How to play music through (only) the center speaker? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-12-2016, 07:27 AM - Thread Starter
gsilver's Avatar
Quoted: 26 Post(s)
I just picked up a used center speaker, and I want to test it out to make sure that it's working properly. Normally, I'd have everything go to the correct channel, but while testing, I'd like to downmix stereo music sources into just the center speaker.
Normal music playback goes though the left/right channels.
The setup is:
PC -> HDMI -> Marantz receiver -> 3.0 speakers
gsilver is offline
post #2 of 8 Old 02-12-2016, 07:40 AM
TornadoTJ's Avatar
Quoted: 1952 Post(s)
Liked: 626
Play a monaural source and set the receiver to PLII?
TornadoTJ is offline
post #3 of 8 Old 02-12-2016, 07:45 AM
Jawaburger's Avatar
Quoted: 240 Post(s)
Liked: 245
In your speaker setup menu on your receiver make all your speakers say "none" except your center?
Sharp LC-80LE844U | HT PC | Marantz AV8003 | Marsh Sound Design A400s (FL/FR) | Marantz MM7055 (C/SL/SR) | PSA MTM 210T (FL/FR) | PSA MTM 210C (Center) | Phase Tech PC 3.1 (SL/SR/SB) | Dual PSA S1811 Subs
Jawaburger is offline
post #4 of 8 Old 02-12-2016, 07:45 AM
TornadoTJ's Avatar
Liked: 626
That's a good idea too.
post #5 of 8 Old 02-12-2016, 07:49 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4802
Run mono and disconnect L/R speakers would be another easy way.
lovinthehd is offline
post #6 of 8 Old 02-12-2016, 08:10 AM - Thread Starter
gsilver's Avatar
Quoted: 26 Post(s)
It wouldn't let me do that when they were still plugged in, at least.
I'll try it again when I get home tonight.
Though if all else fails, I can just plug it into the left audio and push the balance all the way to the left in Windows.
gsilver is offline
post #7 of 8 Old 02-13-2016, 09:13 AM
ES_Revenge's Avatar
Quoted: 584 Post(s)
Liked: 194
Some receivers have a hidden/service menu that allows you to remap channels on the receiver side meaning you can route L/R to the centre, etc. just for testing purposes (or other occasions you may actually want that to be the case). You could check to see if your AVR either allows this in standard menus or check online to see if anyone has figured out the service modes for it.
I'm not sure you can set the centre as the only speaker on AVRs since this typically violates Dolby/DTS "rules"--though Dolby and DTS aren't the only formats (because one could just be using multi-PCM) most AVRs follow those specifications anyway meaning at minimum all you can set is L/R. Then everything after that is optional. I.e. You can set all other speakers to "NONE" but not the L/R speakers.
As you said, if all else fails you can just connect the centre to the L or R terminals on the AVR and go that way.
ES_Revenge is offline
post #8 of 8 Old 02-13-2016, 09:17 AM
eljaycanuck's Avatar
Quoted: 2124 Post(s)
Liked: 3088
Originally Posted by gsilver
I just picked up a used center speaker, and I want to test it out to make sure that it's working properly. ...
... if all else fails, I can just plug it into the left audio and push the balance all the way to the left in Windows.
That's what I would do. It's a quick and easy way of testing the speaker and it's just as accurate as any other way.
eljaycanuck is online now
Reply Home Theater Computers
