*Official* Nvidia Shield Console - HTPC discussion - Page 76 - AVS Forum | Home Theater Discussions And Reviews
 766Likes
post #2251 of 5231 Old 03-10-2016, 09:03 AM
3rob3's Avatar
Quoted: 72 Post(s)
Liked: 29
Originally Posted by Futrader8 View Post
If any of you yahoos have been considering picking up a Flirc to use with your Shield, they are on sale on Amazon right now for $9.49 (plus $5 shipping). $14 plus change is by far the best price I've ever seen for these little puppies.
Good deal! Anyone have a suggestion for a simple remote to pair with this? I am honestly fine with the Shield's remote, just wish I could program TV Power.
3rob3 is offline
post #2252 of 5231 Old 03-10-2016, 02:29 PM
TornadoTJ's Avatar
Quoted: 1934 Post(s)
Liked: 625
With a Flirc?
ANY REMOTE YOU WANT as long as it is IR. If you can find a 1980's remote you like, you can make it work with the Flirc. That's part of the benefit.
Are you just going direct to the TV? Does your TV support CEC? Two of my TVs are set up with the remote that came with the TV and they work great.
TornadoTJ is offline
post #2253 of 5231 Old 03-10-2016, 02:54 PM
3rob3's Avatar
Quoted: 72 Post(s)
Liked: 29
Originally Posted by TornadoTJ View Post
With a Flirc?
Yeah, I actually already have an FLIRC I used with my Nexus Player for awhile. I was just looking for suggestions on a simple remote (programmable power & volume, menu, directional pad, select, and play pause stop). Will probably end up with a Harmony but it is honestly overkill for what I need.
My TV does have CEC, but of course isn't really all that functional with the Shield. It will put the Shield to sleep when it is turned off, but that's about it. The Shield can't wake it or control volume. The TV remote also does not control the Shield via CEC either. It's a 1 year old TCL Roku TV btw.
3rob3 is offline
post #2254 of 5231 Old 03-11-2016, 06:05 AM
TornadoTJ's Avatar
Liked: 625
You can go anywhere from a Nevo C2 (very cheap but there's a learning curve) to a Harmony remote. Currently, I have two bedrooms using CEC, then a Harmony 650 in my bedroom, a Harmony Ultimate hub based remote in my TV room, and a Harmony One in the game room. I do have a C2 and some other remotes I've been playing with, but they require more time than I have to get them working right at the moment. The Harmony just works.
post #2255 of 5231 Old 03-12-2016, 02:49 AM
groove93's Avatar
Quoted: 953 Post(s)
Liked: 539
Google added a Google Play Movies and Trailers channel to Android Live TV, channel 1-1.
groove93 is offline
post #2256 of 5231 Old 03-12-2016, 06:45 AM
MSchu18's Avatar
Quoted: 166 Post(s)
Liked: 362
I know nvidia and amazon dont play well together, but can amazon fire stick be accessible via usb on the shield?
My Name is Nobody...
Klipsch x11i - Klipsch x20i - Oppo HA2
Pioneer SC85 - Bel Canto REF 500M
Klipsch La Scala II - Klipsch Cornwall/Crites/Aletheia Audio - Klipsch RC64II - SW-115
Wyred 4 Sound DAC2 DSDse - OPPO BDP-93
Samsung PN64D8000
MSchu18 is offline
post #2257 of 5231 Old 03-12-2016, 04:16 PM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
not likely, but cant say for sure
wase4711 is offline
post #2258 of 5231 Old 03-14-2016, 07:32 AM
Stevetd's Avatar
Quoted: 310 Post(s)
Liked: 105
Yep.
Hey just stumbled on a nice little present for anyone that needs more storage for their Shield. Is it just me, or isn't $80 for 200GB cheap?
http://www.amazon.com/gp/product/B00...=logicemail-20
$59.99 as of right now!
buckley44 likes this.
Stevetd is offline
post #2259 of 5231 Old 03-14-2016, 09:05 AM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
unreal!!
too bad I bought a 64 gig a couple weeks ago, for 17 dollars.
I wish I had a cell phone or something else that took a micro sd....
wase4711 is offline
post #2260 of 5231 Old 03-14-2016, 09:09 AM
TornadoTJ's Avatar
Liked: 625
Wow that is cheap.
But, last night I noticed the Shield's new way of handling removable storage has hosed Gamesome. I can't configure it to find the removable media to find my ROMs.
post #2261 of 5231 Old 03-14-2016, 02:39 PM
OrlandoD's Avatar
Quoted: 415 Post(s)
Liked: 104
Wow that is cheap.
And there has been no attempt by Nvidia to correct the Shields screwed up way of handling of storage. Are they under the impression that it's all good?
Current HT: Display : Samsung 65JS8500 | Receiver : Denon x2200 | Speakers L-R : EMPTek (RBH) R55Ti's | Speaker C : EMPTek (RBH) R56Ci | Rear Surrounds : EMPTek (RBH) E3b's | Speakers Atmos TM : Micca M-8C | Subwoofer : RSL Speedwoofer 10S | Media Player : Nvidia Shield TV | BluRay : Sony S5500/PS3 | Logitech Harmony 700
OrlandoD is offline
post #2262 of 5231 Old 03-15-2016, 02:30 PM
TornadoTJ's Avatar
Liked: 625
I don't know, I don't visit the NVidia forum. It's not all that important to me at the moment, but eventually I want it to work.
Hey, I noticed something last night. If you have a situation where you have sound with movies in digital format (DD, DTS, etc.) but anything that's stereo or sends your receiver into one of the "old" formats like Prologic II, I found the problem and solution. This had me perplexed. I finally found in the settings that my audio was set to floating or adjustable or something like that - I can't remember exactly. But, what fixed it was to set it to "Fixed".
I'm guessing someone turned the audio all the way down, which seems to only affect analog or LPCM. Anything bitstreamed goes as fixed volume.
post #2263 of 5231 Old 03-15-2016, 02:40 PM
OrlandoD's Avatar
Quoted: 415 Post(s)
Liked: 104
Since I use an AVR, I decided from the get-go to set the audio volume to fixed. I can't say I'm aware of the situation you described above.
OrlandoD is offline
post #2264 of 5231 Old 03-16-2016, 07:07 AM - Thread Starter
Dark_Slayer's Avatar
Quoted: 764 Post(s)
Liked: 473
Looks like Plex users are eventually going to get a good Kodi addon http://forums.plex.tv/discussion/210...odi-connection albeit still limited by Plex on the artwork and trailer side
Dark_Slayer is offline
post #2265 of 5231 Old 03-16-2016, 07:25 AM
Quoted: 162 Post(s)
Liked: 68
This might be old news, but have you guys seen this?:
http://spmc.semperpax.com/
Looks like the Kodi for Android TV developer has had enough and has gone his own way and revived SPMC.
Apparently, Koying was the only Android dev at Kodi, and if no one at Kodi picks up with it, Kodi on Android will be dead for the time being.
https://www.reddit.com/r/kodi/commen...android_dev_a/
EDIT: After reading more of this Reddit thread, looks like there really might be a concerted effort within Kodi to kill off Android development. Anyone want to buy a Shield?
Futrader8 is offline
post #2266 of 5231 Old 03-16-2016, 07:46 AM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
you'd abandon a device based on Reddit chatter?????
wase4711 is offline
post #2267 of 5231 Old 03-16-2016, 07:49 AM
bryansj's Avatar
Quoted: 1753 Post(s)
Liked: 789
Yes, I've been following that thread. The good thing is that I haven't had time to deal with it and since I started following it there have been about five new releases. Maybe this weekend I'll try it.
bryansj is offline
post #2268 of 5231 Old 03-16-2016, 07:52 AM
Quoted: 162 Post(s)
Liked: 68
That was actually meant as tongue in cheek.
post #2269 of 5231 Old 03-16-2016, 07:53 AM
bryansj's Avatar
Liked: 789
Well he did mention he was leaving on the Kodi forum.
bryansj is offline
post #2270 of 5231 Old 03-16-2016, 07:54 AM
staknhalo's Avatar
Quoted: 383 Post(s)
Liked: 241
I'll give you $3.50
OrlandoD likes this.
staknhalo is offline
post #2271 of 5231 Old 03-16-2016, 07:56 AM
Quoted: 162 Post(s)
Liked: 68
Originally Posted by staknhalo View Post
I'll give you $3.50
Sucker! I would have taken $3.
post #2272 of 5231 Old 03-16-2016, 07:59 AM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
is our Shield a 64 bit or X86?
also, has anyone run SPMC and Kodi on the same Shield at the same time?
thanks
wase4711 is offline
post #2273 of 5231 Old 03-16-2016, 08:04 AM
kemetblk's Avatar
Quoted: 30 Post(s)
Liked: 31
thanks
Neither. It's ARM based.
Sent from my VS986 using Tapatalk
wase4711 likes this.
AVR: Denon X3300w
F/C/R: Polk RTi A9's / CSi A6 / Speakercraft AIMWIDE 3 / Sub: SVS PB12-NSD (x2)
Sony XBR-75X940E, Toshiba HD-A30, Nvidia Shield TV (2015), Xbox One S, PS3
PC: Core i7, 16GB RAM, 512GB ssd + 4TB hdd, GTX 970 SSC
kemetblk is offline
post #2274 of 5231 Old 03-16-2016, 08:10 AM
staknhalo's Avatar
Quoted: 383 Post(s)
Liked: 241
Arm processors are also 32-bit or 64-bit, which is what I think he meant.
The X1 in the SHIELD TV is 64-bit.
post #2275 of 5231 Old 03-16-2016, 02:01 PM
OrlandoD's Avatar
Quoted: 415 Post(s)
Liked: 104
So can Koying's SPMC build be installed on the shield while KODI is installed or do I need to remove the regular KODI build first?
OrlandoD is offline
post #2276 of 5231 Old 03-16-2016, 03:28 PM
3rob3's Avatar
Quoted: 72 Post(s)
Liked: 29
From the Kodi wiki: "SPMC has a different app ID from Kodi, so both can be installed side by side at the same time".
3rob3 is offline
post #2277 of 5231 Old 03-16-2016, 04:06 PM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
I've got them both installed now, without any issues!
wase4711 is offline
post #2278 of 5231 Old 03-16-2016, 04:27 PM - Thread Starter
Quoted: 764 Post(s)
Liked: 473
This was a hilarious read to me http://forum.kodi.tv/showthread.php?tid=264310 though I had to look up what bikeshed meant, which cracked me up big time
post #2279 of 5231 Old 03-17-2016, 04:57 AM
mr b's Avatar
Quoted: 181 Post(s)
Liked: 83
Same here. Took care of my issue of not being able to get the GUI to show in 4K. Movie info also shows as 4K which I was unable to get since Kodi 15.2.
Passthrough working as well.
My Gear:
Spoiler!
mr b is offline
post #2280 of 5231 Old 03-17-2016, 08:09 AM
Alan P's Avatar
Quoted: 6144 Post(s)
Liked: 5367
So I've read about half of the thread, but I have a couple of quick questions:
Does lossless audio passthru work with Kodi yet? Not a deal-breaker for me though, I'm fine with PCM.
Is Amazon Prime available yet? Will it ever be??
Alan P is offline
Reply Home Theater Computers
