madVR Player Support Thread - Page 67 - AVS Forum | Home Theater Discussions And Reviews
 271Likes
post #1981 of 2058 Old 02-12-2020, 05:54 AM
Luminated67's Avatar
Quoted: 868 Post(s)
Liked: 469
MadVR PC what components do I need?
OK guys you have all given me the itch for MadVR that needs to be scratched so my question firstly is what PC components do I need to make up a PC to run this to a high level.
Once I build the PC then will be time enough to ask advice on how to set it up.
Epson EH-TW9400 - QualGear Fixed Frame 100” - Sony x700 BRP & Panasonic 420 BRP - Sony 1080 AVR - IPL Acoustics M1TLs & IPL Acoustics AVC Pro Centre, Four KEF surrounds & 2 Sub boxes (10” Sub + 10” Passive Radiator)
Luminated67 is online now
post #1982 of 2058 Old 02-12-2020, 09:22 AM
claw's Avatar
Quoted: 2639 Post(s)
Liked: 2494
Guide: Building a 4K HTPC for madVR:
https://www.avsforum.com/forum/26-ho...tpc-madvr.html
Luminated67 likes this.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is offline
post #1983 of 2058 Old 02-12-2020, 01:57 PM
Quoted: 1164 Post(s)
Liked: 327
If you already have a PC, even with a weaker card, you can still test madvr, just not in motion (or smooth motion). Just pause the video and change whatever settings you need to compare it to the Epson's DTM.
noob00224 is online now
post #1984 of 2058 Old 02-12-2020, 03:39 PM
Liked: 327
@blastermaster do you know the nits of the screen?
With an Optoma HD3300 + Panamorph UH480 + 138" XD AT screen (0.94 gain) the estimated nits would be around 82 in High lamp and 72 in Low.
How many hours on the lamp?
Using a video player that's compatible with madvr, like MPC HC: https://www.avsforum.com/forum/26-ho...tup-guide.html
Install madvr: http://madvr.com/
Madvr folder must not be deleted, and not placed in Program Files or the Windows folder.
Install the latest beta: https://www.avsforum.com/forum/24-di...l#post59127786
Configure MPC HC (or other player) to use madvr as renderer as well as audio, color space (in madvr and lav filters), lav filters, etc.
Use these settings to start with, with the exception of display peak luminance: https://i.imgur.com/dmzMOX9.png
You can disable highlight recovery and shadow recovery in render times are too high. Render times for 24p video should be under 41ms. Render times can be displayed by activating the OSD by pressing Ctrl+J.
Change dynamic target nits to enhance the HDR effect (higher value), or bring the image closer to SDR (lower value). 50 is towards the lower.
Change contrast recovery to whatever you like, you can start with Hill Strong.
Choose the gamma curve: https://forum.kodi.tv/showthread.php?tid=223175&page=37
The gamma must be the same in madvr (the two places where it's found) and the projector.
This topic has also been discussed on this thread: https://www.avsforum.com/forum/26-ho...l#post58891882
This thread is for madvr tone mapping development, not support: https://www.avsforum.com/forum/24-di...ector-292.html
For the rest of the madvr settings, there are many combinations, but with an 970GTX try these:
madvr>
processing>artifact removal, image enhancement, image enhancements: disable all
scaling algorithms
>chroma upscaling: Sharp low quality
>SSIM 1D strength 50%
rendering
>dithering: Ordered Dithering
trade quality for performance>
check compromise on HDR luminance channel quality
You can also check scale chroma separately to reduce render times.
LE: for best performance in LAV Video select D3D11 and Automatic (native) for Hardware Device to use.
There is a mostly update guide on madvr, not sure if it's up to date on the DTM:
https://forum.kodi.tv/showthread.php?tid=259188
blastermaster likes this.
post #1985 of 2058 Old 02-12-2020, 10:39 PM
markmon1's Avatar
Quoted: 5942 Post(s)
Liked: 4012
Originally Posted by SirMaster View Post
Vsync can help for sure.
I thought setting it to 3 render ahead frames was the standard recommendation. It seems to work great with my RTX 2060.
3 frames at 24fps is going to increase your lag by like 120ms
Video: JVC RS4500 135" ST130 G4 screen in batcave, htpc nvidia 1080ti madVR.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is offline
post #1986 of 2058 Old 02-12-2020, 10:41 PM
SirMaster's Avatar
Quoted: 988 Post(s)
Liked: 656
Why would that matter for video playback?
SirMaster is offline
post #1987 of 2058 Old 02-12-2020, 10:46 PM
markmon1's Avatar
Liked: 4012
Well with that much lag you'd have to adjust the audio for sure. Then if you have 60fps content, you'd have to adjust it separately for that.
markmon1 is offline
post #1988 of 2058 Old 02-13-2020, 03:13 AM
mightyhuhn's Avatar
Quoted: 1367 Post(s)
Liked: 498
you don't have to you are on a computer the audio renderer and video renderer know all of this so they stay in sync.
mightyhuhn is offline
post #1989 of 2058 Old 02-13-2020, 07:02 AM
SirMaster's Avatar
Quoted: 988 Post(s)
Liked: 656
Yeah I have not noticed any difference in AV sync at 3 frames which completely solved any of my dropped frames on my RTX.
My Denon remains at 78ms.
post #1990 of 2058 Old 02-15-2020, 12:17 AM
Liked: 327
Originally Posted by jkkwaz View Post
Hi Claw,
With these settings, what do you have gamma set to in the RS500? 2.4? Thanks!
How to set the gamma:
post #1991 of 2058 Old 02-15-2020, 07:29 AM
louc6569's Avatar
Quoted: 31 Post(s)
I want to build a htpc to run madvr
To my jvc nx7 want to be able to pass atmos through the pc I will be using mkv tips 4k and regular bluray.
Can someone guide me on how to do this correctly.
louc6569 is offline
post #1992 of 2058 Old 02-15-2020, 07:57 AM
Liked: 327
How do you mean?
Windows can't process Atmos, it needs to be sent out to a compatible receiver.
post #1993 of 2058 Old 02-15-2020, 11:21 AM
tommarra's Avatar
Quoted: 805 Post(s)
Liked: 459
What output range do you set with MadVR?
When. I set MadVR to 0-255, Nvidia to 0-255 and JVC NX7 to auto or 0-255, my black bars are all washed out and the contrast is very much lacking.
When I set MadVR to video and JVC to 16-235 then the contrast is much improved and the black bars appear deep black vs washed out grey when using the full range.
I am not sure why is MadVR not taking the video input range and mapping it correctly to the full range? Is setting the entire chain to 16-235 the right way to set it up?
Gear: Fronts: B&W 804D3 | Center: B&W HTM2D3 | Surrounds: B&W 705S2 | Backs: B&W 684S2 | Heights: B&W DM601S3 | Subs: 3x PSA S1500 Receiver & Amps: Anthem MRX 720 + Monoprice Monolith 7x200 + Emotiva BasX-5 | Projector: JVC NX7 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is offline
post #1994 of 2058 Old 02-15-2020, 04:00 PM
mightyhuhn's Avatar
Liked: 498
ask other user of the PJ if full range works on that model (it should...) but what so ever setting everything to limited is ALWAYS wrong.
post #1995 of 2058 Old 02-15-2020, 04:27 PM
vp4lifehva's Avatar
Quoted: 17 Post(s)
I set Nvidia to 0-255, JVC NX7 and madVR to 16-235.
tommarra likes this.
vp4lifehva is offline
post #1996 of 2058 Old 02-15-2020, 05:24 PM
claw's Avatar
Liked: 2494
That is what I do for my JVC RS500. But I also have to send RGB 12-bit as the e-Shift models are unable to accept RGB 8-bit; the so-called magenta bug.
CJ
claw is offline
post #1997 of 2058 Old 02-15-2020, 05:32 PM
vp4lifehva's Avatar
Quoted: 17 Post(s)
Hmm...I also run a RS500 but haven't used it much with the same madVR PC since the upgrade in October. I have to check it again.
post #1998 of 2058 Old 02-15-2020, 11:22 PM
RapalloAV's Avatar
Quoted: 2276 Post(s)
Liked: 784
I use madvr with the 1080Ti card and the JVC NZ9, I sometimes nootice when the image is all very black that I see some type of artifacts moving withing those black areas...
What might be wrong in my setip, is it dithering that causes that movement within the black image, Im using ordered dithering.
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild, plus new LED ceiling install Christmas 2018
RapalloAV is offline
post #1999 of 2058 Old 02-15-2020, 11:27 PM
markmon1's Avatar
Liked: 4012
You mean JVC NX9? This is not dithering. You wont notice dithering. That's the point of it.
It sounds like you have a raised black floor and some compression noise you're seeing. If your black floor is low you won't see anything in black - its just black.
woofer and RapalloAV like this.
markmon1 is offline
post #2000 of 2058 Old 02-15-2020, 11:31 PM
RapalloAV's Avatar
Liked: 784
Sorry I mean the NX9, I never thought my black floor was raised as I set it with the blanking feature of the JVC NX9, but maybe you are right, I will drop it one notch and see if it stops. Thank you Mark
Murray Thompson
X Owner RapalloAV
post #2001 of 2058 Old 02-15-2020, 11:38 PM
markmon1's Avatar
Liked: 4012
Im not sure what you mean you used the blanking factor on the NX9. What is the brightness set at? Can you instead throw up a black chart and set black to 16 so that 17 is *barely* visible (like so hard to notice you almost cant notice it).
markmon1 is offline
post #2002 of 2058 Old 02-15-2020, 11:42 PM
RapalloAV's Avatar
Liked: 784
Thats exactly like I set it, I have to put my nose to the screen to see 17. But sometime I check it by using the HIDE button on the NX9 and making sure thatblack is set the same when HIDE is open or closed.
Murray Thompson
X Owner RapalloAV
post #2003 of 2058 Old 02-15-2020, 11:47 PM
markmon1's Avatar
Liked: 4012
OK. Perhaps the content, itself, is raised. Hide is tricky. The dynamic iris sets its level based on the unhidden content (at least it did).
markmon1 is offline
post #2004 of 2058 Old 02-15-2020, 11:49 PM
RapalloAV's Avatar
Liked: 784
If I ever test with HIDE I always turn off the Iris as I know that will certainly much up the readings...
Murray Thompson
X Owner RapalloAV
post #2005 of 2058 Old 02-16-2020, 04:42 AM
mightyhuhn's Avatar
Liked: 498
just make a screenshoot of the issue and share it here.
post #2006 of 2058 Old 02-17-2020, 08:36 AM
Liked: 0
hey there,
i have a pretty weird phenomenon lately... i'm not 100% sure but i think it started with the latest nvidia driver update.
following setup:
- win 10
- gtx 980
- latest mpc-hc / lavfilters / madvr
- philips 55pos901 oled
i've been using this setup for quite some time without any problems but i recently noticed wrong black levels for HDR content while SDR content is fine. (madvr hdr passthrough enabled)
rgb full range (0-255) is enabled in madvr settings and it currently gives me correct black levels for SDR content but i need to change it to 16-235 in order to get correct black levels for HDR content. (otherwise blacks are grey)
i checked this with some black level test files where 0-16 should be black and 17-25 flash.
0-255: correct SDR black levels but greyish blacks for HDR content
16-235: correct HDR black levels but bad black crush for SDR content
could this be a nvidia bug? or is there someting i am missing here?
zeus0r is offline
post #2007 of 2058 Old 02-19-2020, 12:51 PM
sjchmura's Avatar
Quoted: 2379 Post(s)
Liked: 929
Ok HDR suddenly broke and so confused
So
Windows 10
Madvr
MPc Be, potplayer classic
Philips 43” HDR monitor
Nvidia 2080Ti
So playing 4k non hdr is fine
When I play a uhd rip the monitor switches to HDR but is a grey mess, vertical lines, and looks like 720p stretches
I tried to uninstall madvr and reinstall but same issue
Any ideas? Is this a nvidia thing that broke madvr HDR?
DocACE911 on Steam, XBOX, PS4
"Kill Cancer or Die"
Custom Z9 Game Settings For SDR and HDR
Sony 75" Z9, Denon X4200, Definitive Technologies BP7002 + 9.1 ATMOS, PSV 18" sub
Loving Wife and 4 year old Son who tolerate this expense!
sjchmura is offline
post #2008 of 2058 Old 02-20-2020, 08:56 AM
whiteboy714's Avatar
Quoted: 1620 Post(s)
Liked: 708
Wondering if I could get some help. I am using madvr with DSplayer. Everything looks great but with some tv shows I am seeing some judder (not sure that is the right word) while panning. It's annoying and difficult to watch like that.
When I play the same file with Emby on my Shield they are smooth. The files are 1080p h264 mp4's downloaded from HGTV.com
My setup is
Ryzen R5 1600
GTX 1060 6GB
Maybe you can see something from this screen? Or can tell me a setting to look into?
https://imgur.com/Nt3yFQo
EDIT## I don't know why this site has to rotate images. imgur link provided.
TCL 65R625 -- Denon X1400h -- Klipsch RP600m -- RP450C -- Micca M-6S 6.5 -- Dual Klipsch RW-10
whiteboy714 is online now
post #2009 of 2058 Old 02-20-2020, 09:09 AM
mightyhuhn's Avatar
Liked: 498
rendertimes are to high this file is 30 FPS it needs rendertimes below 32 ms.
edit BTW. you are using 10 bit rendering with the GPU at 8 bit this which can easily add banding with nvidia GPUs.
post #2010 of 2058 Old 02-20-2020, 09:22 AM
Liked: 708
Oh shoot I didn't realize that, I was just considering 23 and 59. So I need a profile for 30fps? Or just drop something a hair I suppose.
Can you tell me the best settings to use for the second issue? I used onkyoman's guide a while ago and there are so many way to set that part up. They all seem to have strengths and weaknesses.
Reply Home Theater Computers
