Guide: Building a 4K HTPC for madVR - Page 103 - AVS Forum | Home Theater Discussions And Reviews
 1189Likes
post #3061 of 4857 Old 07-17-2019, 02:13 AM
chros73's Avatar
Quoted: 487 Post(s)
Liked: 241
Originally Posted by neo_2009 View Post
I've read the AIB cards should be available mid August.
Or you can replace the cooler on it by yourself.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(04.10.25+PC4:4:[email protected]/24/25/29/30/50/59/60Hz)
chros73 is online now
post #3062 of 4857 Old 07-17-2019, 05:11 AM - Thread Starter
Onkyoman's Avatar
Quoted: 1192 Post(s)
Liked: 704
I don't think that would pay off. A properly manufactured cooler should perform even better than a simple fix like that.
Onkyoman is offline
post #3063 of 4857 Old 07-17-2019, 05:49 AM
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
No way i would mess with something like that, it would void the warranty, impact the resale value, etc ...
I still need to wait and check how good these cards are, how much they cost, for how much can i sell the 2060, etc.
Only after weighting everything i will decide if i will switch or not.
chros73 likes this.
neo_2009 is online now
post #3064 of 4857 Old 07-17-2019, 07:40 AM
SirMaster's Avatar
Quoted: 1335 Post(s)
Liked: 989
After market coolers that you can install on GPUs perform even better than the best AIB coolers. However they are in general larger and may not fit in your case.
Also they don't void the warranty on most AIB brands and they shouldn't impact resale as you can just put the stock cooler back on before sale.
Here is one for example:
neo_2009 and chros73 like this.
SirMaster is offline
post #3065 of 4857 Old 07-17-2019, 07:51 AM
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
Actually, i've been considering buying a Raijintek Morpheus II.
Assuming it could be fitted in current and next generation cards, its something that would last a decade, and would allow the cards to run way cooler, which would not only increase performance, but also extend the longevity of the cards. My only question is if it will indeed fit on the next generations cards
post #3066 of 4857 Old 07-17-2019, 09:32 AM
whiteboy714's Avatar
Quoted: 1889 Post(s)
Liked: 811
https://www.youtube.com/watch?v=K-9k5cRbrPU
Many brands have a warranty sticker on a screw and if you mess it up they void the warranty.
Although EVGA has the sticker just so they can know they need to pull the cooler if you RMA the card.
whiteboy714 is online now
post #3067 of 4857 Old 07-17-2019, 12:55 PM
Killroy's Avatar
Quoted: 779 Post(s)
Liked: 762
I'm running a RTX 2070 with driver 418.91 along with Kodi/DSPlayer and Madvr beta86. My render times for 4k UHD are in the low-to-mid 20's to low 30's. No dropped frames or presentation glitches.
Is there any reason why I should update the driver to the newer versions? Since madvr is doing the tone mapping I don't need perfect HDR passthrough, right?
Killroy is offline
post #3068 of 4857 Old 07-17-2019, 05:58 PM
mightyhuhn's Avatar
Quoted: 1495 Post(s)
Liked: 553
@neo_2009
cooling ram and VRM is more then edgy with this and make the card very price on top of it.
@Killroy
you don't have to care about passthrough.
@whiteboy714
these stickers are generally of no consequences in the US at least on paper.
looks like evga looks at the differently:
Products with modification to the serial number and/or factory identification labels whether removed, relocated, falsified, defaced, damaged, altered or made illegible.
https://www.evga.com/warranty/graphics-cards/
Killroy and neo_2009 like this.
mightyhuhn is online now
post #3069 of 4857 Old 07-17-2019, 07:24 PM
annisman's Avatar
Quoted: 265 Post(s)
Liked: 120
I have found that unchecking 'use DX11' in MadVR is the only way I can get my UHD files to launch properly when starting playback in MPC-BE. My question is: what will I be sacrificing in MadVR by using DX9 instead of DX11' ?
LG B6 (Chad B. calibrated)
Yamaha 681 AVR
Polk Audio 3.1.2 Atmos
Panasonic UB820
Custom HTPC/Emby WMC/MPC-BE/MadVR
annisman is offline
post #3070 of 4857 Old 07-17-2019, 07:40 PM - Thread Starter
Onkyoman's Avatar
Liked: 704
10-bit RGB output if you need it. Otherwise, it is more of a cosmetic change. It is strange for that checkbox to suddenly stop working. The only thing that I can think of that would cause that is some type of Windows update. Like I said in your other post, try updating to the latest Nvidia driver.
Onkyoman is offline
post #3071 of 4857 Old 07-17-2019, 07:48 PM
annisman's Avatar
Quoted: 265 Post(s)
Liked: 120
It's not that the check box stopped working. I purposely disabled DX11 to try and get HDR working properly, and it did the trick but I want to know if it's worth it, what I'm losing by using DX9.
Yamaha 681 AVR
Panasonic UB820
annisman is offline
post #3072 of 4857 Old 07-17-2019, 08:32 PM
Liked: 811
Originally Posted by mightyhuhn View Post
@neo_2009
@Killroy
@whiteboy714
That's the serial number. But the screw sticker does not void the warranty. Multiple of the big brands don't allow you to remove the cooler. When I was water-cooling I did some research and a couple brand I liked were a no go. That was a few years ago.
TCL 65R625 -- Denon X3500h -- Klipsch RP600m -- RP450C -- Ascend HTM 200 SE -- Dual Klipsch RW-10
post #3073 of 4857 Old 07-18-2019, 08:54 AM
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
Regarding the cost, if the Morpheus can be used in the next generation cards, lets say it would be used with at least 3 generations, it would be worth it ...
post #3074 of 4857 Old 07-18-2019, 04:59 PM
mightyhuhn's Avatar
Liked: 553
it doesn't matter if the Morpheus is better you only need a cooler that is good enough and partner card will give you that card for a lower price.
it doesn't officially support the 5700XT not even the nearly 1 year old turing cards.
post #3075 of 4857 Old 07-19-2019, 02:48 AM
Quoted: 76 Post(s)
I have built a new WIN 10 Home 64bit HTPC Computer with JRiver , MadVR and a ASUS RTX 2080 Graphics card (driver 430.39) connected via HDMI to a Marantz SR5013 Receiver.
When I updated to Windows version 1903 (from 1809) the surround and subwoofer channel stopped working, only sound from the left and right channel did work.
I checked the audio settings in JRiver and everything looked as i should.
I tried to reinstall the audio driver and other things according to this post:
https://www.guidingtech.com/no-sound...ows-10-update/
Nothing worked.
I reverted back to version 1809 and everything works again.
Anyone had this problem before?
Best regards,
//Peter
arcspin is online now
post #3076 of 4857 Old 07-19-2019, 04:28 AM - Thread Starter
Onkyoman's Avatar
Liked: 704
I haven't heard of this. Does this occur when bitstreaming? Are you using WASAPI exclusive mode in JRiver or WASAPI shared? Did you try another audio renderer from another media player?
Did you run through the Windows Sound configuration wizard?
Onkyoman is offline
post #3077 of 4857 Old 07-19-2019, 05:43 AM
Quoted: 76 Post(s)
Hi,
No bitstreaming and yes Wasapi exclusive mode.
No I did not try another player but I did do the windows Sound configuration wizard where I could set up a 5.1 system and do the test tones but there where only sound coming from the front left and right speaker.
Were strange indeed.
post #3078 of 4857 Old 07-19-2019, 06:36 AM
Liked: 811
Originally Posted by arcspin View Post
Hi,
Is this only Jriver? Is your music local to the machine or in a NAS?
You said no bitstreaming so I assume we're not talking movies?
Anyways I had the same problem recently. Was banging my head against the wall. In the dlna section I had told jriver to "transcode audio when necessary". That's not exactly what it was said but something to that effect. This solved my problem in jriver. Turning that off for some reason it was thinking my system couldn't handle Multi channel Audio.
I had the same issue also with the windows speaker config. I want to say this solved it but that doesn't make sense.
post #3079 of 4857 Old 07-19-2019, 08:53 AM
Quoted: 76 Post(s)
Hi,
This is my setup in the bedroom and it is only a 5.1 audio setup so no Atmos and therefor not necessarily a need for bitstream, but it is for movies and the movies (HD and UHD) are on a Synology NAS.
Bitstream however works just fine in Win 1809 with this setup.
This is a new setup so eventually I will switch over to bitstream.
Great suggestion, could you when you have access to your system look and see what the specific name was for that particular "transcode audio when necessary" is.
When i do a search under options in JRiver I do not get that specific phrase or anything similar.
Attach a screen shot on what I get when doing a search for dlna.
Thanx,
post #3080 of 4857 Old 07-19-2019, 09:59 AM
Liked: 811
Hi,
Thanx,
Ah yes, don't search, just look in Media Network, then under "client options" and "audio conversion". Here is a quick screen shot from my laptop.
But if we're talking movies I see no reason to not bitstream unless you have some sort of analog setup.
post #3081 of 4857 Old 07-19-2019, 10:29 AM
Quoted: 76 Post(s)
Ok, great!
No analog setup, HDMI straight from the computer to the Marantz receiver and from there HDMI to the Tv.
Yes, bitstream it will be.
To fix the problem you had to change:
from "Conversion: Convert audio if necessary"
to "Conversion: Don't convert audio"
That solved the surround/subwoofer bug in 1903 for you?
post #3082 of 4857 Old 07-19-2019, 11:01 AM
Liked: 811
Ok, great!
That solved Jriver not playing multi channel audio. It will only output stereo, even when the track was clearly 5.1. But again I am dealing with Flac files not movies, for any sort of video I always bitstream.
arcspin likes this.
post #3083 of 4857 Old 07-22-2019, 02:16 PM
denisoftus's Avatar
Quoted: 173 Post(s)
Lads, I need some help here, latest Windows 10 May 2019 Update broke HDR settings or something, any HDR move is now displayed in magenta colours, and even if I tried to switch on HDR in Windows (HDR for games) it does the same, I searched quickly in the forum but could not find any solution.
Anyone came across this?
I'm using MadVr with MPC HC, but it actually not working everywhere.
4K JVC DLA-X7900BE (RS540); 7.1 Audio: Atmos, DTS-HD, True-HD, Screen: Black Widow Dulux DS1 (on the wall); TV: 4K LG 55'
denisoftus is offline
post #3084 of 4857 Old 07-22-2019, 06:31 PM - Thread Starter
Onkyoman's Avatar
Liked: 704
Your issue sounds similar to this one:
https://www.avsforum.com/forum/26-ho...l#post58328874
This is the first that I've heard of this.
Onkyoman is offline
post #3085 of 4857 Old 07-22-2019, 06:34 PM
Killroy's Avatar
Quoted: 779 Post(s)
Liked: 762
I've said it before, I'll say it again.... if your HTPC is running fine, don't update Windows. "stopudates10" is your friend.
denisoftus and chros73 like this.
Killroy is offline
post #3086 of 4857 Old 07-23-2019, 03:57 AM
denisoftus's Avatar
Quoted: 173 Post(s)
Hi Onkyoman, thanks for your reply, it probably only similar in a way they suggest to roll back the update. In my case everything turns magenta-ish soon I switch HDR on, including just windows settings, I have Nvidia 1060 and also tried to update drivers to no avail
post #3087 of 4857 Old 07-23-2019, 04:59 AM - Thread Starter
Onkyoman's Avatar
Liked: 704
I would take your concerns to Doom9 to get more help and more eyes on your post.
Onkyoman is offline
post #3088 of 4857 Old 07-23-2019, 05:49 AM
markmon1's Avatar
Quoted: 6758 Post(s)
Liked: 4860
Blocking windows 10 updates is pretty simple now. As a happy Windows 1703 user, all I had to do to kill updates is:
Stop and disable windows update service
Stop and disable background intelligent transfer service
Stop and disable update orchestrator service.
CoryW, denisoftus and chros73 like this.
JVC Control - my software for controlling JVC projector via IP control.
Smart Masking - See my automatic smart screen masking system.
JVC IR Codes - free online pronto code converter for JVC IR codes.
markmon1 is online now
post #3089 of 4857 Old 07-23-2019, 06:06 AM
denisoftus's Avatar
Quoted: 173 Post(s)
That issue is resolved by rolling back from 1903 Windows 10 Update, using Recovery option. I don't think its related to MadVR at all, as I was experiencing same colours switching to HDR (Play GDR Games and Apps) in Windows Settings.
Now MPC-HC or/and BE are playing HDR clips just fine, but when I use Windows Settings to switch HDR ON it does the same as before: some colours are missing, and in general screen looks magenta-colored. It is still for me to determine why, and I can't remember it was or wasn't like that before, main thing the movies are playing fine now, and I'm looking into disabling Windows Updates as suggested by Killroy.
Thanks for your helps guys.
post #3090 of 4857 Old 07-23-2019, 06:29 AM
markmon1's Avatar
Liked: 4860
Sounds to me like you have a colorspace mismatch when HDR is enabled. For example, your display may be set to RGB and your desktop set to YUV type thing.
denisoftus likes this.
Reply Home Theater Computers
htpc build , madvr
