Guide: Building a 4K HTPC for madVR - Page 90 - AVS Forum | Home Theater Discussions And Reviews
 903Likes
post #2671 of 3479 Old 05-03-2019, 02:55 PM
Quoted: 59 Post(s)
Liked: 2
can anyone tell me how to restore to default setting ?
Ahmadss is offline
post #2672 of 3479 Old 05-03-2019, 03:29 PM - Thread Starter
Onkyoman's Avatar
Quoted: 1073 Post(s)
Liked: 636
Originally Posted by 04rex View Post
When looking at the Graphics cards, should we be looking at the max resolution? So I notice some cards say 4096x2160 and others say 3840x2160. And some are what I assume 8k ready. The 2070 Mini I am looking at states HDMI 2.0 3840x2160 @ 60hz, by Zotac.
No, it's not relevant. I would only be concerned with having at least HDMI 2.0.
Onkyoman is online now
post #2673 of 3479 Old 05-03-2019, 03:30 PM - Thread Starter
Onkyoman's Avatar
Liked: 636
Originally Posted by Ahmadss View Post
i have i5 7500 ang 8gb ram and rx550 4gb
what is recommended setting for me ?
I don't know. Start with the defaults and try adding NGU Anti-Alias/Standard/Sharp low for chroma upscaling and NGU Sharp low for image upscaling. Repeat if you have some performance left.
post #2674 of 3479 Old 05-03-2019, 03:31 PM - Thread Starter
Onkyoman's Avatar
Liked: 636
There is a reset settings .bat file in the installation folder.
post #2675 of 3479 Old 05-03-2019, 05:06 PM
04rex's Avatar
Quoted: 331 Post(s)
Liked: 64
Perfect thank you very much. I think I am leaning towards that card then. If it looks good then I think that is the highest I can go. I looked and it said it has HDMI 2.0b.
FAMILY ROOM - Totem Tribe II LCR, JL Audio E-112, Anthem MRX 720, Apple TV, WD HDTV, Panasonic 55" Plasma
BASEMENT THEATRE - Paradigm Studio 100 v5, 690 v5, 10x4 v5, Anthem AVM 60, Outlaw Audio 7700 & 7125, 2x JTR Captivator S2s, X-Box One X, Apple TV 4K, HTPC, JVC NX-5, 106" screen
04rex is offline
post #2676 of 3479 Old 05-08-2019, 08:13 AM
Quoted: 76 Post(s)
Originally Posted by Klaus.S View Post
It could be nice with a evaluation of my settings. GPU> RTX 2080
I have made two profiles under scaling. Made one for 1080p and for 2160p.
With these settings, rendering times for 1080p is 22-23, 2160p 34-35
The settings here is not with the windows 7 overlay @mightyhuhn recommended. This is the settings I have used for some time. Still got alot to learn about all this.
Finaly got the time to play with it all again. It seems like all is back to normal again.
I wrote that 2160p rendering time was 34-35 but it is actually closer to 38. That is a little high or?
I am back to using D3D11 Native hardware decoding in LAV Video rather than DXVA2 (copy-back). Just as Onkyoman said.
Should a RTX 2080 with these settings have to high rendering time?
Settings are in this link
Klaus.S is offline
post #2677 of 3479 Old 05-08-2019, 02:38 PM - Thread Starter
Onkyoman's Avatar
Liked: 636
Your rendering times would drop if you disabled reduce random noise. I don't think it is necessary, anyways.
post #2678 of 3479 Old 05-08-2019, 03:28 PM
Quoted: 283 Post(s)
Liked: 90
Having trouble with .VOB (DVD) files to use Lav Video. It keeps using ffdshow.
Only happens with the x86 version of MPC HC (v 1.8.6).
MPC HC x64 and MPC BE (1.5.3 (build 4488)) use Lav Video.
Lav 0.74.1. x86 and x64 installed, Win10x64, GTX 1060.
No external filters enabled.
Any of the samples from here behave the same: http://www.digital-digest.com/movies...hp?type=studio
All Source Filters and Transform Filters from Internal Filters unchecked.
The MPC HC x86 and x64 have identical settings.
In Codec Tweak Tool (6.3.9):
In Preferred splitters the .VOB option is set to Lav splitters.
In Win7DSFilterTweaker > Preferred decoders: I've tried settings everything to LAV, including the MPEG-2 and DVSD (no .VOB option ), no difference. Here x86 and x64 decoders can be set independently, but even with the same settings the x86 and x64 settings identical, MPC HC x64 still plays .VOB with Lav video and the x86 with ffdshow.
Where is the setting responsible for this playing .VOB?
LE: Found it in the ffdshow codecs options.
ID:	2564314   Click image for larger version
ID:	2564316   Click image for larger version
noob00224 is online now
post #2679 of 3479 Old 05-08-2019, 07:36 PM
mightyhuhn's Avatar
Quoted: 1216 Post(s)
Liked: 450
ffdshow doesn't have proper DVD support not saying it doesn't work but there is no full support on top of it it's a dead software for over 5 years now.
d3d11 decode can't deal with dvds.
mightyhuhn is online now
post #2680 of 3479 Old 05-08-2019, 08:12 PM
Quoted: 283 Post(s)
Liked: 90
What do you mean d3d11 can't deal with dvd's?
In this screenshot it's showing Active Decoder: d3d11 native.
post #2681 of 3479 Old 05-09-2019, 01:03 AM
mightyhuhn's Avatar
Liked: 450
dvd are interlaced everything that's not PsF/progressive will turn into a disaster because madVr can't deinterlace with D3D11.
chros73 and noob00224 like this.
post #2682 of 3479 Old 05-09-2019, 01:01 PM
Quoted: 76 Post(s)
Once again thanks. That helped alot. Down to 23-24 now. So now I can actually change NGU from medium to high or very high.
Klaus.S is offline
post #2683 of 3479 Old 05-10-2019, 06:43 AM
04rex's Avatar
Quoted: 331 Post(s)
Liked: 64
Is there a new line of Nvidia cards coming out to replace the RTX2070 line? The Zotac RTX2070 I was planning on getting is on clearance now.
04rex is offline
post #2684 of 3479 Old 05-10-2019, 12:03 PM
whiteboy714's Avatar
Quoted: 1214 Post(s)
Liked: 444
No, AMD will have some cards coming out this year that will hopefully cause Nvidia to lower prices, but too soon for all that. RTX is still really new, Nvidia won't have anything for some time.
When you say clearance do you mean its on sale? Or being closed out?
whiteboy714 is online now
post #2685 of 3479 Old 05-10-2019, 01:06 PM
mightyhuhn's Avatar
Liked: 450
a Turing shrink to 7 nm is a possibility but nvidia has no need to act right now.
post #2686 of 3479 Old 05-10-2019, 01:24 PM
Liked: 444
For sure, nvidia would be crazy to budge right now.
post #2687 of 3479 Old 05-10-2019, 01:41 PM
04rex's Avatar
Quoted: 331 Post(s)
Liked: 64
No it is regularly priced, but it just says clearance next to it online. I will have to go into the store to possibly get more info. Unless it is a mistake.
04rex is offline
post #2688 of 3479 Old 05-10-2019, 03:16 PM
Liked: 444
I wouldn't worry about it personally. Any reason why Zotac? I know they often have decent pricing but their warranty is often inferior.
post #2689 of 3479 Old 05-10-2019, 08:18 PM
04rex's Avatar
Quoted: 331 Post(s)
Liked: 64
Well to be honest it is for a few reasons. My HTPC case is small, so I can only fit a certain size card. I think it is 11” max. This Zotac is a RTX 2070 Mini. So it fits. Also, it is one of the lowest priced 2070s I have found. Plus it has all the specs I would need.
That being said, if there is another option that is better and fits all that, then I would look at it for sure. I might have found an EVGA that might fit the case for $40 more. But I am already extremely over budget with the Zotac. So an extra $40 is just a really tough pill to swallow.
04rex is offline
post #2690 of 3479 Old 05-10-2019, 10:51 PM
Liked: 0
Hi all, i have read the last pages, and most seems to recommend the most expensive cards.
I am looking for a very very budget friendy HTPC and i would like to know if madVR could make the media i will play on it better.
The cheapest 4K HDR HTPC i found was the yet-to-be-released Atari VCS($239)+Windows 10, with AMD R1000 Series and iGPU Vega 3.
It looks like a better, more powerful and more versatile, device than the Nvidia Shield and it only cost $40 dollars more(albeit there is no remote control included).
So, which should be my expectations with this device and madVR ?
Like no improvement at all because of it being under powered ?
Like improving the quality of 720p to 1080p resources ?
Can i at least expect it to upscale 1080p to 4K ?
If there is no possibility to upscale, can it make it look better somehow ? Like same resolution but more sharpeness ?
Thanks for your answers, and i am sorry if this question was too low-budget for this forum
Rubytux is offline
post #2691 of 3479 Old 05-11-2019, 05:34 AM - Thread Starter
Onkyoman's Avatar
Liked: 636
The best budget options are a GT 1030, Ryzen 3 2200G Vega 8 and Ryzen 5 2400G Vega 11. They can all upscale to 4K with better quality than the Shield, but a PC is less capable for streaming apps. It depends on whether you are exclusively playing ripped sources or also relying on playback of 4K HDR Netflix or Amazon.
Rubytux likes this.
post #2692 of 3479 Old 05-11-2019, 07:41 AM
Liked: 444
Ah I see. Seems the budget always gets blown lol.
I think you'll have one less year of warranty with zotac. Hopefully it will never be an issue.
I have just been so happy with evgas RMA service I can't go anywhere else when I buy new. The fact that you can get a human on the phone in under a minute is so rare with any company these days.
I rma'd a 1080ti a month ago and they shipped out the new cards the same day.
But again hopefully it will never be an issue. Have you considered saving a few bucks and getting a 2060? Or do you know you need a 2070?
TCL 65R625 -- Denon X1400h -- Klipsch RP600m -- RP450C -- Micca M-6S 6.5 -- Dual Klipsch RW-10
post #2693 of 3479 Old 05-11-2019, 10:57 AM
Quoted: 76 Post(s)
Moving on in my get to know madvr trip.
Screen config and zoom control.
I got a 2.39:1 screen and I have done some reading about screen config and zoom control. Did read that I should be better to use this againt what I do now. Now I zoom with projector to fill the screen.
But is not sure I to do this correct.
Under screen config it is possible to move top, bottom, left and right. But not totally sure is all 4 sides have to be moved to tell madvr my screen size?
Also not sure what to under zoom control.
Anyone who use this who can help me on the way or is there a guide I am missing?
Klaus.S is offline
post #2694 of 3479 Old 05-11-2019, 11:26 AM
mightyhuhn's Avatar
Liked: 450
zotac gives 5 years.
post #2695 of 3479 Old 05-11-2019, 12:11 PM
Liked: 444
Where are you getting that info from?
https://www.zotac.com/us/page/product-warranty-policy
Plus the warranty is only for the original buyer, doesn't transfer over to the second hand market so resale value is lower, probably the lowest of all Nvidia AIBs.
ID:	2565498   Click image for larger version
post #2696 of 3479 Old 05-11-2019, 02:50 PM
04rex's Avatar
Quoted: 331 Post(s)
Liked: 64
It does always get blown with this hobby. Lol.
I will take another look again just in case.
I want to get the best performance I can to avoid any future upgraditis, I know funny isn’t it. Like that will happen. Lol. I was gonna get a 2060 but found this 2070 that actually fits. 2080 is 100% out based on price and size. So I figured if I’m gonna do it, I should do it and go for the 2070. If it gets more performance and better quality, then I figure why not. But of course my bank account has a different opinion.
04rex is offline
post #2697 of 3479 Old 05-11-2019, 02:56 PM
Liked: 444
I am totally with you. I hate skimping a bit and then regretting it down the road.
post #2698 of 3479 Old 05-12-2019, 05:12 AM - Thread Starter
Onkyoman's Avatar
Liked: 636
screen config is for simulating screen masking, where the light is overshooting the screen and you want it to be scaled back onto the screen.
The zoom control options are summarized in the madVR guide in the first post. I don't know which options work best together because I have never tried them myself. They could probably be streamlined and consolidated.
Keep in mind, you have to use DXVA2 (copy-back) decoding in LAV Video to use zoom control. That can slow down HDR tone mapping.
post #2699 of 3479 Old 05-12-2019, 06:23 AM
mightyhuhn's Avatar
Liked: 450
here: https://www.zotac.com/at/page/product-warranty-policy
no granting warranty when resale is illigel in the EU.
on the other hand EVGA has a very bad track record in the US and a very good in the EU and both doesn't matter because the failure rate of GPU is so low that even 5 more euro is still not worth it.
sure... i can't even name all AIB.
post #2700 of 3479 Old 05-12-2019, 06:31 AM
Liked: 444
EVGA has the best track record in the USA, I don't even think you could argue for a close second.
And not sure about the EU but in the states plenty companies won't warranty their product after original owner.
Because you haven't rma'd many cards doesn't mean a good warranty is but worth much. Go through one terrible experience with someone like Asus and I bet you take that back.
And again if your watch the second hand market. Zotac is one of the hardest to sell. They often sit longer and have to be sold for less.
At least on the tech sites here in the US.
Reply Home Theater Computers
htpc build , madvr
