Guide: Building a 4K HTPC for madVR - Page 81 - AVS Forum | Home Theater Discussions And Reviews
 744Likes
post #2401 of 2912 Old 03-16-2019, 07:23 AM
damelon's Avatar
Liked: 345
Originally Posted by arcspin View Post
I will try installing 398.11 and also 385.28 graphics driver to see if that solves the micro stutter and also "activate Vsync in the 3D settings from NVIDIA" it is now set on default "use the 3D application setting"
(I think these are the two drivers that are commonly refereed to as working properly)
Is there anything else I should consider?
Best regards,
//Peter
Unfortunately, you cannot use 398.11/385.28 with RTX cards
damelon is offline
post #2402 of 2912 Old 03-16-2019, 07:26 AM
Quoted: 64 Post(s)
Ohhh, good to know.
What is the preferred driver for RTX cards?
/Thx
arcspin is offline
post #2403 of 2912 Old 03-16-2019, 07:35 AM
brazen1's Avatar
Quoted: 571 Post(s)
Liked: 328
madVR has lots of algorithm adjustments to fine tune. We know you've adjusted them. So does PowerDVD. Did you adjust any of them? Even with the algorithms off, my results using PowerDVD and madVR don't look anywhere near as bad as the pictures you posted. I sure hope it's your camera.
HOW TO - Kodi 2D - 3D - UHD (4k) HDR Guide Internal & External Players
W10 1903 / MPC-BE\HC / PotPlayer / PowerDVD 19 / DVDFab Player 3 / KODI 19 videoplayer
GTX960 4GB / RGB Full 4:4:4 / 8bit Desktop mode =60Hz / 10/12bit Video mode = Matched Refresh rates IE 23,24,25,60Hz
65JS8500 UHD HDR 3D / Denon S720W
brazen1 is offline
post #2404 of 2912 Old 03-16-2019, 09:01 AM
damelon's Avatar
Liked: 345
Ohhh, good to know.
/Thx
Wish I knew :-/
milin_im likes this.
damelon is offline
post #2405 of 2912 Old 03-16-2019, 09:20 AM
neo_2009's Avatar
Quoted: 309 Post(s)
Liked: 225
I have a RTX 2060 and i'm using the latest 417.71 with no problems so far.
coxy2416 and arcspin like this.
neo_2009 is online now
post #2406 of 2912 Old 03-16-2019, 09:30 AM
whiteboy714's Avatar
Quoted: 646 Post(s)
Liked: 186
Originally Posted by markmon1 View Post
What are you upscaling from and to? What is your display device? And what are your upscaling settings?
Mainly blu ray from 1080p to the TV's res 2160p. My display device a 55MU6290, nothing special, gpu is a 1060 6GB. I am using the medium settings from this thread https://forum.kodi.tv/showthread.php?tid=259188
This is the 1080p profile
Medium:
Chroma: NGU Anti-Alias (low)
Downscaling: SSIM 1D 100% + LL + AR
Image upscaling: Off
Image doubling: NGU Sharp
<-- Luma doubling: high
<-- Luma quadrupling: let madVR decide (direct quadruple - NGU Sharp (high))
<-- Chroma: let madVR decide (Bicubic60 + AR)
<-- Doubling: let madVR decide (scaling factor 1.2x (or bigger))
<-- Quadrupling: let madVR decide (scaling factor 2.4x (or bigger))
<-- Upscaling algo: let madVR decide (Bicubic60 + AR)
<-- Downscaling algo: let madVR decide (Bicubic150 + LL + AR)
Upscaling refinement: Off
Artifact removal - Debanding: low/medium
Artifact removal - Deringing: Off
Artifact removal - Deblocking: Off
Artifact removal - Denoising: Off
Image enhancements: Off
Dithering: Error Diffusion 2
2160p profile
Medium:
Chroma: NGU Anti-Alias (medium)
Image upscaling: Jinc + AR
Image doubling: Off
Artifact removal - Debanding: Off
whiteboy714 is offline
post #2407 of 2912 Old 03-16-2019, 09:49 AM
mightyhuhn's Avatar
Quoted: 1142 Post(s)
Liked: 418
Originally Posted by jbarteli View Post
Thanx, and the algorithm quality options?
the highest you can do. be aware there is a huge diminishing return on very high.
Originally Posted by T-Bone View Post
Unfortunately... the powerdvd image is focused. There are 4 video enhancement settings plus the original unenhanced menu option. I took pictures of four different powerdvd images. They all look blurry when I am up close and take a picture with my Galaxy s9.
MadVR was shot with ngu sharp High luma, Medium chroma.
point is that there is a night and day difference. And for whatever reason, powerdvd looks like crap compared to madVR. That was the point I was making. And that not all upscalers are created equal.
-T
madVR doesn't need to hide from proper comparison.
you won't believe how much work it is to turn an image to look like crap.
i would have done a proper comparison already if i would even dear to give pdvd a single Pfennig and i have no doubt in my mind madVR will win not even a challenge.
but this needs to be done with proper screenshoots and at least the same frame.
mightyhuhn is online now
post #2408 of 2912 Old 03-16-2019, 10:18 AM
Quoted: 64 Post(s)
I'm using the same driver.
Good to know that I do not need to hunt down another driver.
Sent from my SM-N960F using Tapatalk
arcspin is offline
post #2409 of 2912 Old 03-16-2019, 10:32 AM
neo_2009's Avatar
Quoted: 309 Post(s)
Liked: 225
Please note that my use is limited to 1080p as my Optoma HD87 is a 1080p projector.
So i cannot predict how this driver behaves with HDR, 10/12 bits, 2160p, etc.
arcspin likes this.
post #2410 of 2912 Old 03-16-2019, 11:22 AM
damelon's Avatar
Liked: 345
This does matter. My only issues personally were with HDR when using an RTX card. But on another thread it seems some cards have the issue I did and other do not.
damelon is offline
post #2411 of 2912 Old 03-16-2019, 12:52 PM
Quoted: 646 Post(s)
Liked: 186
What's the issue?
post #2412 of 2912 Old 03-16-2019, 02:45 PM
damelon's Avatar
Liked: 345
Originally Posted by whiteboy714 View Post
What's the issue?
Some people have had problems with HDR content on certain RTX cards where there will be judder which is unrelated to clock timings and repeated/dropped frames. It appears as a visual judder or hiccup during playback. No setting I changed corrected the issue. Swapping to the GTX 1080 in my desktop pc (and downgrading my drivers) removed the issue completely so this is no longer a problem for me. I'm not sure if it is related to some of the new beta builds of MadVR, specific cards, etc. I also noticed that it always happened at the same spots during playback. I've seen people who have RTX 2080s say they've seen it as well as myself who had an RTX2060 at the time. So unsure what the root cause of the problem is. It only happened during HDR playback wile using an RTX card and never on 4K SDR or 1080P playback.
damelon is offline
post #2413 of 2912 Old 03-16-2019, 02:55 PM
Quoted: 646 Post(s)
Liked: 186
I see thanks, my RTX card is in my desktop with no HDR so looks like a non issue for me.
post #2414 of 2912 Old 03-17-2019, 02:53 AM
Quoted: 64 Post(s)
I too have made the jump from a GTX 1060 to a RTX 2080 graphics card.
And I also experience micro stutter (with the RTX 2080 not with the GTX 1060) watching UHD MKV with the micro stutter not showing up in madVR OSD as dropped/repeated frames.
I have solved the problem simply by using FSE (Full Screen Exclusive mode), that took care of the micro stutter completely.
I Quote myself to have some traceability of solutions for the micro stutter with RTX 2080 graphics cards.
I can confirm and I think it was @Soulnight who wrote that by changing the Vertical sync to "ON" in the Manage 3D settings in NVIDIA control panel completely solved the micro stutter I had in Fullscreen Windowed mode.
So the two solutions that is working for me is to enable automatic fullscreen exclusive mode in madVR or set Vertical sync to "ON" and continue using enable window overlay in madVR. Both will solve the micro stutter I had when using my RTX 2080 graphics card.
edit: adding a picture to better illustrate the vertical sync change needed.
//Peter
neo_2009, riddle and berstuck like this.
arcspin is offline
post #2415 of 2912 Old 03-17-2019, 02:56 AM
Soulnight's Avatar
Quoted: 939 Post(s)
Liked: 1372
//Peter
Great that it also worked for you.
It also worked for everyone who had the same issue in the german madVR/HTPC facebook group.
damelon, neo_2009 and arcspin like this.
Soulnight is online now
post #2416 of 2912 Old 03-17-2019, 06:51 AM
damelon's Avatar
Liked: 345
Onkyoman pointed that out to me earlier but it didn't change anything for me unfortunately. Glad there are things that are helping some people! I'm just happy I had an alternate video card I could use!
damelon is offline
post #2417 of 2912 Old 03-18-2019, 09:20 PM
hotrippr's Avatar
Quoted: 73 Post(s)
Liked: 33
wanting the Radeon VII. I am over Nvidia overpriced overhyped gimmicky bs
Can anyone tell me from the HTPC user point of view if there are any pros and cons you all can give me regarding amd or nvidia? (all fan-boy comments aside please). Just really wanna hear some honest non biased comments from actual users. I use Madvr all the time for hdr 10bit rips. Any features I would be missing out on from one to the other? etc.
Thanks in advance
Sony X720E
Yamaha RX-V379 5.1 - Klipsch RF3 & RC3 - Boston VR500W Sub - CR4 for rears
Gigabyte Gaming OC RTX2070 - 4790K i7 - 2x8GB Gskill Ripjaws X
970EVO 512GB NvMe
EVGA Supernova G2 750 80+Gold
hotrippr is offline
post #2418 of 2912 Old 03-18-2019, 11:22 PM
Quoted: 72 Post(s)
Originally Posted by Klaus.S View Post
I have a small problem.
Was using jriver with madvr and setup gave me a RGB 8 bit picture and all was working.
Now I am using Kodi > MPC-BE + lavfilter + madvr. Everytime I try RGB 8 bit or 12 bit the screen goes pink.
So right now I use Ycbcr444 on the GPU, madvr is Auto and projector is also Auto and that works. But it is not RGB
I have HTPC with RTX 2080 and is using a JVC X7500 projector.
Any idea what setting I might have done wrong. Do you need more info please let me now.
Anyone who can help me out.
When watching 1080p movies upscaled to 2160p I get RGB 8 bit full, but when I watch 2160p I get RGB 12 bit limited, Ycbcr444 limited. Can't get RGB 8 bit full when watchng 4K
Klaus.S is offline
post #2419 of 2912 Old 03-18-2019, 11:30 PM
mightyhuhn's Avatar
Liked: 418
madshi gave a hind for the use of tensor and a clear recommendation RTX cards because of that.
and yes the RTX cards where known to be over priced until AMD joined them with the VEGA 7 which is just a vega refresh with a RTX like price tag and no real new feature if useful or not. these turing cards have quite some potential which may never get's used and i'm clearly not talking about ray tracing here...
how can nvidia over price there cards if AMD does the same? worst possible outcome...
nvidia has currently a major "bug" (they may do it intentionally wrong which makes it even worse) with HDR pass through.
the AMD user number is currently low for madVR because polaris can't deal properly with NGU so major driver bugs are less known. i'm not aware of any that can'T be easily workaround.
what i currently do is not getting any GPU right now and hope navi is a good architecture and tensor cores are not needed for whatever new thingy madshi plans or i hope for cheaper nvidia cards not using an old manufacturing process. the release of vega 7 clearly didn't help me believe navi is going to be any good...
for gaming the 580 is the current go to card in it's price range if power consumption doesn't matter to you (a 1660 uses less then half the power).
TL;DR
wait for NAVI and hope it get's better but it looks like nvidia is the vendor of choice for madVR if you want to use all of it's features.
chros73 likes this.
post #2420 of 2912 Old 03-19-2019, 02:49 AM
chros73's Avatar
Quoted: 230 Post(s)
Liked: 101
I agree with you in the 2nd part
Unfortunately, as huhn said, Radeon 7 is not meant to be a gaming GPU but AMD didn't have anything else to present this year (?) since Navi is hold back for now. Biggest issue can be power consumption and heat -> noise. If it was 2/3 of the price of an equivalent nvidia GPU, then maybe, but that's not the case. (They state that the new memory type is the really pricey one on it (compared to gddr 6) and AMD even loose money on the card! )
Hopefully Navi will be big. Under big I don't mean the fastest chips but an energy efficient powerful mid-range chip with a nice price tag. But who knows, we will see in time. If they won't announce it during computex then probably it won't happen this year.
I'm not telling to not buy one (you can send it back if you don't like it ), if you will then probably you'll be the 1st one with Radeon 7 and you can "benchmark" madvr with it
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(04.10.25+PC4:4:[email protected]/24/25/29/30/50/59/60Hz)
chros73 is online now
post #2421 of 2912 Old 03-19-2019, 02:53 AM
chros73's Avatar
Quoted: 230 Post(s)
Liked: 101
Interesting. Does your projector have HDR mode? If so, is it selected when 2160p content is used? Otherwise it doesn't make any sense.
post #2422 of 2912 Old 03-19-2019, 02:56 PM
hotrippr's Avatar
Quoted: 73 Post(s)
Liked: 33
Yeah right now isnt the best time to try to get an upgraded card. I was afraid you guys were gonna say to wait till Navi. I agree, I mean Ive had the 970 this long I can wait longer. If the 2080ti were reasonably priced I would get that but that price is just ridiculous. And not interested in getting a mid tier card as the 970 is fine at the moment. Thanks!
Sony X720E
970EVO 512GB NvMe
hotrippr is offline
post #2423 of 2912 Old 03-19-2019, 09:40 PM
SoySauceWDF's Avatar
Quoted: 48 Post(s)
I have a RTX 2080 ti and was having stuttering both during 1080p playback and downscaling 4K HDR to 1080p. Regarding 1080p, changing the preferences in the nvidia control panel to "Prefer Maximum Performance" solved the stuttering issue, as it the card was not being taxed and moving back and forth from no load to load was causing the render times to jump all over the place. Just turned VSYNC on in the control panel, will need to do more testing regarding the 4K HDR stuttering. Definitely an RTX issue as I was having no problems with my previous GTX 1070.
SoySauceWDF is offline
post #2424 of 2912 Old 03-20-2019, 01:34 AM
Quoted: 72 Post(s)
It does select the HDR mode when playing 2160p movies.
Klaus.S is offline
post #2425 of 2912 Old 03-20-2019, 02:31 AM
chros73's Avatar
Quoted: 230 Post(s)
Liked: 101
Then that's the issue, ask around in the projector topics about this if you want to use the HDR mode of the projector.
post #2426 of 2912 Old 03-20-2019, 03:06 AM
Quoted: 72 Post(s)
Thanks, will do
Klaus.S is offline
post #2427 of 2912 Old 03-20-2019, 07:10 AM - Thread Starter
Onkyoman's Avatar
Quoted: 893 Post(s)
Liked: 548
The best result will come from converting to SDR, so there is no need to send HDR to the projector. That could simplify your issue, which affects many JVC projectors.
Onkyoman is offline
post #2428 of 2912 Old 03-20-2019, 08:53 AM
Quoted: 72 Post(s)
It actually makes sense. I had some settings in madvr before and all work fine withv the 8 bit.
But have made two profiles under my projector, a HDR and a BT709. The made a if line > If (HDR) "hdr" else "bt709" and since then I have had the problems. Was a guy who told me to do it like that, so that I could use the HDR profile on the projector., to take advantage of the BT2020.
The BT709 profile is right now set to passthrough HDR.
Before I used two profiles unde processing and the if line was this. if (srcWidth <2001) and the over way around >2000.
Onkyoman can you guide me a little here?
Klaus.S is offline
post #2429 of 2912 Old 03-20-2019, 10:23 AM
Quoted: 646 Post(s)
Liked: 186
Thanks for the update. I thought I remember "prefer max performance" does something with idle clocks? Like locks them at 3d clocks instead of idle. Not sure if that is true or not. I'll look more into it.
post #2430 of 2912 Old 03-20-2019, 10:45 AM
Quoted: 48 Post(s)
You can set it to "Prefer Maximum Performance" specifically for whatever player application you are using (MPC-HC in my case) in the nvidia control panel. Monitoring the clocks with EVGA Precision, playing 1080p content, it was about 1300MHz as opposed to bouncing around from ~400Mhz up to ~2000Mhz when just using "Adaptive" power setting. So not really any power or temp concerns playing 1080p content. 4K content, with the scaling settings I'm using, was pretty much using a bunch of the card anyway so I don't think the setting has too much of an effect in that scenario.
Render times are ~4.74ms at 1080p and ~27ms downscaling 4K to 1080p.
Reply Home Theater Computers
htpc build , madvr
