Big WMC guide changes starting today - Page 24 - AVS Forum | Home Theater Discussions And Reviews
 171Likes
post #691 of 942 Old 01-30-2017, 09:42 PM
JHBrandt's Avatar
Quoted: 2938 Post(s)
Liked: 1432
Yes I'm familiar with it. Unfortunately I'm in the middle of a series, and setting up the guide again with a different provider would mess up recording the series. Kind of went through that with the transition from Zap2it to Rovi in the first place - many of the station ID codes changed and broke up series recordings.
But once I'm out of the series I'll consider it.
JHBrandt is online now
post #692 of 942 Old 01-31-2017, 10:05 AM
Sammy2's Avatar
Quoted: 1059 Post(s)
Liked: 346
epg123 FTW!
Only caveat is some set ups with Colossus Video Capture and some European regions. If that doesn't apply to you then you should be good to go.
Sammy2 is offline
post #693 of 942 Old 01-31-2017, 12:17 PM
JHBrandt's Avatar
Liked: 1432
Is/was anyone who is still on the Rovi guide experiencing issues as I described above? This apparent outage surprised me because:
  1. We're not near the DST change date
  2. As I mentioned above the Rovi guide is working with other devices
I'm trying to determine if my WMC setup got hosed somehow.
post #694 of 942 Old 01-31-2017, 01:47 PM
LastButNotLeast's Avatar
Quoted: 2773 Post(s)
Liked: 2446
My data goes out to 2/8. I started downloading updated guide data > 30 minutes ago, still waiting.
I wouldn't worry just yet, though. They have a tendency to get things working in the nick of time.
So far, anyway.
Michael
LastButNotLeast is offline
post #695 of 942 Old 01-31-2017, 02:17 PM
JHBrandt's Avatar
Liked: 1432
Thanks; at least I know it isn't just me.
The way I found out, though, was that H&I changed their prime-time schedule yesterday. But the current guide from Microsoft/Rovi still has their old schedule, causing WMC to record the wrong shows on that station.
I suppose I could do a manual recording by time and just put the right show title in until it gets fixed. That would mean no episode title, original air date, or description though.
Or I could set up EPG123 and just hope that there are none of the little spelling, etc. differences that broke up my series last time I switched guides (which was when we all did).
post #696 of 942 Old 01-31-2017, 02:45 PM
garnuts's Avatar
Quoted: 100 Post(s)
Liked: 69
It's not just you, there is a thread on TGB:
http://www.thegreenbutton.tv/forums/...p?f=96&t=10615
JHBrandt and bmcn like this.
Living Room: Marantz 6013, XPA-5, 7.1.4 Polk RTiA9, CSiA6, FXiA4, OWM3, RSL C34E, SVS PC12+, 4 Shakers, Epson 5050, VApex 92”, Sony 65X900F, Sony X800, Xbox360, FireStick 4K, Roku Ultra, Odroid-N2. Bedroom: Denon 3600, 5.1.4 Polk: LSiM 703, LSiM 704, RTiA1, OWM3, SVS SB12-NSD x 2, LG OLED65B8, Xbox 360, Roku Ultra, Shield, FireStick 4K. Home Office: Onkyo 707, Polk: RTiA3, CSiA4, Monitor 70's, Yamaha SW315 x 2, Turntable, Triple Monitors.
garnuts is offline
post #697 of 942 Old 01-31-2017, 06:16 PM
JHBrandt's Avatar
Liked: 1432
It appears to be a data error of some sort in the download package. Mine got up to 81% processed before erroring out (according to the tool tip on the Media Center update icon in the system tray).
So, since it started 1/26 and the guide typically goes 12 days, it's probably in the 2/7 data. Which just happens to be where my guide stops. So if nobody fixes it before then, it should fix itself as soon as the guide runs down to zero and we get past whatever the bad data is.
post #698 of 942 Old 02-01-2017, 06:40 AM
sgtarky's Avatar
its odd I havent had any issue with guide until recently. I used wmc guide constantly but I had to leave home in april my wife complained about no data. so I got teamviewer up and I noticed it hadn't recorded anything since May. From my reading it seemed issues started happening in the summer of 15 and I didnt have any problems. Anyway, I put titantv ip in the host file and I see that the guide is populated again. I dont know if it was working I had to reboot and couldnt get back in and my wife went to sleep. So. i will check on this later.
--ok seems to be working so far.
sgtarky is offline
post #699 of 942 Old 02-01-2017, 08:54 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 515
WMC guide problems are now routine problem of couple times a year from roughly zero or one per year. Most of them are usually resolved just before the guide data run out. So, most ppl probably never know about it ever happened if you are not looking at your guide careful (not an easy task in WMC UI).
Foxbat121 is offline
post #700 of 942 Old 02-01-2017, 01:05 PM
Sammy2's Avatar
Liked: 346
Yes. You need to reprogram your series because they get lost when you change to epg123. It is a PITA but IMHO it is well worth the effort. I've had consistent guide data good for 3 weeks out since I made the switch, even when it was in beta.
Sammy2 is offline
post #701 of 942 Old 02-01-2017, 11:48 PM
JorgeA's Avatar
Quoted: 73 Post(s)
Liked: 25
I second what Sammy2 said about epg123.
Last fall, the Rovi guide info got down to a single day and wife was screaming bloody murder as it was the start of the new TV season. So I installed epg123 and ponied up for the Schedules Direct subscription. Took a while to rebuild the series recordings, but once we got that and a few minor glitches sorted out I have to say it's the best tech $25 I've spent in a loooong time.
JorgeA is offline
post #702 of 942 Old 02-05-2017, 06:38 PM
Black Banshee's Avatar
Quoted: 17 Post(s)
Liked: 34
I have been happy with WMC for many years but lately have been having nothing but problems, including these programming issues. I just switched to a TiVo bolt this weekend and it is so much better and quicker! Really wish Microsoft would have kept WMC properly updated and supported.
mdavej likes this.
Black Banshee is offline
post #703 of 942 Old 02-05-2017, 10:02 PM
Worf's Avatar
Quoted: 880 Post(s)
Liked: 611
Wmc and TiVo share the same guide data and both are having plenty of guide data issues - mostly because rovi data sucks.
Worf is offline
post #704 of 942 Old 02-06-2017, 11:03 AM
JHBrandt's Avatar
Liked: 1432
Originally Posted by Worf View Post
Wmc and TiVo share the same guide data ... rovi data sucks.
Yes, that's true in general, but this time it really is was Microsoft's fault. Other Rovi guide users like TiVo and CM's DVR+ are had been getting guide data just fine.
Edit: Posters at TGB are saying it's fixed now!
Edit 2: Confirmed! Had to run ObjectStoreRecoveryTask but my guide is back. Goes out to the 18th (I don't really trust it past the weekend, though).
Soon I'll probably give epg123 a try anyway, to see if I can improve the "out weeks" guide data.
post #705 of 942 Old 02-09-2017, 08:37 AM
Liked: 2446
What do you know, it got fixed. Another apocalypse avoided.
post #706 of 942 Old 02-09-2017, 11:43 AM
JHBrandt's Avatar
Liked: 1432
Hardly an apocalypse, but definitely a major, unnecessary hassle. This was the closest they've gotten to running out completely that I can remember.
post #707 of 942 Old 02-09-2017, 10:57 PM
Worf's Avatar
Quoted: 880 Post(s)
Liked: 611
Except when your guide data was running out feb 8/9 - people on the TiVo forums were complaining the exact same thing, and my tivos also ran out on he same date.
Of course, a week later it was resolved for me. It was funny when I clicked on Guide and it warned me it was down to 3 days, because I had done my recordings for the next two weeks, and I shouldn't be running out as I had already scheduled one and a half weeks of data.
Worf is offline
post #708 of 942 Old 02-10-2017, 12:44 PM
JHBrandt's Avatar
Liked: 1432
That's weird because my DVR+ was fine - and it gets guide data from Rovi/TiVo too. In fact, it was a guide change on my DVR+ that WMC didn't pick up that alerted me to the problem in the first place!
Someone at TGB suggested that Rovi changed something - perhaps a TLS certificate - and it broke communications between the Rovi servers and some others, including Microsoft's. Apparently the TiVo servers were affected too, but they got fixed quicker.
Even though Rovi owns TiVo now, I suspect they still have separate servers, to minimize changes to both TiVo and other Rovi customers.
post #709 of 942 Old 03-16-2017, 05:10 PM
aab1's Avatar
Quoted: 74 Post(s)
It started happening again that once a week all my channel numbers get mixed up (entering 602 may go to 371, entering 700 may go to 47, there is no logic) causing me to miss all my recordings until I realize it's happening again.
I REALLY can't take this anymore. I know someone mentioned there was a solution that costs a monthly fee, firstly what is the monthly fee and is this solution available to users in Canada? Also does it add any inconveniences such as having to update guide data manually or anything like that?
How can Rovi be THAT incompetent? It makes no sense.
aab1 is offline
post #710 of 942 Old 03-16-2017, 05:47 PM
Sammy2's Avatar
Liked: 346
epg123 requires a subscription to Schedules Direct which is $25 a year or $6 for two months.
Sammy2 is offline
post #711 of 942 Old 03-16-2017, 06:10 PM
garnuts's Avatar
Quoted: 100 Post(s)
Liked: 69
Schedules also has a 7 day free trial!
garnuts is offline
post #712 of 942 Old 03-18-2017, 08:29 PM - Thread Starter
mdavej's Avatar
Quoted: 3189 Post(s)
Liked: 1459
A bad day for WMC. Our friend Jon Fincher, presumably "owner" of WMC, has just left Microsoft. He was pretty much our only direct contact via the online community.
More here:
http://www.thegreenbutton.tv/forums/...p?f=30&t=10762
Yet another reason to switch to EPG123.
mdavej is online now
post #713 of 942 Old 06-11-2017, 12:00 PM
aab1's Avatar
Quoted: 74 Post(s)
I haven't had any problems with Rovi in a few months now, does anyone know what's going on?
JHBrandt likes this.
aab1 is offline
post #714 of 942 Old 06-11-2017, 12:20 PM
Super Moderator
DrDon's Avatar
Quoted: 2414 Post(s)
Liked: 4656
Let's hope you didn't just jinx it
Seriously, for a while, I was having to rebuild the guide every week. Then, starting about a month ago, it held. Been fine, since.
Now that I've typed that, I should go check it.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #715 of 942 Old 06-11-2017, 05:41 PM - Thread Starter
mdavej's Avatar
Liked: 1459
Rovi data is still pretty terrible for Tivo users. I chalk this up to the small amount of data you care about is ok. The rest is still garbage.
post #716 of 942 Old 06-11-2017, 07:16 PM
JHBrandt's Avatar
Liked: 1432
I love it: "Rovi isn't screwing up so much of late - what's wrong?"
Actually I have seen an issue, but it's pretty minor: my WMC guide only gets new shows every 2 or 3 days lately instead of getting new shows every day. No big deal, so I'm still putting off that EPG123 update....
post #717 of 942 Old 07-06-2017, 11:56 PM
T Rush's Avatar
Quoted: 14 Post(s)
Liked: 4
isn't it Microsoft that still has to get the data to our WMC rigs?
anyway; over the last two days, my HTPC Windows Media Center has almost all of the "HD" channels showing "no data available" in the guide .... I've never had this big of an outage before....as someone else posted; it likely happens to people all the time, they just never notice it because the guide reloads/is fixed before it runs out of data
I first noticed it about a week ago on another computer in my house I dusted off and ran some updates, then tried out WMC and only got some channels showing guide data....then later I saw the same deal on my main home theater
so now I'm just flipping through the channels like the old caveman days hoping to find something good on.....only problem is that back then there only was like 4 or 5 channels or 36 once we got cable, so you could see them all....now I just never know if something better is on...of course I won't be recording anything: anyone know if there is a F1 race this weekend? time and channel?
T Rush is offline
post #718 of 942 Old 07-07-2017, 01:59 AM
coug7669's Avatar
Quoted: 78 Post(s)
Liked: 47
I too suffer from the guide issues. I get all the way to Showtime then the rest of the channels display no data.
coug7669 is online now
post #719 of 942 Old 07-07-2017, 04:27 AM
Sammy2's Avatar
Liked: 346
No. You can.
I made the jump to epg123 over a year ago and haven't looked back since. Not that there hasn't been a few glitches along the way but it is far superior. Take a look here to see what you've been missing all this time.
Sammy2 is offline
post #720 of 942 Old 07-07-2017, 08:45 AM
JHBrandt's Avatar
Liked: 1432
They've been talking about this over at The Green Button: http://www.thegreenbutton.tv/forums/...p?f=96&t=10770. Start reading around page 14 or so. It seems to be a problem with higher-numbered cable channels.
If you're interested in EPG123, don't post on the thread I just linked to, which is only for Rovi guide users. But here's a link to TGB's EPG123 subforum instead: http://www.thegreenbutton.tv/forums/viewforum.php?f=99 where you can get any help you need setting up and using EPG123.
If you stick with the Rovi guide, you may be able to work around the problem by linking the SD program guides to the HD channels.
Reply Home Theater Computers
