Silverstone GD04 vs. GD05 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-01-2011, 01:53 PM - Thread Starter
snakyjake's Avatar
It appears the difference is the CDROM bezel bay.
This is a good image of what the GD05 looks like with the CDROM face.
What does the GD04 look like with a 5.25" optical drive and how does it function through the bezel?
I don't understand the differences. I've always had a full 5.25" bay on my desktop. The GD04 looks more subtle, which I prefer. Just not sure how it really looks and functions.
Jake
snakyjake is offline
post #2 of 5 Old 07-01-2011, 01:59 PM
Zon2020's Avatar
Here's a picture I found on the internet, although I don't think this person has it lined up properly. You can adjust the location of the drive so that the adhesive metal plate is flush with the case. I chose the 04 and am glad I did. The tray works just fine moving in and out, and the metal cover on mine is flush to the front. Obviously you can see that there is a an opening, but it's more subtle in my view than the 05.
The switches and ports are also in different locations. The internals are identical.
Zon2020 is offline
post #3 of 5 Old 07-01-2011, 04:55 PM
ChairTwo's Avatar
GD05
GD04
I've used the 04 also and I like the small cover on the drive.
ChairTwo is offline
post #4 of 5 Old 07-01-2011, 05:45 PM
jeffkro's Avatar
I prefer the looks of the GD04 and its the one I have.
jeffkro is offline
post #5 of 5 Old 07-01-2011, 05:46 PM
jeffkro's Avatar
I just left the trim panel for the dvd door off, it looks fine.
jeffkro is offline
Reply Home Theater Computers
