Popcorn Hour C-200 cannot play movies from V drive shased of FlexRaid - Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 01-30-2014, 08:37 AM - Thread Starter
Elpee's Avatar
Quoted: 97 Post(s)
Liked: 26
Just set up FlexRaid. Everything looks just fine. My HTPC that's running on Windows 8 can see and play movies/ TV shows very well from V Flexraid drive. But doesn't matter how hard I tried, my Popcorn Hour C-200 cannot see that V drive with non-exist drive/ folder error.
Thank you for your help.
Much appreciate it.
Elpee is offline
post #2 of 14 Old 02-03-2014, 10:40 AM - Thread Starter
Elpee's Avatar
Quoted: 97 Post(s)
Liked: 26
Elpee is offline
post #3 of 14 Old 02-03-2014, 10:44 AM
Sammy2's Avatar
Quoted: 1011 Post(s)
Liked: 339
You might want to post your question in this section of AVS Forum too.
Sammy2 is online now
post #4 of 14 Old 02-03-2014, 10:52 AM
mrstop's Avatar
You probably need to change the removable setting from true to false.
mrstop is offline
post #5 of 14 Old 02-03-2014, 12:17 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2725
I thought the popcorn hour just had problems... It's not a flexraid issue I don't think. it's an issue with how the popcorn hour networks into windows.
Mfusick is offline
post #6 of 14 Old 02-03-2014, 01:05 PM
Davecraze's Avatar
Quoted: 199 Post(s)
Liked: 65
Make sure that you set security permissions on the flexraid drive letter to permit the group "Everyone" to access the drive.
Davecraze is offline
post #7 of 14 Old 02-03-2014, 04:19 PM
Dark_Slayer's Avatar
Quoted: 764 Post(s)
Liked: 473
Is your HTPC using homegroup sharing? How do you have sharing setup on your network? What platform is flexraid installed on?
Dark_Slayer is offline
post #8 of 14 Old 02-04-2014, 10:03 AM - Thread Starter
Elpee's Avatar
Quoted: 97 Post(s)
Liked: 26
Thanks, I'll change it to false when I get home today.
That was the very first one I did. I even set "Everyone" has full control, but the issue sitll insists.
I used both SAMBA Windows share and NFS (thru haneWIN NFS).
My home server's sitting on Windows server 2012.
Elpee is offline
post #9 of 14 Old 02-04-2014, 12:10 PM
Davecraze's Avatar
Quoted: 199 Post(s)
Liked: 65
Can your PCH see other drives on the network besides the FlexRAID drive?
post #10 of 14 Old 02-04-2014, 06:10 PM - Thread Starter
Elpee's Avatar
Quoted: 97 Post(s)
Liked: 26
Sorry, still have the problem. See it below.
Elpee is offline
post #11 of 14 Old 02-04-2014, 07:07 PM - Thread Starter
Elpee's Avatar
Quoted: 97 Post(s)
Liked: 26
Yes, it can.
Elpee is offline
post #12 of 14 Old 02-05-2014, 10:43 AM
mrstop's Avatar
Maybe you can try another pooling software? I have been playing with Stablebit Drivepool after some learning pains with Flexraid. Drivepool has a 30 day trial available and it can be setup in a non invasive manner like Flexraid. You may want to turn off the drive balancing while you trial in case you want to go back to the Flexraid pooling option. It's my understanding that you can use Drivepool as your drive extender while using Flexraid for your parity protection.
mrstop is offline
post #13 of 14 Old 02-05-2014, 11:38 AM
mrstop's Avatar
One other suggestion would be to change the name of Filesystem in Flexraid to NTFS under advanced preferences and settings.
mrstop is offline
post #14 of 14 Old 02-06-2014, 05:24 AM - Thread Starter
Elpee's Avatar
Quoted: 97 Post(s)
Liked: 26
Looks like it's my backup plan. Thanks.
I'll do it once I get home today. Thanks.
Elpee is offline
Reply Home Theater Computers
Popcorn Hour C 200 Networked Media Tank Black , Popcorn Hour , Popcorn Hour A 300 Networked Media Jukebox
