MPC-HC with MadVR stuttering in fullscreen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-16-2014, 09:24 PM - Thread Starter
Liked: 0
About a month ago I followed the Advanced MPC-HC setup guide and for a while it worked great. However suddenly I found that when I try to play a video that is a lower resolution than 1080p the video stutters only in fullscreen. 1080p videos work fine in fullscreen. Other videos work with the player at any other size but not in fullscreen. This only happens with madVR on, when I change DirectShow Video to system default or other settings everything works fine. I have not changed any settings in MPC-HC or madVR since everything was last working.
i7-4710HQ CPU @ 2.50GHz
GTX 870m
Windows 8.1
1920x1080 60Hz
Any help with this problem would be greatly appreciated.
JustinCheeseburger is offline
post #2 of 8 Old 09-16-2014, 09:57 PM
orion2001's Avatar
Quoted: 478 Post(s)
Liked: 330
Could be your GPU is choking on the computations needed for upscaling based on the settings in MadVR. I'd first try backing off with the upscaling settings to see if that improves things for you. You should aim to have 0 dropped frames showing up once the video playback begins.
orion2001 is offline
post #3 of 8 Old 09-16-2014, 10:57 PM - Thread Starter
Liked: 0
It seems like thats what it is, but I find it odd that I could use Jinc 3 taps + antiringing with no problems before and now I need to use dxva scaling to get smooth video playback.
EDIT: I have found the problem. It seems that MPC-HC is using my integrated intel graphics instead of my GTX 870m. Is there any way to force it to use the correct one?
post #4 of 8 Old 09-17-2014, 06:28 AM
Postmoderndesign's Avatar
Quoted: 535 Post(s)
Liked: 312
Have you connected your display to your GPU's HDMI rather than your motherboard?
Postmoderndesign is offline
post #5 of 8 Old 09-17-2014, 06:57 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 513
I think OP has a Laptop which contains two GPUs but only one output. It is using the NVidia driver to switch between Intel IGP and GTX 870m depending on the needs.
Foxbat121 is online now
post #6 of 8 Old 09-17-2014, 09:46 AM
bcec's Avatar
Quoted: 243 Post(s)
Liked: 124
If you are not using motherboards hdmi out for anything, then I'd suggest turning it completely off from within bios.
bcec is offline
post #7 of 8 Old 09-17-2014, 02:39 PM - Thread Starter
Liked: 0
This is correct.
post #8 of 8 Old 01-07-2020, 01:34 PM
Liked: 0
Are there any alternatives for madvr? Because I think there is no better software...
SuurbieR is offline
Reply Home Theater Computers
