Big WMC guide changes starting today - Page 27 - AVS Forum | Home Theater Discussions And Reviews
 170Likes
post #781 of 944 Old 07-24-2017, 08:29 PM
LastButNotLeast's Avatar
Quoted: 2361 Post(s)
Liked: 1988
I've been using "-crl -hms -pscn 15" for longer than I can remember. I certainly have no idea what they do, but it's been okay (I think ). Any benefit to changing to -uf -dbgc?
I also have it running daily. Fortunately, there's no HTPC union.
Michael
Did you really need to quote that entire post in your reply?
Welcome to AVS - Get out while you still can!
Don't guess, measure: https://www.avsforum.com/forum/91-au...l#post22789786
LastButNotLeast is offline
post #782 of 944 Old 07-25-2017, 02:34 AM
bmcn's Avatar
Quoted: 2202 Post(s)
Liked: 3102
Originally Posted by glorpsd View Post
...That had no effect on...lineup configuration and did not require any set up again in WMC.
Updated epg123 to v.10 last evening by installing it over previous version. The complete lineups carried over without any check marks.
bmcn is offline
post #783 of 944 Old 07-27-2017, 06:33 AM
JHBrandt's Avatar
Quoted: 2718 Post(s)
Liked: 1335
Michael
I don't know what those options do, but if they're working for you, great! Thanks for sharing; it may help someone.
I only use mcupdate with the -uf -dbgc options when my guide gets "stuck." It happens sometimes after an outage. I use two guide sources: OTA and Dish Network channels. When Microsoft fixes the guide after an outage, sometimes everything starts working, but other times only the channels with Dish guide data start working again. The ones with OTA guide data don't start updating until I do that command. Then they're fine (until the next outage, of course).
BTW, the reason I use Dish Network guides for some channels is that Rovi's OTA channel guide is either missing or has only generic data for a few of my OTA channels. The Dish guides seem to have most of the missing channels (often on wildly different channel numbers), so I use Dish's guides to fill in the gaps via the Guidetool utility.
JHBrandt is offline
post #784 of 944 Old 08-06-2017, 07:02 PM
olyteddy's Avatar
Quoted: 537 Post(s)
Liked: 943
I bought the subscription to Schedules Direct and installed EPG123. It worked OK but I must say there are a lot of generic descriptions. Rovi is (generally) more up to date on talk show guests. I also get a lot of generics on Ion TV. Am I doing something wrong? Most of the rest of this thread implies that Schedules Direct is a better guide. I find it more reliable but prefer the detail level of Rovi.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #785 of 944 Old 08-06-2017, 07:15 PM
JHBrandt's Avatar
Liked: 1335
I don't have an answer, but you might read through the EPG123 subforum at thegreenbutton.tv and see if someone there has run into that problem: http://www.thegreenbutton.tv/forums/viewforum.php?f=99
BTW, I often complain about generic descriptions in the Rovi guide, particularly for the "out" week. So I guess YMMV
JHBrandt is offline
post #786 of 944 Old 08-07-2017, 05:52 PM
lfox's Avatar
Quoted: 13 Post(s)
I switched to EPG123 during the last data outage. I like it and find more detail for sporting events, particularly Auto Racing. Rovi treats most motor racing as a single series. Try to record a particular series and you are going to get 30 recordings a week including replays of everything from swamp buggies to off road dirt racing. I like sports car racing. The Zap2it data distinguishes different racing series. The only exception seems to be on CBS Sports Channel where lots of things are called Auto Racing.
dj4monie likes this.
lfox is offline
post #787 of 944 Old 08-17-2017, 12:45 PM
Krispy Kritter's Avatar
Quoted: 59 Post(s)
Liked: 27
I did the same thing, and noticed that as well. Much more helpful.
Krispy Kritter is offline
post #788 of 944 Old 08-21-2017, 08:58 AM
rkulagow's Avatar
I work for Schedules Direct. If you're having issues with generic descriptions, please open a ticket at our Schedules Direct website, so that we can determine if the issue is with our upstream data.
olyteddy and roknrol like this.
rkulagow is offline
post #789 of 944 Old 11-09-2017, 04:35 PM
aab1's Avatar
Quoted: 60 Post(s)
I'm quite pissed as I just found WMC is deleting recordings to make space for new ones when I'm sure I told it it was strictly forbidden from ever doing that.
Why is WMC deleting my recordings despite being told not to and how do I make sure it NEVER happens again? I'd much rather miss a future recording due to lack of space than have an old one deleted, at least that way I know what I'm missing and not having random recordings deleted without my knowledge.
The only reason I caught it, and then realized it's been going on for over a week, is that my disk space went up by itself.
Edit: I just noticed the setting had in fact reverted to "Delete stuff when space is needed" (whatever the right wording is), is it each time Rovi crashes and I have to reset my TV settings that this gets reset? If so then I need to use that monthly fee program to eliminate Rovi now. Can someone provide the info again and is this service available in Canada?
Thank you
aab1 is offline
post #790 of 944 Old 11-09-2017, 05:32 PM
perpetual98's Avatar
Quoted: 94 Post(s)
Liked: 52
epg123 is the software that a lot of people use, although I can't attest to it working in Canada. I assume it will, but don't quote me.
perpetual98 is offline
post #791 of 944 Old 11-09-2017, 06:28 PM
JHBrandt's Avatar
Liked: 1335
Thank you
Micro$oft has had terrible trouble keeping the EPG current lately, but you shouldn't need to reset everything to get it back. Run (as administrator) the following command, and it will always force WMC to download the latest guide without wiping out any of your settings:
C:\Windows\ehome\mcupdate.exe -uf
The command will return immediately but actually runs in background, taking the usual amount of time (about 10 minutes for me). If that doesn't work, then Micro$oft simply has no new guide data for you, and you'll just have to wait for them to fix it. They've run almost down to zero twice in the last month.
As for that "monthly fee program," it's actually an annual fee of $25/year (or you can pay $6 every other month) to Schedules Direct. (The program itself, called EPG123, is free, but you have to pay for the data.) It does give you 21 days of guide data, and a lot of folks (but not everyone) seem to like it better.
perpetual98 likes this.
JHBrandt is offline
post #792 of 944 Old 11-13-2017, 04:14 AM
dj4monie's Avatar
Quoted: 40 Post(s)
Liked: 26
That was a constant source of frustration with Rovi as well. Since Fox Sports 1/2 show both Weather Tech and World Endurance Championship I would know when I came on anyway but as you said it was a catch all for everything... Where have you seen swap buggy races? Must be CBS-SN or the Lucas Oil hour on NBC-SN I believe I've seen it there.
I hadn't seen it really since Diamond P/TNN went belly up.
A. Thomas
PSN - DJFourMoney
dj4monie is offline
post #793 of 944 Old 11-20-2017, 03:34 PM
aab1's Avatar
Quoted: 60 Post(s)
I tried that command but I don't think we're referring to the same guide data problem. The problem I've had every few weeks since they switched to Rovi is that my channel numbers all get mixed up. For example everything still appears with the correct number in the WMC guide, but going to channel 702 might put the box on 433, going to channel 600 might put the box on 89, etc. There is no logic, every channel just tunes to a seemingly random number (though each channel always tunes to the same wrong channel).
Is there a solution for this channel mixup issue? I've missed countless shows because of this.
aab1 is offline
post #794 of 944 Old 11-21-2017, 11:46 AM
TornadoTJ's Avatar
Quoted: 1933 Post(s)
Liked: 624
http://epg123.garyan2.net/
EPG 123 comes to mind...
TornadoTJ is offline
post #795 of 944 Old 11-21-2017, 12:31 PM
Ken.F's Avatar
Quoted: 2214 Post(s)
Liked: 2420
...but going to channel 702 might put the box on 433, going to channel 600 might put the box on 89, etc.
Are you using WMC to change the channels on a cable box?
Ken.F is offline
post #796 of 944 Old 11-21-2017, 10:58 PM
Worf's Avatar
Quoted: 795 Post(s)
Liked: 514
When I have that problem, i redo the tv setup. That refreshes the channel maps and gets it changing properly. Sometimes it happens and I don't notice it, other times it causes bad recordings.
This is especially true if you have an hauppage HD-PVR.
Worf is offline
post #797 of 944 Old 11-22-2017, 05:57 AM
JHBrandt's Avatar
Liked: 1335
I've never experienced that problem so I don't know, but you might try running the ObjectStoreRecoveryTask in the task scheduler next time it happens and see if that fixes it. That task is a bit more extensive than "mcupdate.exe -uf" but usually not as drastic as rerunning setup.
JHBrandt is offline
post #798 of 944 Old 01-26-2018, 02:16 PM
Ken.F's Avatar
Liked: 2420
Anybody know the correct procedure for updating EPG123 to the latest version? Do I need to uninstall then re-install or do I just run the new install program without uninstalling the old one? I don't want to register over at TGB forum just to ask a stupid question when everyone here already knows how dumb I am.
Sammy2 likes this.
Ken.F is offline
post #799 of 944 Old 01-26-2018, 02:23 PM
Sammy2's Avatar
Quoted: 1016 Post(s)
Liked: 342
What version are you running right now?
Sent from my SM-G930P using Tapatalk
Sammy2 is offline
post #800 of 944 Old 01-26-2018, 02:26 PM
Sammy2's Avatar
Liked: 342
http://www.thegreenbutton.tv/forums/...124925#p124925
Sammy2 is offline
post #801 of 944 Old 01-26-2018, 02:27 PM
Ken.F's Avatar
Liked: 2420
Originally Posted by sammy2 View Post
what version are you running right now?
1.1.18
Ken.F is offline
post #802 of 944 Old 01-26-2018, 02:30 PM
Sammy2's Avatar
Liked: 342
1.1.18
Just install I believe.
Sammy2 is offline
post #803 of 944 Old 01-26-2018, 02:34 PM
Ken.F's Avatar
Liked: 2420
Ken.F is offline
post #804 of 944 Old 01-27-2018, 09:02 AM
grittree's Avatar
Quoted: 444 Post(s)
Liked: 270
I'm still at v1.0.2. Works perfectly. Am I missing something?
grittree is offline
post #805 of 944 Old 01-27-2018, 10:01 AM
Ken.F's Avatar
Liked: 2420
It has a bunch of new WMC tweaks.
grittree likes this.
Ken.F is offline
post #806 of 944 Old 01-27-2018, 10:04 AM
captain_video's Avatar
Quoted: 689 Post(s)
Liked: 415
You don't need to register at TGB to get the answer. There's a separate sub-forum that discusses EPG123. Check the link at the top of the page for the setup guide. There's another one for the EPG123 website where you can download the latest version (currently 1.1.19). The instructions tell you how to upgrade from an older version. Just follow the procedure for the Clean Start and you'll be fine.
captain_video is offline
post #807 of 944 Old 01-27-2018, 10:57 AM
Ken.F's Avatar
Liked: 2420
Thanks, but I still can't find those instructions that tell you how to upgrade from an older version of EPG123. It's not in the pdf manual and I couldn't find it posted at TGB. I installed over top of the previous version this morning and everything seems to be working.
Ken.F is offline
post #808 of 944 Old 01-27-2018, 11:09 AM
Quoted: 689 Post(s)
Liked: 415
You did it the correct way. There used to be an interim procedure for upgrading from an older version to one of the more current ones, but the process is now automated and included with the current installers. I thought the interim instructions were still included in the pdf file but apparently they have been removed as they are no longer required. Just run the setup executable and it will update the necessary files and perform the necessary background operations to bring it up to date. The author has done a great job adding new and better features to EPG123.
Ken.F likes this.
post #809 of 944 Old 01-27-2018, 10:43 PM
Sammy2's Avatar
Liked: 342
How'd it go?
Quite a lot actually!
Sammy2 is offline
post #810 of 944 Old 01-28-2018, 03:44 AM
Ken.F's Avatar
Liked: 2420
How'd it go?
OK I guess. The guide updated last night so I must have done something right. My guide data runs out on some channels on 2/16 (19 days) with it set to download 21 days worth. I'll have to keep an eye on those channels for a few days to make sure they get new guide data as it becomes available.
Sammy2 likes this.
Ken.F is offline
Reply Home Theater Computers
