Advanced MPC-HC Setup Guide - Page 155 - AVS Forum | Home Theater Discussions And Reviews
 165Likes
post #4621 of 4631 Old 04-16-2019, 05:22 PM
Liked: 0
Can anyone link me high end settings for GTX 1080ti? thank you
Hashim Murtada is offline
post #4622 of 4631 Old 04-17-2019, 05:07 AM
Onkyoman's Avatar
Quoted: 864 Post(s)
Liked: 534
Onkyoman is offline
post #4623 of 4631 Old 04-22-2019, 07:29 AM
jchong's Avatar
Quoted: 20 Post(s)
Liked: 32
Hi all, I've been using MPC-HC with MadVR (v 0.89.5) for over 2 years now without problem. I'm still running a PC with Win XP SP3. Today, I encountered this error message for the 1st time:
madHcCtrl.exe - Entry Point Not Found
The procedure entry point _time32 could not be located in the dynamic link library msvcrt.dll
It appears every time I launch a new video. I've tried reinstalling MPC-HC, and also reinstalled MadVR (with latest 0.92.17) to no avail. That error message still comes up.
Any idea how I can fix it?
On another note, is there any other good video renderer aside from MadVR?
jchong is offline
post #4624 of 4631 Old 04-23-2019, 05:29 AM
Quoted: 139 Post(s)
Liked: 41
Originally Posted by brazen1 View Post
Using MPC-HC/BE, OSD: Remaining Time is a key in the player settings you can map to whatever you want. I chose 'I'. When I press 'I' on my keyboard or my remote, it displays the length of the title and how much has played. It's displayed in the player taskbar that pops up when selected and goes away when selected again. You can toggle the current local time up there also but it's 24hr and not 12hr. File name too.
I'm referring to the Windows taskbar, the one on the bottom of the desktop, not the player one.
Tried enabling the Show in tray option, did not get the desired result.
Similar to the 1by1 player options.
ID:	2557146   Click image for larger version
ID:	2557148   Click image for larger version
noob00224 is offline
post #4625 of 4631 Old 05-05-2019, 02:05 PM
Lostclusters's Avatar
On my MPC-HC opening screen, I get a green check mark and a red x. Does anyone know what that means?
Lostclusters is offline
post #4626 of 4631 Old 05-09-2019, 01:39 AM
Quoted: 139 Post(s)
Liked: 41
What is Tearing Test (Ctrl+T)?
Pressing the key combination does not appear to do anything.
post #4627 of 4631 Old 05-09-2019, 02:27 AM
mightyhuhn's Avatar
Quoted: 1131 Post(s)
Liked: 412
not supported by madVR.
noob00224 likes this.
mightyhuhn is offline
post #4628 of 4631 Old 05-18-2019, 10:12 AM
filipp2442's Avatar
Quoted: 28 Post(s)
Running this on a laptop with a 1050 ti, anyone have recommended 1050 ti settings? I'm very new to this and just followed most of the guide where I'm running it on the doubling setting.
filipp2442 is offline
post #4629 of 4631 Old 05-20-2019, 07:44 AM
filipp2442's Avatar
Quoted: 28 Post(s)
For some reason I have huge frame drops/stuttering when trying to run my projector/HTPC at 60hz but its 100% buttery smooth at 24hz, any ideas?
post #4630 of 4631 Old Yesterday, 05:20 PM
Anderegg's Avatar
Quoted: 440 Post(s)
Liked: 242
New to MPC, just curious, if I am running my HDMI out as 1080 24hz, and playing back 1080 24p content, is there any advantage to using MPC over VLC or even Windows Media Center? I see all the talk about processing and needing a high end GPU, but my MPC MadVR 1080 24Hz movie file playback with everything enabled pegs the GPU (GT 1030 Nvidia set as decoder) at 100% with no stuttering, but doesn't lag or drop frames. I am wondering if MPC and all the fixin's are just for upscaling users?
Paul
Sony X900F SDR and HDR Calibrations https://www.avsforum.com/forum/166-l...l#post57551552
Anderegg is online now
post #4631 of 4631 Old Today, 01:01 PM
FGEvans's Avatar
Quoted: 66 Post(s)
Followed the guide above and the suggestion of having 8 separate profiles for example 4k and 1080p 720p sd
I assume you then separately change the settings in each profile. Ie have different options for 1080p than the 4k profile
FGEvans is offline
Reply Home Theater Computers
