Hercules Gamesurround Fortissimo™ III 7.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-27-2002, 03:52 PM - Thread Starter
cheapskate's Avatar
Has anybody have any experience with this card. It is a 7.1 DD EX card supposedly. I cant find anybody that has them for sale or any info other than that on the Hercules site. I like the optical out and 7.1 for only 50 bucks. Thanks.
cheapskate is offline
post #2 of 8 Old 10-27-2002, 04:07 PM
andersa's Avatar
Quoted: 55 Post(s)
Liked: 37
Tom's Hardware has a review here
Check out the measurements of the center channel - not pretty...
andersa is offline
post #3 of 8 Old 10-27-2002, 04:30 PM
ryangs's Avatar
There's also a new 6.1 GameTheater card coming soon--haven't seen any reviews of it yet, though.
ryangs is offline
post #4 of 8 Old 10-27-2002, 06:29 PM
z.mash's Avatar
I picked it up at CompUSA and it works fine. Beware that you can either play your digital AC3 sources (PowerDVD) *or* your wave sources (i.e. WinAmp) at a time. You can change the settings, but it requires a reboot. That doesn't affect me since my MB has a builtin soundcard, which I run into the same inputs on my receiver. However, others are not happy with this limitation.
-Zak
z.mash is offline
post #5 of 8 Old 10-27-2002, 08:38 PM
JJay's Avatar
Remember that these measurements are using the 3 outputs on the back of the card and not the optical out. For our htpc uses most of us will be using (hopefully) the optical out to connect to our receiver/processor. The card works fine for being a 50 dollar item. I also got mine at compusa...
Jaime
If you can't say anything kind at least have the decency to be vague...
JJay is offline
post #6 of 8 Old 10-27-2002, 08:41 PM
Alric's Avatar
Can you compare the optical out with an SB Live or Audigy?
Alric is offline
post #7 of 8 Old 10-27-2002, 08:54 PM
andersa's Avatar
Quoted: 55 Post(s)
Liked: 37
J Jay,
I realize that and I agree that the card is most likely adequate for SPDIF out, but cheapskate did mention he was interested in the 7.1, so I just pointed out that there may be quality issues based on the TH review.
/Anders
andersa is offline
post #8 of 8 Old 10-27-2002, 09:38 PM
JJay's Avatar
J Jay,
/Anders
Good point--I stand corrected :)
Jaime
JJay is offline
Closed Thread Home Theater Computers
