AMD Catalyst Control Center changes revert back after 30 seconds - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By Vorkosigan
  • 1 Post By pohh-bah
post #1 of 6 Old 05-30-2015, 11:39 AM - Thread Starter
ontherocks's Avatar
[Workaround] AMD Catalyst Control Center changes revert back after 30 seconds
I have AMD Radeon HD 5450 and AMD catalyst 15.5 Beta (currently).
If I change the pixel format and hit the Apply button, the changes take place but it reverts back to default after 30 seconds.
Previously after 30 seconds a pop up would appear asking "Do you want to keep these display settings?". If I hit Yes, the changes would be saved. Now that pop up never appears.
I tried installing older versions of catalyst, tried reinstalling Windows. No luck.
ontherocks is offline
post #2 of 6 Old 05-30-2015, 03:51 PM
Quoted: 386 Post(s)
Liked: 277
I've had issues with the Beta drivers in terms of video playback (related to 3D.) I ended up reverting to the Omega (14.12) drivers and everything works well.
TB4XSBC is offline
post #3 of 6 Old 05-31-2015, 05:10 AM
Vorkosigan's Avatar
Quoted: 39 Post(s)
Liked: 34
I had the same problem. From what I read, it's a bug in the software. The only solution I found that works (iirc) was to reboot immediately after making the change.
ontherocks and StinDaWg like this.
Vorkosigan is offline
post #4 of 6 Old 05-31-2015, 08:15 AM - Thread Starter
ontherocks's Avatar
OMG That worked! Thanks a lot.
I was about to download lots of previous versions of catalyst and test one by one. You saved me a lot of hassle, time and headache.
What kind of nonsense bug it is? How did you come up with this idea?
post #5 of 6 Old 05-31-2015, 08:41 AM
pohh-bah's Avatar
Quoted: 29 Post(s)
You don't need bleeding edge drivers for old video cards. Just find one that works and leave it alone.
nightfly85 likes this.
pohh-bah is offline
post #6 of 6 Old 05-31-2015, 08:43 AM
Vorkosigan's Avatar
Quoted: 39 Post(s)
Liked: 34
I can't take the credit. I searched and searched and searched and ended up finding it in some topic somewhere. (I think it was here.) I don't remember who suggested it, but they also suggested changing that setting and then immediately changing another setting, but that didn't work for me.
Reply Home Theater Computers
ati , catalyst
