Guide: Building a 4K HTPC for madVR - Page 161 - AVS Forum | Home Theater Discussions And Reviews
 1197Likes
post #4801 of 4897 Old 06-29-2020, 08:49 AM
whiteboy714's Avatar
Quoted: 1908 Post(s)
Liked: 826
Originally Posted by biglen View Post
Okay, so I tried setting up my first profile. I named it 1080p24, and used the settings from the guide. Does it look like the settings are kicking in when I play a 1080p movie? Did I make the profile correctly? The only thing I'm not sure of, is if I need to make the 1080p profile in the other settings, when I adjusted them. Some settings were in Scaling Algorithms, and the others were in Rendering. Do I need to make a 1080p profile in Rendering too?
Sent from my SM-N975U using Tapatalk
I'm not sure why there is that second folder that says "profile 1" on the left panel in your settings? It should be directly under 1080p24.
But maybe it still works. What you want to do is close the madvr settings, and play a 1080p video. Once you do that open the madvr settings and the word "1080p24" will be in bold showing that it is actively being used.
You made that extra folder so maybe "profile 1" will be in bold.
TCL 65R625 -- Denon X3500h -- Klipsch RP600m -- RP450C -- Ascend HTM 200 SE -- Dual Klipsch RW-10
whiteboy714 is offline
post #4802 of 4897 Old 06-29-2020, 08:54 AM
Liked: 826
Here's a screenshot of the upscaling page. One more question that maybe you can help with. I have some 3D rips that are 1080p. My Epson 5050 won't engage the 3D mode when it's fed a 2160p signal. I can change the main resolution in Kodi to 1080p, and that works. My question would be, am I messing anything up by setting Kodi to 1080p, as opposed to 2160, which I normally did?
You need to make profiles for every section that you want to have custom settings per resolution. So yes make a profile under rendering as well.
There's nothing wrong with setting Kodi to 1080p as you have madvr adjusting the resolution for playback. But you'd need to somehow prevent madvr from upscaling those 3d movies to 2160.
Your render times on that screen shot are really low. Which is great but means you can still but up some settings the GPU isn't being used much.
post #4803 of 4897 Old 06-29-2020, 09:10 AM
biglen's Avatar
Quoted: 1051 Post(s)
Liked: 375
Profile 1 is bold with 1080p and 3D rips. If i'm looking at the 3D rip OSD correctly, it doesn't look like the 3D rip was being upscaled. I could be reading it wrong though. I don't know why Profile 1 was created. I only created 1080p. As far as bumping up my settings, to get the most out of my GPU, which settings would benefit the most getting bumped up?
biglen is online now
post #4804 of 4897 Old 06-29-2020, 09:28 AM
Liked: 826
If it's working then great! You might not even need to make a 4k profile, it should use the default settings if not 1080p.
As far as upping the settings I would probably Max out the using stuff and see what it can handle. It might not make a huge difference but why not. Or if you're happy just leave it alone.
post #4805 of 4897 Old 06-29-2020, 09:40 AM
biglen's Avatar
Liked: 375
Max out the using stuff? What do you mean by that? Also, in the guide, there are settings for a HDR profile. I already have a profile for 2160p, so wouldn't there be a conflict with the settings, when I play a 2160 HDR movie?
post #4806 of 4897 Old 06-29-2020, 09:56 AM
Liked: 826
Auto correct. I meant upscaling settings.
Those are just the HDR settings not necessarily a profile. But if you also have a 2160p settings then be sure to add those hdr settings to it. You'll have to be sure you have a profile group for 2160p where the HDR settings are.
post #4807 of 4897 Old 06-29-2020, 10:01 AM
biglen's Avatar
Liked: 375
Hmmmmm. Something isn't right. When I play a 4k HDR movie, the 1080p profile is bold, and the movie is really choppy. How do I get it so 4k HDR doesn't use the 1080p profile? That's where I'm not understanding profiles. How does each video type, know which profile to use ?
post #4808 of 4897 Old 06-29-2020, 10:04 AM
Liked: 826
When you make the profile you add the info that says something like "if less than 24fps"
Someone posted it for you somewhere, I'm on a phone currently don't know where it was. Post a screen shot of the page where you made the 1080p profile.
post #4809 of 4897 Old 06-29-2020, 10:17 AM
biglen's Avatar
Liked: 375
This is the profile I made. I don't think I'm doing it right. Mybe I'm making things more difficult than they need to be? I just want MadVR for upscaling 1080p movies, 4k movies, and dynamic tone mapping. Do I need profiles for that?
Name:	1080p settings.PNG
post #4810 of 4897 Old 06-29-2020, 10:20 AM
Liked: 826
Sorry I bailed from madvr like 6 months ago so nothing to look at here.
I was referring to the screen where you put all the profiles. I would go back to the Kodi guide as far as setting them up. You should get a green check mark when they're set up right
post #4811 of 4897 Old 06-29-2020, 10:26 AM
Liked: 826
Say this point I think I'm just confusing things more than anything.
Profiles were quite a pain for me as well. Info out there is not super clear.
post #4812 of 4897 Old 06-29-2020, 10:42 AM
biglen's Avatar
Liked: 375
That's okay. When you mentioned resolutions, I remembered this part in the guide. I copy and pasted that string, got the green check mark, and now everything seems to be playing correctly.
post #4813 of 4897 Old 06-29-2020, 11:09 AM
Liked: 826
Yes that's what I mean. Glad it's working. And remember I think you need to do that for each category in madvr if you want to have profiles, ie rendering and scaling.
post #4814 of 4897 Old 06-29-2020, 02:42 PM
biglen's Avatar
Liked: 375
So that string gets pasted into Rendering, and then in Processing? That's how MadVR would know to link those options to my particular Profiles that I set up in Scaling, right?
post #4815 of 4897 Old 06-29-2020, 02:58 PM
Liked: 826
Yes you have to do each section individually if you want profiles. When you make profiles for scaling it only affects the scaling settings.
biglen likes this.
post #4816 of 4897 Old 06-29-2020, 03:05 PM
Liked: 826
You just repeat the process for each section if you want to have profiles for a given section. Or "groups" I guess is the technical name.
ID:	2750778   Click image for larger version
post #4817 of 4897 Old 06-29-2020, 03:06 PM
biglen's Avatar
Liked: 375
Okay, thank you so much. I'm starting to now understand how profiles work. The copy and paste string is the key to getting all the different settings to link to each other. I'm assuming MadVR automatically uses the hdr settings under my 5050 automatically, when it sees an HDR movie being played? That's not actually a "profile", right?
post #4818 of 4897 Old 06-29-2020, 03:09 PM
Liked: 826
And you can get as specific or as general as you want, for instance some people like to do
720p25, 720p29, 720p60 in scaling. But then in a section like rendering you may just have a profile for 720p.
You can really tweak as much or as little as you want to get the most out of it.
post #4819 of 4897 Old 06-29-2020, 03:11 PM
biglen's Avatar
Liked: 375
Gotcha. I edited my last post asking you about the hdr settings under my projector. Am I correct in how I understand it?
post #4820 of 4897 Old 06-29-2020, 03:28 PM
Liked: 826
Yeah thats how I understand it, I have never done any there. It looks like you can but I think it is smart enough to know the difference.
biglen likes this.
post #4821 of 4897 Old 06-30-2020, 12:10 AM
Quoted: 252 Post(s)
Liked: 49
Would you mind sharing what software, video card and driver version you’re using to play 3D rips? I’m having a hard time getting my full HD 3D rips to play back with MadVR (they just play back as side by side).
filmgeek47 is offline
post #4822 of 4897 Old 06-30-2020, 04:47 AM
biglen's Avatar
Liked: 375
I just opened the 3D movie in Kodi 17.7 Better GUI, using DSPlayer for the default player. My GPU is a RTX2060 Super. All of my 3D rips are side by side, so maybe that's why it's working for me?
post #4823 of 4897 Old 06-30-2020, 08:17 AM
Quoted: 252 Post(s)
Liked: 49
Ah. Yeah, frame packed 3D is a bit more complicated. Thanks for the reply though.
post #4824 of 4897 Old 06-30-2020, 08:44 AM
Quoted: 61 Post(s)
Liked: 4
What 4K drive does everyone like ?
Aceman2101 is offline
post #4825 of 4897 Old 06-30-2020, 11:46 AM
reebok's Avatar
Quoted: 17 Post(s)
https://makemkv.com/forum/viewforum....a79d98a41737d9
Aceman2101 likes this.
reebok is offline
post #4826 of 4897 Old 06-30-2020, 11:56 AM
Quoted: 61 Post(s)
Liked: 4
Originally Posted by reebok View Post
Ok really stupid question, does madvr only work with rips or does it work on both
post #4827 of 4897 Old 06-30-2020, 12:06 PM
reebok's Avatar
Quoted: 17 Post(s)
what do you mean both? are you talking about UHD discs? the first page of this thread talks about those.
reebok is offline
post #4828 of 4897 Old 06-30-2020, 12:08 PM
Quoted: 61 Post(s)
Liked: 4
Yes discs.
post #4829 of 4897 Old 06-30-2020, 12:40 PM
SirMaster's Avatar
Quoted: 1373 Post(s)
Liked: 1032
Yes discs.
madVR doessn't care what it's playing. It's the media player that either supports discs or not.
But yes, you can use media players directly with discs with the right software. Typically RedFox AnyDVD HD.
SirMaster is offline
post #4830 of 4897 Old 06-30-2020, 01:04 PM
Quoted: 61 Post(s)
Liked: 8
I am going to order another card and give this another try. The shield performance is not acceptable. Up-scaling creates lots of artifacts. Playing the same film on a 1080p screen with a 590ti looks worlds better than the same film on a 4K C8 65in through the shield.
When playing other films through the 1660ti on my HTPC, I was getting way too much stuttering with the 1660ti. I am considering a 2060 super or a 2070 Super for $90 more to see if they can accomplish the look I am going for. Both cards are stretching my budget a bit, but I want to use a lot of artifact removal. I want to remove ringing effects and banding. I would like to get the nice smooth pic I get on my 1080 with a 590ti card. For me smoothness and lack of motion artifacts are a priority. Trying these settings on the 1660ti caused it to get very loud. After reading SirMaster say
Originally Posted by SirMaster View Post
In my opinion yes. I bought an RTX 2060 for my own system for a reason as it lets me do everything quality wise that I can see.
Other people I'm sure have other opinions.
Even the GTX 1060 in my laptop I can do all the tone-mapping options with no compromise performance for quality options. I just have to take Chroma scaling down to bicubic and dithering down to ordered in order to make frame time.
I thought a 2060 super would be enough, but others say you need more.
I can buy a 2060 Super for $359 or a 2070 Super for $449. I would much rather spend less if the performance is not going to be affected, but not if it is going to cause frustration with a loss of quality. I don't know if the 2070 S is so much better that it would allow me to upgrade my settings. Please advise. I have to buy today. Got a special deal that ends.
esumsea is offline
Reply Home Theater Computers
htpc build , madvr
