New to HTPC, critique my build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-15-2014, 09:33 PM - Thread Starter
dorito31561's Avatar
Hey I've finally decided to build a HTPC. I need it to be able to do 3D bluray playback, 1080p mkv streams, very light gaming (emulators), cablecard DVR (comcast or fios using hdhomerun prime), and Netflix/Hulu/Itunes/etc
Here is the build I'm thinking about http://pcpartpicker.com/p/Gj6pzy
would I be better off spending a little bit more for the i3-4130 and a ~$60MB?
the 240gb ssd is actually going into my gaming rig, and I will be taking the 128gb ssd out of that for the HTPC
The 500gb hdd is just for copy-once dvr stuff (HBO), my gaming rig has a few TB that will hold most of the media
audio will be going to just a stereo setup, so I'm not too worried about fancy audio decoding
home is wired with cat5e thru gigE switch
let me know what you think? I'd like to save money anyway possible to get a faster ROI (from ditching cable dvr)
dorito31561 is offline
post #2 of 3 Old 07-15-2014, 09:36 PM - Thread Starter
UPDATE - sorry pasted wrong url
http://pcpartpicker.com/p/rRGhFT
post #3 of 3 Old 07-15-2014, 11:42 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
- You will want a better CPU cooler, e.g. Scythe Shuriken, $35. Then you'd better go with Core i3-4130 with stock cooler (a lot cooler under load).
- 2GB x 2 is enough.
- You can buy a 1TB 3.5" HDD for the same price. The case can hold up to 2 x 3.5" HDD + 1 x 2.5" HDD/SSD.
- The space between PSU and ODD will be very tight. You'd better choose a different PSU (non-sleeved ATX or SFX, e.g. Silverstone ST40F-ES or ST30SF).
renethx is offline
Reply Home Theater Computers
