madVR Player Support Thread - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 154Likes
post #331 of 1099 Old 10-18-2018, 08:45 AM
mkohman's Avatar
Quoted: 398 Post(s)
Liked: 340
Originally Posted by Onkyoman View Post
As huhn said, you can't stretch 16:9 horizontally to fill a 2.39:1 screen without destroying the aspect ratio of the source. If you stretch it horizontally, it also has to get taller or the image won't be 1:1 anymore.
Thank you for your help.. Any advise on how this is achieved please? Thank you..
Sent from my moto g(6) using Tapatalk
mkohman is offline
post #332 of 1099 Old 10-18-2018, 10:02 AM - Thread Starter
Onkyoman's Avatar
Quoted: 929 Post(s)
Liked: 575
You can't do it. The 16:9 image would be taller than your screen if you stretched it 1:1. The only way is to flatten the image by pulling it sideways. That is essentially what the Lumagen is doing.
mkohman likes this.
Onkyoman is offline
post #333 of 1099 Old 10-18-2018, 12:39 PM
mkohman's Avatar
Quoted: 398 Post(s)
Liked: 340
Thanks.. So in other words it can only be done by a Lumagen..
mkohman is offline
post #334 of 1099 Old 10-18-2018, 01:34 PM
Jish9's Avatar
Quoted: 276 Post(s)
Liked: 106
Does anyone know if KODI DS can be used in stable 64bit mode, or should we stick with 32bit? I'm asking as Win10 is 64bit and can't run 32bit programs. I am testing MADVR now on an existing computer but running into issues. Trying to determine whether software or hardware issues. Will update the system config and what I'm seeing.
Jish9 is offline
post #335 of 1099 Old 10-18-2018, 07:53 PM
mightyhuhn's Avatar
Quoted: 1157 Post(s)
Liked: 423
win 64 can run 32 bit program. 64 bit operation systems have a clear advanced for running 32 bit software.
@mkohman no you can't stretch an image without stretching it. the lumangen is just stretching it the only "special part of it" is doing it non linear which will look horrible in a panning shoot.
and i can't tell you how to stretch with madVR without knowing the exact setup and how the image is handled in by the end device.
mkohman likes this.
mightyhuhn is online now
post #336 of 1099 Old 10-20-2018, 12:21 AM
Mrkazador's Avatar
Quoted: 308 Post(s)
Liked: 428
You can stretch the video to fill the screen with MPC-HC by using the "stretch to window" option. There are a bunch of other scaling options but I've never used them.
mkohman likes this.
Mrkazador is offline
post #337 of 1099 Old 10-21-2018, 10:27 AM
Liked: 0
Hi guys, I need the expert's advice again.
My Nvidia GT1030 - doesnt support 3D vision - I bought RF glasses for my projector - does that mean I cant play SBS,3D, etc... ? Because the GT 1030 doesnt show me 3D stereoscopic option while my AMD did show.
So embarrassing I bought this and was sure its gonna work
Spark7 is offline
post #338 of 1099 Old 10-21-2018, 11:58 AM
mightyhuhn's Avatar
Liked: 423
looks like nvidia doesn't support it.
you can try some registry changes so the option maybe available or look out for the 3d option in windows it self you fidn it under display.
i still wonder why nvidia goes this far to really remove it.
post #339 of 1099 Old 10-21-2018, 12:00 PM
Liked: 0
Any idea on how to do that registery change ? I didnt know stuff like that are possible.
I tried the windows option it doesn't actually shows up anywhere.
Spark7 is offline
post #340 of 1099 Old 10-21-2018, 12:25 PM
mightyhuhn's Avatar
Liked: 423
this is an advanced topic and there where always registry entry to change/add/remove nvidia control panel settings.
this was done in the past to unlock there overclocking page.
i know there is an registry entry to lie to the GPU driver that there is an nvidia 3d vision kit present for lightboost.
the closest to a 3d registry entry i found is this one Computer\HKEY_CURRENT_USER\Software\NVIDIA Corporation\NVControlPanel2\RegisteredServers\Ster eoVisionServer
and that for sure will not help you.
post #341 of 1099 Old 10-21-2018, 05:38 PM
fitbrit's Avatar
Quoted: 74 Post(s)
Liked: 59
For side-by-side and over-under 3D you'll be fine. You will just have to put your projector or TV into manual 3D mode to interpret the signal correctly. You just won't be able to do frame-packed mvc 3D
fitbrit is offline
post #342 of 1099 Old 10-21-2018, 06:51 PM
Liked: 0
oh ok! Thanks ill try.
So what settings do I use in madvr/mpc so that it plays Side by side correctly ?
Spark7 is offline
post #343 of 1099 Old 10-21-2018, 07:49 PM
fitbrit's Avatar
Quoted: 74 Post(s)
Liked: 59
There is no setting. You want the PC to play the file as is - then tell your display device to process the signal in the correct way. So you will see a side-by-side image, for example, until you activate the 3D processing and then the two images will be combined and stretched horizontally to make one 3D image. Again, that processing is done by the display device, not the renderer.
fitbrit is offline
post #344 of 1099 Old 10-21-2018, 07:54 PM
Liked: 0
Thank you so much i got it - needed to drop resolution to get that 3D manual mode to work.
Can MPC change resolutions with shortcuts? is that what that fullscreen list is about?
Spark7 is offline
post #345 of 1099 Old 10-22-2018, 01:18 AM
mightyhuhn's Avatar
Liked: 423
if you are fine with using 3d this way is your device passive 3D by any chance?
post #346 of 1099 Old 10-22-2018, 09:41 AM
Liked: 0
Im not sure.
its an epson tw-9300 Projector - the glasses are RF active glasses.
my issue now is that regular 4k movies need to have different settings in MPC for resolution - I need 4k 24hz for the regular movies and 1080i for the 3D - currently I manually change it from the options menu.\
Btw can I play AVC or is it the same as MVC ?
Spark7 is offline
post #347 of 1099 Old 10-23-2018, 05:57 AM
mightyhuhn's Avatar
Liked: 423
that's active 3D in my book and that means sending side by side will throw half the resolution away.
AVC is used as a name for h264 or better is a part of the really long full name of h264.
MVC stand for multi view coding and is used like this in h264 for 3D and multi view point encoding. so they are not the same.
i guess you can play these files fine. for 3D madVR only supports MVC encodes.
post #348 of 1099 Old 10-23-2018, 07:11 AM
Quoted: 175 Post(s)
Liked: 60
Im not sure.
For MVC playback (disc/image/ripped) via MPC HC/BE ( and others) you need to follow this guide: https://forum.kodi.tv/showthread.php...287#pid2616287
I see there are some image improvement options present in both processing - image enhancements and scaling algorithms - upscaling refinement.
What is the difference between them?
noob00224 is online now
post #349 of 1099 Old 10-23-2018, 07:26 AM
Liked: 0
I was told I cant play MVC due to having a GT 1030 which does not support 3d vision.
That guide seems useful I just cant figure out how to make it work for my needs: Changing the resolution in MPC Options>Fullscreen - to fit the movie that is playing.
I watch 4kHDR and 3D movies so I need to change between 1080i 25hz and 2160p 24hz, so that I can set the projector to manual 3D .
Spark7 is offline
post #350 of 1099 Old 10-23-2018, 07:28 AM - Thread Starter
Onkyoman's Avatar
Quoted: 929 Post(s)
Liked: 575
Image enhancements are added pre-resize. Upscaling refinement is added post-resize.
The first should be used with native content (e.g. 4K UHD at 4K). The second should be used after upscaling.
Onkyoman is offline
post #351 of 1099 Old 10-23-2018, 08:26 AM
Quoted: 175 Post(s)
Liked: 60
That card does not seem to support 3d vision, but you can still play the disc in frame packing via a separate blu ray player. You can also rip it at maximum quality HSBS.
I haven't used the internal MPC resolution/refresh rate switcher. Madvr itself has a feature that switches to the resolution and refresh rate of the video file (assuming the display supports it). Madvr - devices - your device name - display modes. For interlaced video some displays get confused, so you should try it with 25i and 50i (30i/60i) when adding it to the list . Details of how to do that here in the middle of the post: https://www.avsforum.com/forum/26-ho...l#post20886682
@Onkyoman so what happens if you have the options in the processing - image enhancements selected prior to upscaling? Does it affect performance or the upscaling process in a negative way?
LE: I think I found the answer: Image enhancements are not recommended for content that needs to be upscaled. Pre-resize sharpening will show a stronger effect than sharpening applied after resize like that under upscaling refinement. In many cases, this will lead to an image that is oversharpened and less natural in appearance.
@mightyhuhn If you send an interlaced video to madvr does it not deinterlace it via the feature included?
I vaguely remeber having an [email protected] file and the PJ would jump into that mode (25i or 50i),. The picture looked fine. I don't recall the other settings though.
post #352 of 1099 Old 10-23-2018, 09:50 AM
mightyhuhn's Avatar
Liked: 423
madVR can't output interlanced video properly.
you should deinterlance it or with other words you should not send interlanced if you have an alternative.
post #353 of 1099 Old 10-23-2018, 10:55 AM
brazen1's Avatar
Quoted: 578 Post(s)
Liked: 330
The guide links to madVR settings pictures here https://imgur.com/a/4h7U0#KJ179vR
In the fourth picture down, you will see how to enter 2160p23, 2160p24, 2160p25, 2160p30, 2160p50, 2160p59, 2160p60 into madVR setting.
You do NOT want to use MPC to control refresh rates. You want madVR to control them.
Yes, you want to use 2160p30 AND 2160p60 AND the 50 and the 25 even though they are multiples provided your display switches to all of them when appropriate.
I've no idea how you ripped your 3D but normally it is always 1080p24. The GPU driver controls this resolution and frame rate change, not madVR or anything else. If your driver and your O/S display properties does not offer stereoscopic, I don't think it matters for SBS or TAB video. These are really just (2) 2D frames and not 3D like frame packed MVC. But, with SBS or TAB at best you will only see half resolution to each eye afaik.
noob00224 likes this.
HOW TO - Kodi 2D - 3D - UHD (4k) HDR Guide Internal & External Players
W10 1903 / MPC-BE\HC / PotPlayer / PowerDVD 19 / DVDFab Player 3 / KODI 19 videoplayer
GTX960 4GB / RGB Full 4:4:4 / 8bit Desktop mode =60Hz / 10/12bit Video mode = Matched Refresh rates IE 23,24,25,60Hz
65JS8500 UHD HDR 3D / Denon S720W
brazen1 is offline
post #354 of 1099 Old 10-23-2018, 01:41 PM
Quoted: 175 Post(s)
Liked: 60
I did some tests with SD material, and there was a diference between where the filters where applied.
However, I have more questions.
Once a filter is selected in the scaling algorithms - upscaling refinement page, on the bottom there are 2 options available, one of which must always be selected:
refine the image after every ~2x upscaling step
refine the image only once after upscaling is complete
This thread (https://forum.kodi.tv/showthread.php...23175&page=280) explains them as the following:
Sharpening is applied after every 2x resize.
Sharpening is applied after resize is complete.
I'm confused as to why the sharpening filter would be applied before the process was complete, and which would be the better option (using NGU AA for upscale, no SuperRes).
post #355 of 1099 Old 10-23-2018, 03:50 PM - Thread Starter
Onkyoman's Avatar
Quoted: 929 Post(s)
Liked: 575
Refine after every 2x step can make the image sharper and more detailed at the expense of poorer performance. I've never tested it, so I don't know if you'd actually notice the difference.
Onkyoman is offline
post #356 of 1099 Old 10-24-2018, 09:39 AM
grendelrt's Avatar
Quoted: 557 Post(s)
Liked: 293
I have a weird issue in MADVR through MPC-HC. I am only having lip sync issues when playing back frame packed 3D. These used to play fine with no issues, 2D still plays fine with no delays at the same resolution and refresh. I have tried using the internal audio renderer (with the sync enabled and disabled) and external lav. I saw you can change the MS delay based on the fullscreen mode, but that would affect 2D as well I believe. The audio is early from my testing. The render time is around 10ms, so I dont think its related to that, not sure why it would only affect 3D , I tried resetting back to stock settings with no change.
grendelrt is offline
post #357 of 1099 Old 10-25-2018, 01:25 AM
the_jaguar's Avatar
Quoted: 156 Post(s)
Liked: 50
I am in the process of choosing the best media player that has madvr support - jriver, kodi DSPlayer, MPC, MP1 are the main players is what I have gathered after a bunch of reading up.
I am a fairly advanced user of Kodi on my Shield, so I am quite well versed with this platform, but given that DSPlayer is supported by 1 person with no guarantee of further maintenance and the fact that it doesn't work with Kodi 18 is a bit troubling.
I have never used any of the remaining players, so would love to hear your thoughts on what's the best option. Please suggest.
the_jaguar is offline
post #358 of 1099 Old 10-25-2018, 08:01 AM - Thread Starter
Onkyoman's Avatar
Quoted: 929 Post(s)
Liked: 575
Start by trying another media player. Also, audio sync delays set during playback only affect the current video.
Onkyoman is offline
post #359 of 1099 Old 10-25-2018, 08:03 AM - Thread Starter
Onkyoman's Avatar
Quoted: 929 Post(s)
Liked: 575
I would suggest trying all of them. Even JRiver has a free trial. You can use core Kodi with an external media player such as Media Player Classic. The experience isn't as satisfying, but it is another option.
Onkyoman is offline
post #360 of 1099 Old 10-25-2018, 08:28 AM
the_jaguar's Avatar
Quoted: 156 Post(s)
Liked: 50
Got it - I will try and test all of them. If you don't mind me asking, what do you use and why?
Reply Home Theater Computers
