madVR Player Support Thread - Page 47 - AVS Forum | Home Theater Discussions And Reviews
 219Likes
post #1381 of 1646 Old 10-16-2019, 04:48 PM
Quoted: 443 Post(s)
Liked: 133
Originally Posted by Sittler27 View Post
I moved to the last stable build (92.17 I believe) and notice it only accepts a minimum of 100 target nits to be entered, but my actual peak target nits is 72. Is it ok to leave it at 100?
That build does not allow targets lower than 100 nits.
The beta builds do. The latest that is usable for viewing is v.95:
https://www.avsforum.com/forum/24-di...l#post58662522
noob00224 is offline
post #1382 of 1646 Old 10-16-2019, 06:03 PM
Sittler27's Avatar
Quoted: 1354 Post(s)
Liked: 122
On my JVC NX9, I get 72 nits with DCI-P3 filter in place and 91 nits without it (HDR color still though).
Is 72 nits still considered worth it for tonemapping HDR?
Sittler27 is online now
post #1383 of 1646 Old 10-16-2019, 06:12 PM
Quoted: 443 Post(s)
Liked: 133
There are users with lower nits than that, that are using HDR tone mapping.
The higher nits value might satisfy more people, but it's up to user preference. Higher brightness and a smaller color gamut, or lower brightness and a larger color gamut.
post #1384 of 1646 Old 10-16-2019, 06:31 PM
Sittler27's Avatar
Liked: 122
Ok, I think I'll use the 72 nit one, since that's with filter so I get almost 100% of DCI-P3 coverage.
post #1385 of 1646 Old 10-16-2019, 06:37 PM
neo_2009's Avatar
Quoted: 354 Post(s)
Liked: 261
I was using NVIDIA 418.91 driver, and tried a few times to upgrade to newest versions with no success, stuttering was always present.
Due to some positive feedback on the latest driver (436.48), i decided to try it, and so far there has been no stuttering.
I'm also applying this NVIDIA driver slimming utility, as the regular NVIDIA distribution has so much garbage in it.
Moreover, i'm also applying this NVIDIA Profle Inspector tool with an optimized profile for MPC-HC/BE.
MMoser and the_jaguar like this.
neo_2009 is online now
post #1386 of 1646 Old 10-17-2019, 09:50 AM
Quoted: 25 Post(s)
Liked: 3
LAV Video
- NEW: Initial support for parsing HDR10+ (SMPTE ST 2094-40) metadata, and passing it to the video renderer
Latest Lav filter. Does that mean that it is up to MadVR to show HDR Plus or what does it exactly mean?
neo_2009 likes this.
HDRX is online now
post #1387 of 1646 Old 10-17-2019, 10:18 AM
neo_2009's Avatar
Quoted: 354 Post(s)
Liked: 261
Where did you get this information? I'm not seeing it on the oficial github page ...
post #1388 of 1646 Old 10-17-2019, 10:53 AM
Quoted: 25 Post(s)
Liked: 3
Scroll down to Changelog.
https://forum.doom9.org/showthread.php?t=156191
HDRX is online now
post #1389 of 1646 Old 10-17-2019, 10:57 AM
neo_2009's Avatar
Quoted: 354 Post(s)
Liked: 261
Thank you, this is from the latest oficial March build, i incorrectly assumed it was a new feature from the nightly builds
post #1390 of 1646 Old 10-18-2019, 11:41 AM
Sittler27's Avatar
Liked: 122
I upgraded to v95. Is there a list of setting values currently deemed best that I should be adjusting to?
post #1391 of 1646 Old 10-18-2019, 12:08 PM
Shepardos's Avatar
Quoted: 149 Post(s)
Originally Posted by Shepardos View Post
I found a long threat about the grounding loop issue and Nvidia Cards. The solution is to remove the ground at one side, using HDbaseT or an optical HDMI cable.
With HDBaseT I have not heard the noice, but now with a direct HDMI connection is there.
Sorry for the OFFTOPIC,, it is not related the MadVR!!!
Just to close this topic. Fibre Cable solved the annoying Nvidia GPU issue under load!!!!
Shepardos is online now
post #1392 of 1646 Old 10-18-2019, 12:13 PM
Quoted: 25 Post(s)
Liked: 3
Is v95 new version? Where did you find it?
HDRX is online now
post #1393 of 1646 Old 10-18-2019, 12:20 PM
Killroy's Avatar
Quoted: 585 Post(s)
Liked: 468
It's up to v101 now.
Look here for all the betas (last few pages): https://www.avsforum.com/forum/24-di...projector.html
Killroy is offline
post #1394 of 1646 Old 10-18-2019, 12:24 PM
kalhua's Avatar
Quoted: 46 Post(s)
That is great, am am glad to hear it. What cable did you buy?
kalhua is online now
post #1395 of 1646 Old 10-18-2019, 12:25 PM
Sittler27's Avatar
Liked: 122
Is there a recommended list of best settings based around all the testing on them and feedback?
post #1396 of 1646 Old 10-18-2019, 12:50 PM
Quoted: 25 Post(s)
Liked: 3
But thats is for Projectors. Right?
HDRX is online now
post #1397 of 1646 Old 10-18-2019, 04:14 PM - Thread Starter
Onkyoman's Avatar
Quoted: 1120 Post(s)
Liked: 660
No, not really. Posts like these are the best you can do in the meantime:
https://www.avsforum.com/forum/24-di...l#post58702226
There aren't that many testers and only a couple tend to share their settings.
noob00224 likes this.
Onkyoman is online now
post #1398 of 1646 Old 10-18-2019, 07:04 PM
Killroy's Avatar
Quoted: 585 Post(s)
Liked: 468
Look through that thread for the various setting samples but it will vary a lot due to different displays, screen size, etc. Take one, test it, adjust if needed.
Killroy is offline
post #1399 of 1646 Old 10-20-2019, 05:13 AM
Shepardos's Avatar
Quoted: 149 Post(s)
Does anybody has a guide, recommendation or validated settings for processing, scaling algorithms and rendering for nVidia GTX GPU’s?
post #1400 of 1646 Old 10-20-2019, 06:05 AM - Thread Starter
Onkyoman's Avatar
Liked: 660
Did you check the guides linked in the first post? The GPU brand doesn't matter as much as it's relative processing power.
post #1401 of 1646 Old 10-20-2019, 05:58 PM
Sittler27's Avatar
Liked: 122
Is it better to run Luma doubling at very high and Luma quadtripling at very high rather than high for both? I don't get any dropped frames switching to very high.
post #1402 of 1646 Old 10-21-2019, 03:44 AM - Thread Starter
Onkyoman's Avatar
Liked: 660
Yes, very high is better than high by a small margin. The first doubling step is more important than the second, though.
post #1403 of 1646 Old 10-22-2019, 07:59 PM
Sittler27's Avatar
Liked: 122
I've found recently after leaving Kodi on for a while that when I go play a file it doesn't start the audio stream. Only after a full reboot can I get it to work.
It seems like it started happening since I upgraded to latest madvr beta.
post #1404 of 1646 Old 10-23-2019, 03:09 AM - Thread Starter
Onkyoman's Avatar
Liked: 660
You should close and open Kodi again whenever you intend to use it. I use an AutoHotKey script to accomplish this by remote.
Are you putting the PC to sleep? This can also cause a loss of audio from the HDMI handshake that occurs when you wake the computer.
post #1405 of 1646 Old 10-23-2019, 04:52 AM
Quoted: 25 Post(s)
Liked: 3
What setting in HDR settings should i use for true/real HDR picture? I'm using Samsung Q90R QLED TV.
HDRX is online now
post #1406 of 1646 Old 10-23-2019, 06:04 AM - Thread Starter
Onkyoman's Avatar
Liked: 660
Try passthrough HDR to display.
If you are using v91+ of the current madVR beta builds, then tone map HDR using pixel shaders with output video in HDR format checked can bring some highlight detail back into the brightest highlights and is worth checking. Your display would only benefit with titles that are mastered very bright due to its high peak brightness.
To try pixel shaders, enter your estimated peak brightness and set highlight recovery strength to high, very high or are you nuts. You also have to uncheck some of the trade quality for performance checkboxes.
If you are using a build before that, including the latest official build, tone map HDR using pixel shaders with output video in HDR format checked is not working correctly and will cause some clipping of the highlights. A bug fix has been issued just recently.
post #1407 of 1646 Old 10-23-2019, 08:33 AM
whiteboy714's Avatar
Quoted: 1451 Post(s)
Liked: 598
Really? I like the idea of just leaving it open so that I never need to see windows. In the past with something like wmc this would always cause hdmi issues, or the window wouldn’t be full screen. But so far so good.
TCL 65R625 -- Denon X1400h -- Klipsch RP600m -- RP450C -- Micca M-6S 6.5 -- Dual Klipsch RW-10
whiteboy714 is online now
post #1408 of 1646 Old 10-23-2019, 08:46 AM
tommarra's Avatar
Quoted: 641 Post(s)
Liked: 384
Is there any player that is MadVR compatible but also shows the Menu of BDMV Rips?
I use MPC-HC but then only rip the main movie file to MKV, but for some movies I would like to get access to directors commentary etc
Gear: Fronts: B&W 803D3 | Center: B&W HTM2D3 | Surrounds: B&W 705S2 | Backs: B&W DM601S3 | Heights: Definitive Techonlogy ProCinema 1000 | Receiver & Amps: Anthem MRX 720 + Emotiva BasX-5 | Projector: JVC NX7 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is offline
post #1409 of 1646 Old 10-23-2019, 08:50 AM
tommarra's Avatar
Quoted: 641 Post(s)
Liked: 384
Originally Posted by kalhua View Post
Unfortunately I haven't found a fix. The noise is audible at low volumes but gets drowned out at movie listening levels. I have found that adjusting the voltages on my GPU along with madVR settings improves it but doesn't make it go away. Can you hear sound coming from the card itself as well? I can if I put my ear close to the computer case. I purchased the card not long ago. EVGA agreed to RMA the original card but the replacement was actually worse. At this point the only thing that I havent tried is a power conditioner but it helping seems unlikely.
There is no fix for coil whine from the processor. I had a cheaper 2060 and it would have a lot of white, I moved to an EVGA 2070 (which had lower whine to begin with) and then since I use MaDVR for only DTM I was able to lower the clock on the 2070 so it’s not running at full capacity with the card is engaged. This lead to lower coil noise.
Finally I simply moved my HTPC away from my listening position that fixed the problem for good :-)
tommarra is offline
post #1410 of 1646 Old 10-23-2019, 08:54 AM
kalhua's Avatar
Quoted: 46 Post(s)
In my case the sound is actually audible through all of my speakers. The sound from the card itself is tolerable.
Sent from my SM-G975U using Tapatalk
Reply Home Theater Computers
