madVR Player Support Thread - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 146Likes
post #811 of 1032 Old 04-08-2019, 04:40 PM
brazen1's Avatar
Quoted: 567 Post(s)
Liked: 327
Originally Posted by Colozeus View Post
I have match frame configured in madvr and mpc.
Imo, I think that's your problem. Try madVR only and using 2160p23, 2160p24, 2160p25, 2160p30, 2160p50, 2160p59, 2160p60.
HOW TO - Kodi 2D - 3D - UHD (4k) HDR Guide Internal & External Players
W10 1903 / MPC-BE\HC / PotPlayer / PowerDVD 19 / DVDFab Player 3 / KODI 19 videoplayer
GTX960 4GB / RGB Full 4:4:4 / 8bit Desktop mode =60Hz / 10/12bit Video mode = Matched Refresh rates IE 23,24,25,60Hz
65JS8500 UHD HDR 3D / Denon S720W
brazen1 is offline
post #812 of 1032 Old 04-11-2019, 01:15 PM
Quoted: 227 Post(s)
Liked: 108
I tried a bunch of things and i still can't nail this down. I think the main issue here has to do with clocking. It looks like the 2080 isn't outputting a true 24p signal, 23.976hz. I even tried creating a custom resolution for 23hz with 23.976 and that does not appear to help. Going back and forth on the same scenes comparing my shield tv and htpc playback, the shield's playback is smoother with less judder. I have read of possibly using reclock to fix audio and video clock speed differences, but i would then lose the ability to bitstream.
Surely some of you have dealt with this before.
I'm wondering if unraid's hypervisor is somehow messing with the clocks.
Colozeus is offline
post #813 of 1032 Old 04-11-2019, 01:48 PM
mightyhuhn's Avatar
Quoted: 1137 Post(s)
Liked: 414
clock issue would give you issues every couple minutes not the whole time so can you make a screen of the OSD (control+j)
mightyhuhn is online now
post #814 of 1032 Old 04-11-2019, 05:05 PM
Quoted: 227 Post(s)
Liked: 108
I think the issue is the composition rate being different than source?
Colozeus is offline
post #815 of 1032 Old 04-11-2019, 05:13 PM
markmon1's Avatar
Quoted: 4413 Post(s)
Liked: 2764
Ok, so i updated the lav filters and selected d3d 11. Wow what a difference in color saturation. Coco looked dull before and now it's very colorful. However, i've noticed an issue with smooth playback, especially with coco, playback is more juttery when compared to say my shield tv. I have match frame configured in madvr and mpc. In madvr i have 2160p23 and 24 (etc configured). I'm thinking this has something to do with windows and how it handles 23 and 24p playback as my initial research suggests.
I'm going to try removing 23 as an option and report back.
Also, i'm not using any motion enhance settings on my rs3000
Does it show frames being dropped in the ctrl+j screen?
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #816 of 1032 Old 04-11-2019, 05:43 PM
mightyhuhn's Avatar
Liked: 414
that's a composition rate mismatch the win 10 special. a fix for that is windows 8. newer GPU driver with newer windows 10 version and some hope.
try d3d9 overlay (windows 7 overlay make sure FSE and d3d11 are not checked) as a test it is the only surface that can ignore the composition rate on win 10 there is another trick you could try later that give you the old FSE back but i don't have the best experience with this trick on win 10.
post #817 of 1032 Old 04-11-2019, 06:58 PM
Quoted: 227 Post(s)
Liked: 108
Tried that. Still the same. Also tried playing around with vsync settings and also rolled back drivers to a previous cersion as suggested in another thread. No dice. It did manage to fix the composition mismatxh but thats about it.
@markmon i dont have dropped frames unless i pause or resize the window. Then i get a few dropped frames while playback resumes.
Colozeus is offline
post #818 of 1032 Old 04-11-2019, 07:02 PM
mightyhuhn's Avatar
Liked: 414
can you make me a screen with overlay.
and with overly it's more important if playback works properly not if it still shows a composition rate overlay ignore it it is not displaying anything there it's just a "black" screen the GPU driver later adds the image.
post #819 of 1032 Old 04-11-2019, 07:03 PM
Quoted: 227 Post(s)
Liked: 108
Also tried vsync on and windowed mode only...
I’m thinking i might try swapping my 1080ti into this box to see if it behaves differently.
Colozeus is offline
post #820 of 1032 Old 04-11-2019, 07:34 PM
markmon1's Avatar
Liked: 2764
I’m thinking i might try seapping my 1080ti into this box to see if it behaves differently.
I run windows 10, GTX 1080TI, and driver 390.65. I have none of these issues. So if you roll back to those 3 things and still have the same issue without high rendering times or dropped frames, you know it's something else. I use 390.65 because it allows Ansel in any game (freestyle effects).
markmon1 is offline
post #821 of 1032 Old 04-12-2019, 03:42 AM
mightyhuhn's Avatar
Liked: 414
how the hell should he use a driver that's older then his card :-)
@Colozeus
any reason you can't test overlay?
post #822 of 1032 Old 04-12-2019, 05:58 AM
markmon1's Avatar
Liked: 2764
@Colozeus
He just said he was going to put a GTX 1080TI into that machine. So that driver is a good recommendation for his 1080TI. That's how
markmon1 is offline
post #823 of 1032 Old 04-12-2019, 07:26 AM
Quoted: 227 Post(s)
Liked: 108
@Colozeus
I can. How exactly do i test overlay? (I just woke up and not firing on all cylinders yet. ) :-P i will try my 1080 ti as a last resort today
Colozeus is offline
post #824 of 1032 Old 04-12-2019, 09:32 AM
Quoted: 227 Post(s)
Liked: 108
Colozeus is offline
post #825 of 1032 Old 04-12-2019, 10:31 AM
Quoted: 227 Post(s)
Liked: 108
Shouldn't it say d3d11 overlay?
Also, i tried CMD low on the projector and it pretty much cures it. I can live with that even though i didn't want to have to deal with audio delay stuff. I think i'll still try the 1080ti later today.
Colozeus is offline
post #826 of 1032 Old 04-12-2019, 10:42 AM
jbarteli's Avatar
Quoted: 191 Post(s)
Liked: 43
Question, I'm using dxva2 (copyback) but want to use D3D11 native because its less heavy on my CPU. But when I select that kodi won't play in exclusive mode and my auto ratio for my JVC stops working?? Is this correct or am I doing something wrong?
jbarteli is offline
post #827 of 1032 Old 04-13-2019, 06:10 AM - Thread Starter
Onkyoman's Avatar
Quoted: 893 Post(s)
Liked: 547
CPU usage shouldn't differ much between the two, but black bar detection is not yet supported by D3D11 Native.
There is a tutorial on configuring LAV Filters here:
https://forum.kodi.tv/showthread.php...541#pid1843541
Onkyoman is offline
post #828 of 1032 Old 04-13-2019, 06:14 AM - Thread Starter
Onkyoman's Avatar
Quoted: 893 Post(s)
Liked: 547
What do these 24p judder tests look like when played:
https://drive.google.com/drive/folde...prM_dindje9fMB
The moving bars in these videos should connect with the sound played to indicate proper 24p cadence. Do they also look fairly smooth?
Onkyoman is offline
post #829 of 1032 Old 04-13-2019, 06:18 AM
markmon1's Avatar
Liked: 2764
Spoiler!
Here is my general screen settings. It's way different than yours. Again this is a 1080TI but I'm having nothing but smooth playback.
Also, you're using MPC-BE not MPC-HC right? MPC-BE seems to fix stutter for tons of people for some reason. (I use zoom player)
riddle likes this.
markmon1 is offline
post #830 of 1032 Old 04-13-2019, 05:37 PM
Quoted: 227 Post(s)
Liked: 108
They look fairly juddery to me. At lot less so when played back from the shield. I also tried mpc-be and i didn't notice any improvement. I think i'll just stick with using mpc low on the jvc since it restores motion without adding any artifacts that i can see. I just watched mary queen of the scots with these settings and it worked fine. I think this is an issue with the 2080 not being able to properly do 23.9 correctly.
Colozeus is offline
post #831 of 1032 Old 04-14-2019, 11:33 AM
hotrippr's Avatar
Quoted: 73 Post(s)
Liked: 33
Could you humor me for a sec and go to windows power options and set it to power saver? It should slow your system noticably. Run a video in mpc like youve been trying to (it will take longer to get going) and let me know if you notice any difference.
Sony X720E
Yamaha RX-V379 5.1 - Klipsch RF3 & RC3 - Boston VR500W Sub - CR4 for rears
Gigabyte Gaming OC RTX2070 - 4790K i7 - 2x8GB Gskill Ripjaws X
970EVO 512GB NvMe
EVGA Supernova G2 750 80+Gold
hotrippr is offline
post #832 of 1032 Old 04-15-2019, 03:25 AM
NM20's Avatar
Quoted: 14 Post(s)
I have been trying to get the settings correct to tone map with Mad VR and my JVC X7500. I just want to be sure the settings I have are correct.
I have MAD VR and Nvidia settings at 0 - 255 and LAV on 16-235. Is this correct?
I have my JVC on Gamma 2.2, colour profile BT2020, colour temp HDR 6500k.
Nvidia settings are 12bit, RGB, with the latest drivers.
I have MAD VR calibration on DCI-P3 and Gamma Power Curve 2.4. I am not using any LUT files (I don't know how)
I have had my projector professionally calibrated for SDR and HDR, but since then have discovered MAD VR tone mapping.
The only issue I have come across is in the latest Mission Impossible in 4K, I got horizontal banding on the iMAX scenes towards the end. This happened in the sky mainly.
When looking at the MPC status, it says D3D11 Fullscreen Windowed (8 bit) should that not be 10 bit? Or is there anything else wrong with these settings?
I just want to make sure I am maximising the capability of my system.
Name:	MPC Settings.png
ID:	2553118   Click image for larger version
Name:	Mad VR Levels.png
NM20 is offline
post #833 of 1032 Old 04-15-2019, 07:02 PM
Quoted: 227 Post(s)
Liked: 108
@hotrippr @markmon quick update. I just ddu uninstalled my nvidia drivers and reinstalled 418.91. Stutter is now gone. I initially had installed 419.35 first, which some say has no stutter issues, before installing 418.91. but not using DDU. DDU appears to have done the trick + enabling vsync in driver menus.
So, if anyone else is having judder issues with a rtx card, use 418.91. Worth mentioning that i also did not install geforce experience. I'm a happy camper now and this should hold me over until madvr envy becomes available.
markmon1 likes this.
Colozeus is offline
post #834 of 1032 Old 04-15-2019, 08:30 PM
hotrippr's Avatar
Quoted: 73 Post(s)
Liked: 33
Going on 24hrs without issue on 425.31. I also have tried many different drivers and used DDU, the issue would always return, 425.31 included. But for me I believe it is power related. I reseated the gpu and noticed also that the ECO mode switch on my PSU was in between the on and off positions so I gave it a nudge all the way over and now seems all is good. Either position worked but it didnt like being in the middle of the switch throw. What led me to this conclusion was setting windows power setting to Power saver, with power saver it took load out of the system and would get smooth playback vs Balanced or High Performance gave me lag/stutter. So power/heat was giving me issue. Long story short I believe my PSU fan wasnt spinning at all. Hopefully, it doesnt come back.
Colozeus likes this.
Sony X720E
970EVO 512GB NvMe
hotrippr is offline
post #835 of 1032 Old 04-16-2019, 11:02 AM
Flavio61's Avatar
Hello,
I'm trying to use the HDR file measurement function. After dragging the .mkv file onto MadMeasureHDR.exe the window opens and I have the message "Measuring video file ....." but the measurement does not start, I only see the blinking cursor but no measurement percentage count. Where am I doing wrong? Thank you.
Flavio61 is offline
post #836 of 1032 Old 04-16-2019, 04:19 PM - Thread Starter
Onkyoman's Avatar
Quoted: 893 Post(s)
Liked: 547
Try it again. It sometimes hangs on the first attempt.
Onkyoman is offline
post #837 of 1032 Old 04-16-2019, 05:40 PM
hotrippr's Avatar
Quoted: 73 Post(s)
Liked: 33
So frustrated. My stutter is back again.From what I can tell its mostly apparent with 24fps/hz content/display mode. And what I cannot understand is why it does not stutter with windows power setting at power saver???
My options: 1. Turn off madvr display matching for 24hz
2. When I watch videos set power saver
3. Put my head through the wall (not preferred)
Sony X720E
970EVO 512GB NvMe
hotrippr is offline
post #838 of 1032 Old 04-17-2019, 05:08 AM - Thread Starter
Onkyoman's Avatar
Quoted: 893 Post(s)
Liked: 547
Are you certain that it is stutter? I've never found 24 fps playback perfectly smooth. Have you tried all of the recommended drivers in this thread:
https://forum.doom9.org/showthread.php?t=176013
Read the last post for a tip on what settings should be disabled in the Nvidia control panel.
neo_2009 likes this.
Onkyoman is offline
post #839 of 1032 Old 04-17-2019, 11:27 AM
neo_2009's Avatar
Quoted: 309 Post(s)
Liked: 223
Are you certain that it is stutter? I've never found 24 fps playback perfectly smooth...
I assume this occurs when the source file is exactly 24fps? This also happens to me, even with rendering times around 26-28ms. Basically i get 1 frame drop every 45s.
For files with 23.976fps, i get perfect playback.
neo_2009 is online now
post #840 of 1032 Old 04-17-2019, 11:40 AM
hotrippr's Avatar
Quoted: 73 Post(s)
Liked: 33
Thanks guys
No it is not the normal judder with 24fps content nor 23.9. It is annoying stutter. The exact same files play smoothly if windows power saver is selected.
And it happens only sometimes. Then goes away and comes back. I have tried selective startup to see if an app is conflicting but no dice.
So I am baffled.
Sony X720E
970EVO 512GB NvMe
hotrippr is offline
Reply Home Theater Computers
