HTPC vs PopCorn Hour A-200 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-08-2016, 09:49 PM - Thread Starter
hussain's Avatar
Quoted: 58 Post(s)
Liked: 25
After growing tired of my POPCORN Hour glitches, I finally decided to build an HTPC with Plex Home Theater.
HP N54l PC
ATI 5450 GPU
8 GB Ram
I have 135" screen, HW55 Projector and Onkyo 5010 receiver.
As soon as I moved to the HTPC I realized.
1. At the same volume the db level of sound was much lower
2. The Video Quality was way below par as compared to my PopCorn Hour.
PHT is set to switch referesh rates. What am I doing wrong.
hussain is offline
post #2 of 5 Old 05-09-2016, 09:49 AM
Charles R's Avatar
Liked: 817
1. Volume level is relative and irrelevant.
2. "way below par" doesn't help... without knowing the actual differences you can't address the issue. First stop would be to verify source/output resolution and for fun you might boot OpenELEC off of a USB flash drive and see how Kodi "looks"
125" Projection | 5.2.4 Audio | Shield TV | LibreELEC/ODROID-C2 Kodi Media Client | Ubuntu/ODROID-XU4 NAS/Server | 65" LG OLED TV | TiVo | Shield TV |
| Water cooled Threadripper & Radeon VII, NVMe PC - 43" 4K IPS Panel |
Charles R is offline
post #3 of 5 Old 05-09-2016, 09:07 PM - Thread Starter
hussain's Avatar
Quoted: 58 Post(s)
Liked: 25
1. For the same movie, the volume at the receiver with popcorn hour around 60% gives the same db level as 80% for htpc.
2. The colours for htpc are dull, skin tones are flushed out, video is slightly pixelated. Same movie A-B test between htpc vs popcorn hour the difference is night and day. Suffice to say that even my wife walked in and was able to notice the difference in picture quality.
hussain is offline
post #4 of 5 Old 05-10-2016, 06:41 AM
Charles R's Avatar
Liked: 817
For the former you might verify the video levels the PC is outputting and the levels the display is set to receive. Either PC (0-255) or Video (16-235) levels have to be maintained through the entire chain. If not, you'll typically have a washed out or crushed image. In most cases pixels speak to resolution...
post #5 of 5 Old 05-10-2016, 07:11 AM
TornadoTJ's Avatar
Quoted: 1950 Post(s)
Liked: 626
Another common mistake that could cause these errors is leaving the video card control panel to default values. Most control panels come with the default of having a bunch of video processing turned ON rather than OFF, such as dynamic/adaptive contrast, color enhancement, image enhancement (which one of the items on Intel video is Skin Tone Enhancement), etc. These need to all be changed to disabled, or you will have a mess of a display.
TornadoTJ is offline
Reply Home Theater Computers
