madVR Player Support Thread - Page 92 - AVS Forum | Home Theater Discussions And Reviews
 391Likes
post #2731 of 2833 Old 06-27-2020, 02:54 AM
Quoted: 2013 Post(s)
Liked: 646
Originally Posted by Arese View Post
Thank you
You can also get expanded details by adding two empty folder to the madvr folder:
ShowHdrMode
ShowRenderSteps
noob00224 is online now
post #2732 of 2833 Old 06-27-2020, 12:55 PM
Liked: 646
What scenarios does scale chroma separately work?
4K source on a 1080p display works, but 4K source on a 1440p does not. Is this because in a 4K video the chroma is 1080p and on a 1440p display it would still require upscaling?
post #2733 of 2833 Old 06-27-2020, 08:01 PM
long_pn's Avatar
Quoted: 80 Post(s)
You're right. I think by downscaling, SSIM 2D is the king. So in order to use SSIM 2D, with a GTX1060 you have to enable scale chroma separately without having dropped frames especially at [email protected] If you got a more powerful GPU eg. 2080ti then it can be unchecked.
noob00224 likes this.
long_pn is offline
post #2734 of 2833 Old 06-28-2020, 12:54 AM
Liked: 646
It can also be debated if the result from upscaling chroma from 1080p (original size for 4K) and downscaling it is a good thing. For playback on a 1080p display.
post #2735 of 2833 Old 06-28-2020, 04:10 AM
long_pn's Avatar
Quoted: 80 Post(s)
I have tried pixel-peeper the two images but not noticed any difference on my 4K monitor. I think, as Madshi named that option, it's more about "saves performances" of the GPU than the picture quality.
long_pn is offline
post #2736 of 2833 Old 06-28-2020, 04:16 AM
Liked: 646
But in your case the feature does not work since you have a 4K display and the chroma is still getting upscaled. I think this is only for 4K downscaling to 1080p displays. Check the OSD and you'll see chroma upscale active.
post #2737 of 2833 Old 06-28-2020, 04:20 AM
mightyhuhn's Avatar
Quoted: 1498 Post(s)
Liked: 554
by default madVR upscales chroma first before downscaling it. so if you are not downscaling then this option doesn't do anything ever.
mightyhuhn is online now
post #2738 of 2833 Old 06-28-2020, 04:41 AM
long_pn's Avatar
Quoted: 80 Post(s)
I have only checked the two static images on the 4k monitor to find out any differences. Normally I'm downscaling 4k HDR movies to my 1080p projector.
long_pn is offline
post #2739 of 2833 Old 06-28-2020, 04:06 PM
Quoted: 61 Post(s)
Liked: 4
In jriver, I can’t seem to get then lav filters to show up.
Aceman2101 is offline
post #2740 of 2833 Old 06-28-2020, 04:35 PM
claw's Avatar
Quoted: 2943 Post(s)
Liked: 2828
Note the "auto-configured" text next to the filters. They were downloaded, installed, and configured by JRiver. You can't display or modify them. This is by design with JRiver.
You can replace them with standalone versions if you wish.
Aceman2101 likes this.
CJ
JVC RS500 | LG B7A OLED | Denon X6400H (7.2.4) | X4200W | Panasonic UB820 | Two Oppo 203 | Samsung K8500 | Apple TV 4K | Amazon Fire TV Stick 4K | HDfury Diva/Vertex/Linker/Integral | MadVR with EVGA RTX-2080 Ti
claw is offline
post #2741 of 2833 Old 06-28-2020, 10:27 PM
Liked: 0
Does anyone know how to fix this monitor flicker issue? I don't see any settings about a borderless fullscreen mode or anything.
ENunn is offline
post #2742 of 2833 Old 06-29-2020, 12:20 AM
markmon1's Avatar
Quoted: 6829 Post(s)
Liked: 4952
I dont see what that has to do with madVR. But it looks like your video card is resetting and/or resolutions are trying to reset repeatedly and keeps failing.
JVC Control - my software for controlling JVC projector via IP control.
Smart Masking - See my automatic smart screen masking system.
JVC IR Codes - free online pronto code converter for JVC IR codes.
markmon1 is offline
post #2743 of 2833 Old 06-30-2020, 10:30 AM
Quoted: 252 Post(s)
Liked: 49
Not sure if this is specifically a madVR issue, but can anyone help me get frame packed 3D output working? I've installed the latest lav filters with the 3D download option, and I've used 3D fix manager to enable stereo 3D with my Nvidia driver, but madVR is just outputting side by side off of my FP mkvs. All I can find is some 4+ year old threads about enabling this, and following all the steps results in side-by-side output.
filmgeek47 is offline
post #2744 of 2833 Old 07-01-2020, 10:48 PM
Liked: 0
Hey, I'm getting pretty bad quality when using MadVR. Settings in the screenshot below. I usually get better quality when I'm using the MPC Video renderer. Despite having a 1660Ti and using pretty high settings, the image quality looks pretty bad. Anything I'm doing wrong here? Also, I'm having way more dropped frames when playing 1080p videos instead of lower quality ones. I don't know, shouldn't it be the other way around due to the upscaling?
The image I've attached is of a 720p movie. Edit: I've attached a couple more images and cranked the settings all the way up to very high, which doesn't make any difference in image quality.
ID:	2751838   Click image for larger version
ID:	2751840   Click image for larger version
MovieStreamer85 is offline
post #2745 of 2833 Old 07-01-2020, 11:17 PM
Liked: 646
If the source is bad madvr can only do so much.
Post a screenshot of the movie while playing.
Also post a screenshot of:
mediainfo of the 720p file in question
madvr
processing>artifact removal
processing>image enhancements
scaling algorithms>image upscaling
scaling altorithms>image downscaling
scaling algorithms>upscaling refinement
rendering>dithering
rendering>trande quality for performance
post #2746 of 2833 Old 07-02-2020, 12:37 AM
Liked: 0
madvr
rendering>dithering
Please note that I have tried lower and higher settings, without no improvement in image quality at all and also MPC renderer produces better results (in my opinion). Right now it's on pretty much max settings and it doesn't have many dropped frames unless I'm playing 1080p videos. Quality and performance doesn't change for any settings. Looks all the same.
I'm posting a screenshot of 1080p video too, the dropped frames stay the same at all levels of quality. With madVR it looks really bad, worse than the original. Hobbit.txt is the mediainfo for the screenshot of the Hobbit I've provided.
And I just tried it out. 4K doesn't play at all. On any settings.
ID:	2751860   Click image for larger version
ID:	2751862   Click image for larger version
ID:	2751864   Click image for larger version
ID:	2751866   Click image for larger version
ID:	2751872   Click image for larger version
ID:	2751874   Click image for larger version
ID:	2751876   Click image for larger version
ID:	2751878   Click image for larger version
ID:	2751888   Click image for larger version
ID:	2751892   Click image for larger version
post #2747 of 2833 Old 07-02-2020, 02:26 AM
markmon1's Avatar
Liked: 4952
Something is really wrong. It looks like there's a *massive* anti noise filter going. Try turning off that anti-bloat filter. Also, I'd suggest dithering error diffusion 2 not 1. Hopefully the anti bloating filter fixes it. It definitely should *not* look this way.
markmon1 is offline
post #2748 of 2833 Old 07-02-2020, 04:57 AM
Liked: 0
Well, turning it off made it slightly better, but nowhere near the original quality. It actually should be better, right? Is there some kind of configuration file I could use so as to default everything to normal or something like that? Best settings for my GPU would be better, but that's probably taking it way too far. Any other settings I could try turning off? I hope I've given you enough info, I'd be glad to do what I can to get this fixed. It's only very slightly better. I wouldn't have said it made a difference if I didn't look closely. Big thanks for the help anyways! Hoping to get this fixed soon!
post #2749 of 2833 Old 07-02-2020, 07:45 AM
Liked: 646
I'm going to assume that you're new to madvr. There's no such thing as best settings for GPU, it's up to the source and personal preference.
So you have to read the guide and see what everything does. Cranking everything up does not mean the best quality.
https://forum.kodi.tv/showthread.php?tid=259188
I don't know how when disabling the settings mark suggested looked just a bit better. There should be a significant difference.
And how can a downgraded 800kb/s 720p video looks better than the original Blu ray? Or what's the original file the 720p file is being compared to?
First you should disable everything on artifact removal page, and only enable the feature after you've tested them individually with varying settings. The guide has examples of the effect of the feature in artifact removal page, but you can also try on your own files.
Disable anti bloating filter.
Try NGU Sharp instead of AA.
Try the dithering setting mark suggested.
This is my personal preference, but I only use banding removal from artifact page, unless the file is very poor quality.
I also use these settings for scaling algorithms>upscaling refinement
sharpen edges 2
enhance detail 1.1
luma sharpen 1.15
If there's some artifacting then disable luma sharpen setting and leave the other two.
And these for when the source has the same resolution as the display, or when the source is slightly higher resolution, but not something like 4K>1080p. Works for 1080p on 1080p:
In processing>image enhancements
sharpen edges 1.1
enhance detail 1.1
luma sharpen 1.15
The enhancement sets above should not be used at the same time, for upscaling use the first one, for video with same resolution as the display use the second.
There's nothing to be fixed, it's on your end that adjustments need to be made.
As for 4K, what happens exactly?
What madvr version are you using, is it a beta?
What LAV version?
Screenshot of LAV Video?
markmon1 and dimi123 like this.
post #2750 of 2833 Old 07-02-2020, 07:54 AM
markmon1's Avatar
Liked: 4952
Please turn *everything* off on the artifact removal page. You have every option checked. Let me know how it looks then. I totally missed that first setting photo when I looked at this earlier.
dimi123 and noob00224 like this.
markmon1 is offline
post #2751 of 2833 Old 07-02-2020, 08:25 AM
Liked: 1
Hello everyone!
I use the "always shift the image" function in the "zoom" menu in MadVR to move it down (it’s better to watch 2.35 with a projector on 16:9 screen).
When a film in full HD 1080p, the image moves down - all is ok. When I watch a film in the ultra HD 3840p, the image does not move down.
Please help deal with this problem. Perhaps there is another way to automatically shift the image down.
My projector - JVC dla X700
Any ideas?
ID:	2751984   Click image for larger version
Nicks007 is offline
post #2752 of 2833 Old 07-02-2020, 04:50 PM
Liked: 0
What LAV version?
Okay, I am very new to madVR. I did mention that in the last page. And I'm being honest it didn't make a lot of difference. But turning off everything in artifact removal did work. Disabled anti-bloating filter too. Tried NGU Sharp instead of AA. And the original I was referring to was how it looked using the default MPC renderer for the same file.
4K is playable now after changing the settings. Rendering time is still 100ms but I'll try tweaking some settings myself.
I've uploaded a screenshot on how it looks now. It looks a lot better now. Although I would like your opinion on how it actually looks. I mean, would this be the best quality I could get with madVR or could I push for better by tweaking settings? Anyway, performance is loads better. Uses only about 30% or less of my GPU. Makes me think it is underutilized. Anyway, thanks a lot, guys!
I have uploaded screenshots when using default MPC renderer, NGU AA and NGU Sharp. NGU AA seems like the best to me.
ID:	2752086   Click image for larger version
ID:	2752090   Click image for larger version
post #2753 of 2833 Old 07-04-2020, 12:01 PM
Quoted: 252 Post(s)
Liked: 49
I’m having a problem with setting up custom display modes. I’m trying to follow the MadVR tutorial on them. After following the instructions and running a video for 30 minutes, I create a custom resolution, choose “try” on one of the optimal timings, and then restart. When I start playing the same video, MadVR reports 1 dropped frame ever 54 minutes (much better than the 4 minutes I’m getting), but then after a few seconds it drops back to ~4 minutes. However, when I check the timings, they HAVE changed to the new ones I’m setting. It’s almost like something in the software is actively throwing the sync.
Any ideas? Could this be an nvidia driver problem? I’m running the most recent driver that doesn’t cause HDR issues.
post #2754 of 2833 Old 07-04-2020, 02:27 PM
RapalloAV's Avatar
Quoted: 2315 Post(s)
Liked: 791
Is it ok to play ripped DVDs (59.97) with madvr set to 30fps, does the image deteriorate by doing so?
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild, plus new LED ceiling install Christmas 2018
RapalloAV is offline
post #2755 of 2833 Old 07-04-2020, 03:46 PM
mightyhuhn's Avatar
Liked: 554
if the source is true 60 hz yes massively
post #2756 of 2833 Old 07-04-2020, 04:35 PM
RapalloAV's Avatar
Liked: 791
Can you explain what it actually does please if the source is 60Hz and you play at 30Hz?
Murray Thompson
X Owner RapalloAV
post #2757 of 2833 Old 07-04-2020, 04:43 PM
mightyhuhn's Avatar
Liked: 554
it throws half the frames away. there are a lot of ways to do that i haven't test what which DXVA implementation does. could be blending just discarding or frame matching followed by discard.
if you let madVR do it you are of really bad madVR is far from optimal if it has to drop frames. is one of the rare cases where other render are better but it's actually not needed so no really unimportant feature.
post #2758 of 2833 Old 07-04-2020, 05:13 PM
whiteboy714's Avatar
Quoted: 1909 Post(s)
Liked: 826
You like the middle one? Looks like the worst to me, I like the 3rd one.
EDIT# Ah my bad they are out of order.
TCL 65R625 -- Denon X3500h -- Klipsch RP600m -- RP450C -- Ascend HTM 200 SE -- Dual Klipsch RW-10
whiteboy714 is offline
post #2759 of 2833 Old 07-04-2020, 10:47 PM
markmon1's Avatar
Liked: 4952
Why even have a 30hz option? I don't see the benefit. My madVR display modes are: 2160p23, 2160p25, 2160p60. 30hz stuff will play back at 60hz just fine with no extra processing required. I suppose you could swap 2160p60 with 2160p59.
RapalloAV likes this.
markmon1 is offline
post #2760 of 2833 Old 07-05-2020, 10:25 AM
Quoted: 252 Post(s)
Liked: 49
Any thoughts on my custom display modes issue? It’s driving me nuts
Reply Home Theater Computers
