Guide: Building a 4K HTPC for madVR - Page 95 - AVS Forum | Home Theater Discussions And Reviews
 903Likes
post #2821 of 3479 Old 06-07-2019, 05:53 AM
markmon1's Avatar
Quoted: 5225 Post(s)
Liked: 3395
Originally Posted by Ahmadss View Post
Hi
I have gtx1060 6gb with I5 7500 and ssd drive
I want to use a settings in madvr only to improve the 4k movies quality
So whats to focus on, and what setting
Display is sony x930e
With that display, there's probably not much needed to be done in madVR. You could try one of the builds with dynamic tone mapping which will turn regular HDR into something more like dolby vision. I imagine your target nits on that TV is about 1000.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is online now
post #2822 of 3479 Old 06-07-2019, 08:18 AM
chros73's Avatar
Quoted: 315 Post(s)
Liked: 140
I have gtx1060 6gb with I5 7500 and ssd drive. Display is sony x930e
I can upload my settings during the weekend or so (using the same GPU with a LG B8).
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(04.10.25+PC4:4:[email protected]/24/25/29/30/50/59/60Hz)
chros73 is offline
post #2823 of 3479 Old 06-07-2019, 09:00 AM - Thread Starter
Onkyoman's Avatar
Quoted: 1073 Post(s)
Liked: 637
Hi
As someone replied in your other thread, what are you trying to improve? Is the image too dim, or are the highlights clipped or is the image not sharp enough?
Onkyoman is online now
post #2824 of 3479 Old 06-08-2019, 03:07 AM
aerodynamics's Avatar
Quoted: 280 Post(s)
Liked: 129
Originally Posted by long_pn View Post
I'm little surprised that a gtx 2060 can cause some trouble by downscaling [email protected] to 1080p. I have no issue with my gtx 1060 6gb, when using DXVA2 Native decoding and HDR tone mapping with SIM1D, sharpening is not needed since 4k very sharp already.
Are you using the test builds of MadVR ?
I'm using v0.92.17. My setup is having trouble in particular with "The World in HDR" demo file which is [email protected] HDR. It has no problem with the "Sony Camp 4k" file which is [email protected] SDR. I have tried DXVA2 Native and the result is the same. At this point, I'm not too worried since all of my 4k HDR content is 24fps. Downscaled 4k on my projector looks a bit soft compared to my 4k TV so the sharpening makes it virtually indistinguishable.
Viewsonic PX800HD | 100” Snowhite UST Screen | Pioneer Elite LX-503 | HDFury Diva | 7.2.4 Surround | Sony Core Series LCR + Atmos | Cambridge Min 12 Side Surrounds | Monoprice Rear Atmos Surrounds | Bic V1020 x2
aerodynamics is offline
post #2825 of 3479 Old 06-08-2019, 04:56 AM - Thread Starter
Onkyoman's Avatar
Liked: 637
It could be the codec. Check the MediaInfo.
post #2826 of 3479 Old 06-09-2019, 10:47 AM
Quoted: 77 Post(s)
Hi,
I am having a problem with movies/serie with 25.000 fps (like blue planet 2). Sometimes it shows them in 50.00 and everything works. But often there is not comming a picture on the screen.
Setup HTPC > Marantz 8802a > JVC X7500 If I look under display modes in madvr the 1080p 25.00 mode is missing. All other modes are there. I upscaling to 2160p so when that mode is there I can't see that should be the problem?
The funny thing is that if I run my htpc to a pc screen directly there is no missing mode and all seems to work.
So what is wrong here?
Klaus.S is offline
post #2827 of 3479 Old 06-09-2019, 12:19 PM - Thread Starter
Onkyoman's Avatar
Liked: 637
I'm not sure. Go to the madVR guide at the top of the first thread and find the display modes section. Ensure you have entered all of the relevant 2160p display modes and then check what display modes are reported in Windows using the instructions provided.
Did you create a custom resolution that may have caused the loss of any display modes?
post #2828 of 3479 Old 06-10-2019, 12:26 PM
chros73's Avatar
Quoted: 315 Post(s)
Liked: 140
Here are my settings using the same (underclocked) GPU:
- d3d11 mode in LAV video (madvr image processing is much faster compared to the other modes)
- hdr passthrough to 4k hdr display
- in nVidia panel
-- power management set to "Adaptive"
-- output: RGB, FULL, 12bit
Profile rules under scaling algorithms:
Code:
if (srcHeight <  577) and (deintFps <  26) "0576p25"
if (srcHeight <  577) and (deintFps <  31) "0576p30"
if (srcHeight <  577) and (deintFps <  51) "0576p50"
if (srcHeight <  577) and (deintFps >= 51) "0576p60"
if (srcHeight <  721) and (deintFps <  26) "0720p25"
if (srcHeight <  721) and (deintFps <  31) "0720p30"
if (srcHeight <  721) and (deintFps <  51) "0720p50"
if (srcHeight <  721) and (deintFps >= 51) "0720p60"
if (srcHeight < 1080) and (srcHeight > 1030) and (srcWidth < 1920) and (deintFps <  26) "1079p25"
if (srcHeight < 1081) and (deintFps <  26) "1080p25"
if (srcHeight < 1081) and (deintFps <  31) "1080p30"
if (srcHeight < 1081) and (deintFps <  51) "1080p50"
if (srcHeight < 1081) and (deintFps >= 51) "1080p60"
if (srcHeight < 2161) and (deintFps <  26) "2160p25"
if (srcHeight < 2161) and (deintFps <  31) "2160p30"
if (srcHeight < 2161) and (deintFps <  51) "2160p50"
if (srcHeight < 2161) and (deintFps >= 51) "2160p60"
else                                       "Default"
Profile rules under rendering (there's spare GPU power with current settings, hence the different dithering algo for >[email protected] content):
Code:
if (srcWidth > 1919) and (deintFps <  26) "1080p25"
else "Default"
ID:	2578540   Click image for larger version
ID:	2599494   Click image for larger version
ID:	2599496   Click image for larger version
ID:	2599498   Click image for larger version
ID:	2599502   Click image for larger version
ID:	2599504   Click image for larger version
ID:	2599506   Click image for larger version
ID:	2599508   Click image for larger version
ID:	2599512   Click image for larger version
ID:	2599514   Click image for larger version
ID:	2599516   Click image for larger version
ID:	2599518   Click image for larger version
ID:	2599522   Click image for larger version
ID:	2599524   Click image for larger version
ID:	2599526   Click image for larger version
ID:	2599528   Click image for larger version
ID:	2599532   Click image for larger version
ID:	2599534   Click image for larger version
ID:	2599536   Click image for larger version
ID:	2599538   Click image for larger version
ID:	2599546   Click image for larger version
ID:	2599550   Click image for larger version
ID:	2599552   Click image for larger version
ID:	2599554   Click image for larger version
ID:	2599558   Click image for larger version
ID:	2599560   Click image for larger version
ID:	2599562   Click image for larger version
ID:	2599564   Click image for larger version
ID:	2599568   Click image for larger version
ID:	2599570   Click image for larger version
ID:	2599572   Click image for larger version
ID:	2599574   Click image for larger version
ID:	2599578   Click image for larger version
ID:	2599580   Click image for larger version
ID:	2599582   Click image for larger version
ID:	2599584   Click image for larger version
ID:	2599588   Click image for larger version
ID:	2599590   Click image for larger version
ID:	2599592   Click image for larger version
ID:	2599594   Click image for larger version
ID:	2599598   Click image for larger version
ID:	2599600   Click image for larger version
ID:	2599602   Click image for larger version
ID:	2599604   Click image for larger version
ID:	2599608   Click image for larger version
ID:	2599610   Click image for larger version
ID:	2599612   Click image for larger version
ID:	2599614   Click image for larger version
ID:	2599618   Click image for larger version
ID:	2599620   Click image for larger version
ID:	2599622   Click image for larger version
ID:	2599624   Click image for larger version
ID:	2599628   Click image for larger version
ID:	2599630   Click image for larger version
ID:	2599632   Click image for larger version
ID:	2599634   Click image for larger version
ID:	2599638   Click image for larger version
ID:	2599640   Click image for larger version
ID:	2599642   Click image for larger version
ID:	2599644   Click image for larger version
ID:	2599648   Click image for larger version
ID:	2599650   Click image for larger version
ID:	2599652   Click image for larger version
ID:	2599654   Click image for larger version
ID:	2599658   Click image for larger version
ID:	2599660   Click image for larger version
ID:	2599662   Click image for larger version
ID:	2599664   Click image for larger version
ID:	2599668   Click image for larger version
ID:	2599670   Click image for larger version
ID:	2599672   Click image for larger version
ID:	2599674   Click image for larger version
ID:	2599678   Click image for larger version
ID:	2599680   Click image for larger version
ID:	2599682   Click image for larger version
ID:	2599684   Click image for larger version
ID:	2599688   Click image for larger version
ID:	2599690   Click image for larger version
ID:	2599692   Click image for larger version
SuperFist, Killroy and noob00224 like this.
chros73 is offline
post #2829 of 3479 Old 06-10-2019, 01:51 PM
Quoted: 77 Post(s)
All settings seems to be good. All relevant display modes a typed in. But 1080p25 are missing costume modes. It is like it is not on the gpu. It is on the 2160p on the gpu.
Where do I see what is reported in windows?
Klaus.S is offline
post #2830 of 3479 Old 06-10-2019, 04:36 PM - Thread Starter
Onkyoman's Avatar
Liked: 637
The steps to see the available display modes in Windows are in the madVR guide under display modes.
post #2831 of 3479 Old 06-10-2019, 09:03 PM
mightyhuhn's Avatar
Quoted: 1216 Post(s)
Liked: 450
stop this nonsense it's just wrong...
mightyhuhn is offline
post #2832 of 3479 Old 06-11-2019, 12:53 AM
chros73's Avatar
Quoted: 315 Post(s)
Liked: 140
No, it isn't on my system.
Edit: most "visible" with 23p 4k BD remuxes (high bandwidth), GPU 1060 6GB (max, underclocked) freq is 1544Mhz (checked with nvidiainspector), using "2160p25" profile (only chroma upscaling is applied: NGU Sharp HQ + SuperRes 3):
- DXVA2 copyback : ~34ms, GPU usage ~90%
- D3D11 : ~31.50ms, GPU usage ~80%
chros73 is offline
post #2833 of 3479 Old 06-11-2019, 03:52 AM
mightyhuhn's Avatar
Liked: 450
if i take these number which doesn't show the whole image anyway you need about 10% of your GPU an older IGPU doesn't even have 10 % of your GPU so it should be incaplabe of doing this what so ever and they can still do a copyback operation even through is really shows now.
post #2834 of 3479 Old 06-11-2019, 06:50 AM
BondDonBond's Avatar
Quoted: 733 Post(s)
Liked: 660
New to MadVR so excuse the newbe question but two things.
1: Interesting quirk where my JVC and my PC resolution reports the high resolution but MadVR says the projector is one step down. The projector is getting the high resolution. This does not allow me to put in the resolutions to use.
2: Running MadVR with the same movie they are dark. The nits match my display. Do I need to change something. I gone through the settings.
I have the 2080 card.
Home Theater: JVC RS2000, Stewart 120" 2:35 StudioTech 130, Panamorph DCR Lens, B&W 802 Nautilus, HTM1, 4-B&W 805's for surround, 4-Martin Logan 22's ceiling speakers ATMOS, 2- PB-16 Ultra Subs, Marantz 8802A, MacIntosh 8207 AMP and Proceed AMP 5, Panasonic 820, Apple TV, XBox One, HTPC with MadVR, Qnap NAS
BondDonBond is offline
post #2835 of 3479 Old 06-11-2019, 07:28 AM - Thread Starter
Onkyoman's Avatar
Liked: 637
I don't know what you are trying to say. Can you post an image of the madVR OSD (Ctrl + J) while playing a file?
post #2836 of 3479 Old 06-11-2019, 09:57 AM
ddgdl's Avatar
Quoted: 337 Post(s)
Liked: 309
If you are willing to take the time, use Soulnight's measurement and dynamic clipping tool to measure your movie file. Input your real nits into the target nits field, and leave everything else at the default. Then check to see if it is brighter.
I found Soulnight's tool to be more user friendly while madvr is testing the latest beta
BondDonBond likes this.
ddgdl is online now
post #2837 of 3479 Old 06-11-2019, 10:22 AM
Keith AP's Avatar
Quoted: 108 Post(s)
Liked: 83
I'll take a stab at 2: - check your Nvidia Control Panel - under "Display->Change resolution" - are you using NVIDIA color settings? If not, switch to that and make sure the "Output dynamic range" is set to "Full". This may help if MadVR device properties is set to PC Level 0-255.
SuperFist and BondDonBond like this.
Marantz AV7702mkII | Emotiva XPA-5 Gen3 | miniDSP 2x4HD for BEQ/BOSS filters
PSA MTM-210 (L/C/R) | Polk Monitor 35B (SR/SL)
Epson 5050UB - BenQ W1070 w/ Panamorph CineVista Lens | Oppo BDP-103
HSU VTF-3MK5 (dual subs)
Seymour Center Stage UF 2.35 AT Screen
Keith AP is online now
post #2838 of 3479 Old 06-11-2019, 11:45 AM
jbarteli's Avatar
Quoted: 213 Post(s)
Liked: 52
I'm so done with the rtx series..... always comes down to stuttering eventually.......one day everything is working great and then without any changes the stuttering is back.
I now got the rtx2060, the gtx1070 doesn't have this problem right?
jbarteli is online now
post #2839 of 3479 Old 06-11-2019, 12:16 PM
neo_2009's Avatar
Quoted: 351 Post(s)
Liked: 257
I'm using 418.91 with RTX 2060 without any stuttering problem.
I've updated 3 times ( 419.17/35 and 67 i think), all gave me stuttering problems, so i gave up and i'm using 418.91 since without problems.
Please also see this post: https://forum.doom9.org/showpost.php...&postcount=151
neo_2009 is offline
post #2840 of 3479 Old 06-11-2019, 12:41 PM
jbarteli's Avatar
Quoted: 213 Post(s)
Liked: 52
Ok thanx, will try that.
post #2841 of 3479 Old 06-11-2019, 12:44 PM
neo_2009's Avatar
Quoted: 351 Post(s)
Liked: 257
I also used this excellent utility, that allows you to strip most of the junk that's included on Nvidia oficial driver: https://forums.guru3d.com/threads/nv...tility.423072/
SuperFist likes this.
neo_2009 is offline
post #2842 of 3479 Old 06-11-2019, 09:29 PM
Liked: 0
I'm a little confused. I have two separate builds. One has a GTX 1080 and can play HDR and Dolby Vision rips and tonemap to SDR no problem. The seconds sports a GTX 670 and can't playback Dolby Vision rips but can for regular HDR. This is playing back on a non HDR screen.
Any ideas?
This is through MadVR with MPC-HC.
Timothy Le Masson is offline
post #2843 of 3479 Old 06-11-2019, 11:33 PM
SirMaster's Avatar
Quoted: 669 Post(s)
Liked: 406
Hmm, I’ve got an RTX 2060, and 2 friends of mine have a 2070 and 2080Ti respectively and none of us have any stuttering via madVR.
I’m also using the latest drivers on my 2060 without any problems.
SirMaster is online now
post #2844 of 3479 Old 06-12-2019, 02:33 AM
chros73's Avatar
Quoted: 315 Post(s)
Liked: 140
Have you tried out on your system with a >60GB 4k UHD Bluray remux?
chros73 is offline
post #2845 of 3479 Old 06-12-2019, 03:15 AM
Quoted: 289 Post(s)
Liked: 90
I had a similar problem playing 4K HDR 60FPS and it was due to the PCI Express bus being stuck at x4, where it should be at x16. So bandwith problem.
Turned out the CPU was causing it.
GPU Z displays the PCI Express Bus multiplier. You can press the question mark next to the Bus and GPU Z will run a small test which will max it out (some cards lower it to x4 during idle). It should go up to x16 immediately.
https://www.google.com/search?q=gpu+...Gr0LSC482-OkM:
If anyone wants to test 4K HDR 60 FPS (or other high fps) samples can be found online, here are a few examples:
https://4kmedia.org/sony-swordsmith-hdr-uhd-4k-demo/
https://4kmedia.org/lg-daylight-hdr-uhd-4k-demo/
https://kodi.wiki/view/Samples#4K_.28UltraHD.29
In the last link, it's under 4 4K (UltraHD), number 15.VP9 Profile 2 HDR #1 The World in HDR (in MKV, downloaded from YouTube) (thanks wesk05)
noob00224 is offline
post #2846 of 3479 Old 06-12-2019, 04:17 AM
mightyhuhn's Avatar
Liked: 450
i'm was testing copyback performance with card like an 6770.
the size of the source file is pretty much meaningless it's like 0.01 % of the data transferred when doing copyback.
this madness stated when madshi added nit measurement which pretty much turns into an decoder benchmark hence d3d11 is much faster PCIe is simply the bottleneck.
just to make that obsoletely clear i'm not saying that copyback has the same speed but it is clearly in the real not significant on performance cards the numbers are deceiving. uploading "textures" is simply something GPU are good at and they learned downloading to over the past 10 years. d3d11 makes a more notable difference for iGPU which still can do the copyback operation and they have about 5 or more % of the performance of an 1060.
and you have to remember the user here recommending an interface with hard limitation like d3d11 is not a great idea even if it is faster it's not worth it even if it is just for compatibility.
post #2847 of 3479 Old 06-12-2019, 05:15 AM - Thread Starter
Onkyoman's Avatar
Liked: 637
Any ideas?
There is no Dolby Vision support for MPC-HC and madVR. And there is no HEVC decoder on the GTX 670. I would think the HEVC decoder would make the difference when playing back HDR files.
post #2848 of 3479 Old 06-12-2019, 10:16 AM
Liked: 0
I know this and this was I am confused. Even though DV isn't 'supported' the layer is still being converted to SDR on the GTX 1080. And even though the GTX 670 doesn't do HDR, why can it also convert it to SDR.
My question is why can I playback DV files on the 1080 but not on the 670. But regular static HDR files will play on both.
post #2849 of 3479 Old 06-12-2019, 10:54 AM - Thread Starter
Onkyoman's Avatar
Liked: 637
The only thing that is being converted in both cases is the HDR10 layer. If you check the madVR OSD, it will show you the static HDR10 MaxCLL and MaxFALL that is being reported by the source.
Check the bitrate on the sources that won't play. That should provide your answer.
post #2850 of 3479 Old 06-12-2019, 12:09 PM
Quoted: 77 Post(s)
The only mode that is not there (in windows) is 1080p25. All other are there also 2160p25.
1080p50 is there, so don't get why I can't play these 25.00 movies. Should it nomally not just double the value so 25.00 movies would be played as 50.00? That mode is there.
Really lost here
Klaus.S is offline
Reply Home Theater Computers
htpc build , madvr
