Advanced MPC-HC Setup Guide - Page 160 - AVS Forum | Home Theater Discussions And Reviews
 181Likes
post #4771 of 4775 Old 06-01-2020, 07:12 AM
Quoted: 2013 Post(s)
Liked: 646
Originally Posted by Aceman2101 View Post
All I did was change it so it things it’s a ht and not a pc and that’s worked for me. With my Samsung I can change what it thinks the inputs are.
So you fixed it?
It's strange it exceeds the screen when in fullscreen but not when maximized.
There might be other settings in the TV menu that move the picture around. Check those.
Also try MPC BE and don't change anything:
https://sourceforge.net/projects/mpc...274%29%20beta/
noob00224 is online now
post #4772 of 4775 Old 06-01-2020, 07:15 AM
Quoted: 61 Post(s)
Liked: 4
Originally Posted by noob00224 View Post
So you fixed it?
This is what I had to change for it to fit not me. My home theater is really my pc. Just had to edit the source
noob00224 and Dmitriy Z like this.
Aceman2101 is offline
post #4773 of 4775 Old 06-01-2020, 07:41 AM
Liked: 2
Changing to Home Theater works! Now I can set "Fit to screen" to On. Problem solved, thank you!
Aceman2101 likes this.
Dmitriy Z is offline
post #4774 of 4775 Old 06-01-2020, 08:50 AM
Quoted: 61 Post(s)
Liked: 4
It took me forever to figure it out too, it was driving me crazy.
post #4775 of 4775 Old 06-07-2020, 05:59 PM
Liked: 0
Hello MINDBOMB;
I have been using MPC-HC for a long time, so I am well versed in how it works. I just don't understand a couple of things.
1. Why are there two sections for changing the video display? (video frame and pan/scan). It does affect things when changing; stretch to window, touch from inside, and touch from outside. I just don't know what it's doing. They look the same some times which leads to my next question. B/c it has affected what should be the proper a/r. So what should I keep the video display section on? I keep the a/r on "default", but it does not seem to default to proper a/r in all files.
2. I use Media Info. A couple files (that are old 1080p) say the "display aspect ratio" is 16:9. However when playing the file in 16:9 or "Default", the display comes out as 2:40:1? I can scale to 16:9 in pan/scan section but I can not like other files change the A/R in "video frame". Obviously it has the same result, but I should not have to do either since according to Media Info it is 16:9? So is Media Info's data incorrect for the 1080p files? Some of the 1080p files are 2:40:1 and display correctly in Default.
3. In order to play files with 2160p res. I have to use the EVR. So is it a correct statement that you can only change the video display in "system default" and EVRcp, not the regular EVR?
mlmiller is online now
mlmiller is offline
Reply Home Theater Computers
