Big WMC guide changes starting today - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 170Likes
post #631 of 944 Old 09-13-2016, 10:25 AM
JHBrandt's Avatar
Quoted: 2829 Post(s)
Liked: 1373
Originally Posted by DrDon View Post
I can't remember how to fix this..
Win7 x32 HTPC with 4 ATSC and 1 DirecTV (capture box) tuner. Guide has stopped populating program info for the ATSC channels only. They're still IN the guide. Re-ran setup and WMC correctly determined 4 ATSC and 1 DirecTV. Set up DirecTV for East Coast Digital as I always have (no local channels). Every channel, OTA and Satellite, is correctly LISTED in the guide. I even re-did all the checkmarks under Edit Channels. So, that's all correct. Just "no data" for all the OTAs.
But.. when I look at the Guide Information Page, it only lists DirecTV.. no OTA.
Something like this always happens the day before the fall television season begins. All was well through last week.
I need a fix. Please do not suggest EPG123 as thegreenbutton reports just as many issues with it as Rovi.
Much thanks..
Your friendly moderator.
That sounds similar to an issue I often have. I use two guide sources: OTA and Dish. (I don't actually have a Dish capture device hooked up, but I use the Dish guides with Guidetool to fill out some OTA channels where Rovi's OTA guide is missing or unhelpful.) Sometimes my OTA quits updating even though the Dish guides stay updated.
If TornadoTJ's suggestion works, let us know; otherwise, try this. First exit Media Center, then open the Task Scheduler (in Administrative Tools), expand Task Scheduler Library / Microsoft / Windows and click (no need to expand) Media Center. Then right-click ObjectStoreRecoveryTask in the center pane and run it.
It will only run a few seconds, then it'll start MCUpdate, which will take the typical amount of time to run. Once that's done, you can start WMC again. You'll see a message about WMC fixing a problem with your setup (don't remember the exact wording). Just click OK and check your guide. It should be back to normal.
Robert Clark and DrDon like this.
JHBrandt is offline
post #632 of 944 Old 09-13-2016, 10:27 AM
TornadoTJ's Avatar
Quoted: 1950 Post(s)
Liked: 626
When the guide changes happened (the switch to Rovi) the zip code thing was the workaround. I was guessing that this was the workaround you were looking for. I can't guarantee it'll solve the issue.
TornadoTJ is offline
post #633 of 944 Old 09-13-2016, 11:57 AM
Super Moderator
DrDon's Avatar
Quoted: 2299 Post(s)
Liked: 4344
The zip code thing oddly isn't working.. for the current zip code. I can switch it to five states away and it's fine. Here? Nope. Will try JH's method. Luckily, the backup machine (also OTA and DirecTV, but uses WinTV for DirecTV) is fine and updated with two weeks of guide data.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #634 of 944 Old 09-13-2016, 12:04 PM
Ken.F's Avatar
Quoted: 2290 Post(s)
Liked: 2570
I've had to try a few different ones until I found one that works. I've always been lucky enough to find a good zip code close enough to me that the guide data was the same.
Ken.F is offline
post #635 of 944 Old 09-13-2016, 12:15 PM
Super Moderator
DrDon's Avatar
Liked: 4344
One would think the zip code that works on one machine would work on the other. The backup computer is fine. But it doesn't use WMC for DirecTV. Just OTA.
EDIT
Rebuild seems to have worked. Some guide data has correctly loaded. Promising.
EDIT
Spoke too soon. Now, it's lost most of the DirecTV listings. Refreshing the guide, then will try setup, again.
DrDon is offline
post #636 of 944 Old 09-13-2016, 12:57 PM
TornadoTJ's Avatar
Liked: 626
Well, you would think the guide would just work.
DrDon likes this.
post #637 of 944 Old 09-13-2016, 01:03 PM
Super Moderator
DrDon's Avatar
Liked: 4344
Aaaaand we're back. Thanks a ton JHBrandt.
After restarting WMC, I did get the "rebuilding" notification and let that run. Got the locals but only the first couple hundred DirecTV channels. Nothing past ESPN.
Re downloaded the guide from WMC menu. Made it to 80% and threw an error.
Re-ran TV Signal Setup (using current zip). (I do cancel "scan for add'l channels you may receive") Guide download made it to 80% and threw an error.
Manually forced guide update from system tray icon. Guide download threw the error.. BUT.. All now appears well. Bonus: I have my notes forever enshrined in this thread.
One of these days, I'll break down and get a DirecTV DVR. Holding out because I'm on a no-longer-offered package I'll lose when I change anything. But I digress.
Many thanks.
DrDon is offline
post #638 of 944 Old 09-13-2016, 01:20 PM
Liked: 1028
Originally Posted by mdavej View Post
Hopefully Tivo subs won't tolerate Rovi's terrible data, and Rovi will have to step up and actually fix it.
We're going to find out soon how much of Rovi's incompetence that Tivo users are going to take. There's already been plenty since the guide data switchover started.
The only hope here is that if Tivo forces Rovi to get their act together to keep their users from leaving, WMC will benefit.
6athome likes this.
slowbiscuit is offline
post #639 of 944 Old 09-13-2016, 02:49 PM
JHBrandt's Avatar
Liked: 1373
I often get an error when my guide downloads. Usually it seems meaningless and the guide is fine.
Looking at Event Viewer, the error seems to have something to do with downloading an obsolete part of the guide - "nettv" or something like that. It appears the guide package names are case sensitive and that it should be trying to download "NetTV" instead.
I don't even think there's anything in that part of the guide anymore - it's been a long time since WMC had any Internet channels - but for some reason MCUpdate still seems to want to download it, and complains if it doesn't work.
JHBrandt is offline
post #640 of 944 Old 09-13-2016, 03:36 PM
Super Moderator
DrDon's Avatar
Liked: 4344
That makes total sense as, during one of the zip code switching attempts, the thing loaded all the internet channels that have long since been removed.. CBS, etc.
DrDon is offline
post #641 of 944 Old 09-14-2016, 05:56 AM
6athome's Avatar
Quoted: 648 Post(s)
Liked: 175
I have two HTPC, one runs win 7, other one 8.1 pro w/wmc. I read that Rovi had bought out Tivo and like you I was wondering how that will affect WMC, I miss the year that the movie was made, showing up in WMC.
6athome is offline
post #642 of 944 Old 09-23-2016, 08:40 PM
JorgeA's Avatar
Quoted: 72 Post(s)
Liked: 25
Not sure if this is the right thread for this, but has anybody noticed a short window on the EPG this week? I was looking ahead in the grid and noticed that the program info for some channels ends on the evening of 9/25, the info for other channels stops late on 9/29, and the furthest out we have for any channels is on 9/30. Usually of course everything goes a couple of weeks out.
Tried doing a manual guide update via WMC and it was unsuccessful.
UPDATE:There's a thread about this over at The Green Button (http://www.thegreenbutton.tv/forums/...p?f=96&t=10345). Apparently it's been going on for several days.
JorgeA is offline
post #643 of 944 Old 09-24-2016, 05:36 AM
bmcn's Avatar
Quoted: 2220 Post(s)
Liked: 3124
Remarkable that Rovi nailed the Olympics schedule in advance, then reverted to prior form.
bmcn is offline
post #644 of 944 Old 09-24-2016, 07:03 AM
garnuts's Avatar
Quoted: 93 Post(s)
Liked: 63
This has been going on with WMC Rovi guide data for 1-2 years. For some users it would sometimes get down to only 1 or 2 days of guide data, but Microsoft always gets it fixed before it completely runs out. Since MS no longer supports WMC, it does not seem they are too concerned about guide data for a tiny fraction of their customers, and who knows when they may completely quit supplying guide data altogether.
If you get tired of Rovi, there is an alternative also here at TGB: http://www.thegreenbutton.tv/forums/viewforum.php?f=99
EPG123 is a free program developed by a TGB member. It uses guide data from Schedules Direct which does have a $25 annual fee, but also has a 7 day free trail.
I swithced to EPG123 about 9 months ago. The guide data has never run out like Rovi. It is more accurate than Rovi, no more 'TBA' for sporting events, late night talks shows and other shows have actual data for that show instead of a generic show description. There is a lot of support in the EPG123 subforum from the developer and users.
Living Room: Denon X3600H, XPA-5, 7.1.4 Polk RTiA9, CSiA6, FXiA4, OWM3, RSL C34E, SVS PC12+, 4 Shakers, Epson 5050, VApex 92”, Sony 65X900F, Sony X800, Xbox360, Shield, Roku Ultra, Odroid-N2.Bedroom: Marantz SR6013, 5.1.2 Polk: LSiM 703, LSiM 704, RTiA1, OWM3, SVS SB12-NSD, LG OLED6B8, Xbox 360, Roku3, RPi2-RasPlex, FireStick 4K. Home Office: Onkyo 707, Polk: RTiA3, CSiA4, Monitor 70, Yamaha SW315 x 2, Turntable, Triple Monitors.
garnuts is offline
post #645 of 944 Old 09-24-2016, 09:06 PM
JorgeA's Avatar
Quoted: 72 Post(s)
Liked: 25
Thumbs up
Thanks VERY much for the info.
The first channels to run out of data end at 8PM tonight (Sunday). The "Introducing EPG123" thread runs for 64 pages with 1279 posts. All told, including resetting the series recordings, how much manual work is involved in carrying out the changeover? (In other words, what are the chances that I can have this up and running by 8PM?)
One more thing. The EPG123 User's Guide says (p. 4) that:
>>All guide customization will be lost (callsigns, channel numbers, favorite lineups, logos, ...)<<
Not sure what that means: If call signs and channel numbers are lost, then how does anybody use the program guide?
Much appreciated!
JorgeA is offline
post #646 of 944 Old 09-25-2016, 06:49 AM - Thread Starter
mdavej's Avatar
Quoted: 3077 Post(s)
Liked: 1395
That just means you have to set those up again. All those features still work.
As long as you start before 7:45, you should be fine.
Sammy2 likes this.
mdavej is offline
post #647 of 944 Old 09-25-2016, 09:06 AM
JorgeA's Avatar
Quoted: 72 Post(s)
Liked: 25
Whew, that's a relief!
It sounds that from start to finish the whole process of getting EPG123 ready for use doesn't take all that long?
I'll be doing that today, as last night and this morning the guide update via WMC failed, while the manual update from outside WMC managed to download the info but then stopped processing it at 92% each time.
JorgeA is offline
post #648 of 944 Old 09-25-2016, 09:34 AM
Super Moderator
DrDon's Avatar
Liked: 4344
FWIW, my WMC guide is valid thru 10/7. If yours is still failing to download, then the issue may be on your end. Mine's run rather flawlessly since performing the recommended resets a few posts up.
Let us know how it goes for you.
DrDon is offline
post #649 of 944 Old 09-25-2016, 12:04 PM
JorgeA's Avatar
Quoted: 72 Post(s)
Liked: 25
I tried the ideas given in posts 628, 631, and 637. None of them worked. The ObjectStoreRecoveryTask thing failed.
In fact, things are a little worse than before, as the guide info for the high-def cable channels (CNN, Lifetime, FX, etc.) now runs out immediately rather than at 8PM tonight.
Strangely, we have guide info for the standard-def versions of all those channels, just not for the high-def ones... the ones we're interested in recording.
JorgeA is offline
post #650 of 944 Old 09-26-2016, 02:40 PM
JHBrandt's Avatar
Liked: 1373
I noticed the short guide too, and ObjectStoreRecoveryTask didn't help me either. At least it didn't make things any worse. I'll check again tonight and see if M$ got it fixed.
BTW, Rovi's DVR+ guide is fine, so this must be an issue with the M$ servers, not with Rovi itself. (Many of the other issues mentioned are due to Rovi, however.) Traditionally, this happens right before a Daylight Saving Time change, but this time, something else must be the problem as we're over a month away from the next DST change.
Edit: They fixed it, just in the nick of time for me. Now it goes all the way out to 10/7 and all is well again.
I see at TGB that the guide did run out for some folks overseas before it got fixed. Maybe M$ shut off updates on purpose, because Rovi has had a bunch of bad TBA entries in the guide recently, as a result of their TiVo screw-ups, and M$ figured it was better to let the guide dwindle (and give Rovi a chance to fix the problems) than to replace good entries with bad ones and cause folks to miss recordings.
JHBrandt is offline
post #651 of 944 Old 09-26-2016, 10:51 PM
JorgeA's Avatar
Quoted: 72 Post(s)
Liked: 25
Some channels started to run out of guide info before any fix came in for us, so I ended up downloading EPG123 and doing a trial subscription for Schedules Direct.
Boy, is it nice. The grid listings are even color-coded by type (sports, movie, etc.) although I haven't figured out all of the categories yet.
Thanks to @garnuts for the tip!
JorgeA is offline
post #652 of 944 Old 09-26-2016, 11:30 PM
rc05's Avatar
Quoted: 153 Post(s)
Liked: 87
FWIW, you can enable color coding of the guide with Rovi data, you just have to turn it on in guide options
rc05 is offline
post #653 of 944 Old 09-27-2016, 09:40 AM
garnuts's Avatar
Quoted: 93 Post(s)
Liked: 63
I'm glad the switch went well for you and you like it
garnuts is offline
post #654 of 944 Old 10-12-2016, 10:11 AM
Ken.F's Avatar
Liked: 2570
It looks like Rovi is mucking up the guide data again. I only use WMC for recording programs that are flagged copy once so I don't check the recording schedule very often. I looked at it this morning and noticed there were no recordings scheduled for the series "American Horror Story: 6". Rovi changed the series name in the guide data to just "American Horror Story" without the ": 6" at the end so my old series rule didn't recognize it as a match. Thanks Rovi. I'm glad I wasn't out of town this week. I only need WMC to record three shows and it can't even do that right.
Ken.F is offline
post #655 of 944 Old 10-12-2016, 10:21 AM
Sammy2's Avatar
Quoted: 1043 Post(s)
Liked: 345
Why are you not using epg123 yet? Here's a screen shot of my series information in Emby (I'm not at home right now so I can't grab it in WMC for you) which is the same information that is in WMC. I strongly urge you to ditch the native WMC guide.
Name:	American Horror Story.JPG
Sammy2 is offline
post #656 of 944 Old 10-12-2016, 10:28 AM
JHBrandt's Avatar
Liked: 1373
Rovi did the same thing with Star Trek on H&I. They originally titled it Star Trek: The Original Series but that caused it not to match their own database so none of the shows had episode titles or descriptions. So then they shortened it to just Star Trek. That fixed the titles and descriptions, but if you had set up to record Star Trek: The Original Series (or even just anything containing "Star Trek:" with the colon) your recordings quit working
JHBrandt is offline
post #657 of 944 Old 10-12-2016, 10:51 AM
sgbroimp's Avatar
Quoted: 305 Post(s)
Liked: 40
Maybe he objects, as I do, to paying for a decent TV guide that used to be free (Zap2it), which was like a decent NFL team whereas Rovi performs like a group of sandlot kids half the time.
sgbroimp is offline
post #658 of 944 Old 10-12-2016, 10:53 AM
Sammy2's Avatar
Liked: 345
It is $2.08 a month. Worrying about bad data in your guide and or missed recordings is worth more than that.
EDIT: What I mean is the guide in WMC used to be good and it was free. Now it is either bad and free or costs a couple bucks a month and it is good. Things change.. This isn't a huge budget breaker, IMHO.
Sammy2 is offline
post #659 of 944 Old 10-12-2016, 11:12 AM
Ken.F's Avatar
Liked: 2570
I'm only using WMC to fill in the gaps until Silicondust gets DRM working. I really don't want to put any money into it.
Ken.F is offline
post #660 of 944 Old 10-12-2016, 11:13 AM
Ken.F's Avatar
Liked: 2570
Originally Posted by sgbroimp View Post
Maybe he objects, as I do, to paying for a decent TV guide that used to be free...
I don't object to paying for guide data. I object to paying for guide data that I don't plan on using in the near future.
Ken.F is offline
Reply Home Theater Computers
