MCEBuddy 2.3 issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 09-29-2016, 05:59 AM - Thread Starter
Toys7505's Avatar
Quoted: 72 Post(s)
Liked: 27
MCEBuddy 2.3 issues
Hello ALL -
Currently have an issue with MCEBuddy converting a WTV file. I can convert it to MKV (preferred format) with no problem. It will play through Emby just fine. My problem is getting MCEBuddy to keep the Dolby Digital audio track. For some reason it keeps taking it down to 2channel stereo. I have made sure the Mulitchannel Box is "checked" under advanced options - but still get 2channel audio when playing it back as a MKV. Thought maybe if I changed it to MP4, it might work. End result was the same, 2channel stereo during playback after being converted.
Am I doing something wrong here? Tried searching on the interweb but haven't found the answer I'm looking for. Anyone have any suggestions? Or even another type of converter you use with success in keeping the original Audio track intact?
Let me know......
Toys
Denon AVR-3311CI, Denon DVP-602CI, B&K Reference 200.7 S2, Belkin PF60
Sony BDP-S5000ES, Silverstone HTPC (6 Tuner DVR & 10 TB Media)
PSB Stratus Minis, PSB Stratus C6, PSB Alpha S surround, James Subwoofer EMB-1200
Sharp LC-70LE755U, Harmony 880 Remote
Toys7505 is offline
post #2 of 12 Old 09-29-2016, 06:36 AM
TornadoTJ's Avatar
Quoted: 1952 Post(s)
Liked: 626
Mine keeps the multi-channel track. I am not converting to MKV though, I go to AVI. I used to have a Roku 3, and AVI worked better for me. Since they still play back fine on my Shields, I never changed the format.
I don't have access to my settings right now, but if you don't get an answer over the next few days, I will take a look one evening.
TornadoTJ is offline
post #3 of 12 Old 09-29-2016, 06:51 AM - Thread Starter
Toys7505's Avatar
Quoted: 72 Post(s)
Liked: 27
Hey thanks for responding. I'll give AVI format a try and see if that changes things. I'll report back later with results.
Toys
Toys7505 is offline
post #4 of 12 Old 09-29-2016, 08:41 AM
cburbs's Avatar
Quoted: 159 Post(s)
Liked: 39
If you download media info select that file, right click, select media info... what does the info say for audio stream track?
I have been testing different settings recently and if I check multichannel audio say for "The Blacklist" and MKV Normal quality I get two audio streams :ac-3/AC-3.
Main one being English, 384kbs, 48.0 kHz, 6 channels, AC-3.
I have not tested if this plays back as stereo or not though.
From here - https://sourceforge.net/p/mcebuddy2x...mmon%20Issues/
My original video has 6 channel/multichannel audio but my converted file only has stereo/2 channel audio
Cause
MCEBuddy by default limits all the output audio to 2 channel audio (stereo) to preserve compatibility with many 3rd party players and Windows Media Player (which doesn't support multichannel audio)
Resolution
In MCEBuddy, in the Conversion Tasks page, under Advanced Settings, enable Multichannel Audio. This will tell MCEBuddy to output multichannel audio if the source video has multichannel audio.
"You’re KILLIN’ ME Smalls! "
Sony 55EX500 Settings
cburbs is offline
post #5 of 12 Old 09-29-2016, 10:22 AM
garnuts's Avatar
Quoted: 100 Post(s)
Liked: 69
Under Volume settings I don't check 'Multichannel audio', I check 'Select best soundtrack' to get 5.1 Dolby Digital output.
Normally I leave it as a .wtv file, but I have converted to MP4 and MKV and still get 5.1 with this setting.
When I first started using MCEBuddy, I vaguely remember running into what you have because 'Multichannel' seems like it would be the correct setting but is wasn't!
Also, in the next setting down 'Audio Language', I have 'English' selected. I seem to remember that leaving it 'Default' or 'Original' also caused some issue.
Living Room: Marantz 6013, XPA-5, 7.1.4 Polk RTiA9, CSiA6, FXiA4, OWM3, RSL C34E, SVS PC12+, 4 Shakers, Epson 5050, VApex 92”, Sony 65X900F, Sony X800, Xbox360, FireStick 4K, Roku Ultra, Odroid-N2. Bedroom: Denon 3600, 5.1.4 Polk: LSiM 703, LSiM 704, RTiA1, OWM3, SVS SB12-NSD x 2, LG OLED65B8, Xbox 360, Roku Ultra, Shield, FireStick 4K. Home Office: Onkyo 707, Polk: RTiA3, CSiA4, Monitor 70's, Yamaha SW315 x 2, Turntable, Triple Monitors.
garnuts is offline
post #6 of 12 Old 09-30-2016, 08:55 AM - Thread Starter
Toys7505's Avatar
Quoted: 72 Post(s)
Liked: 27
Hi - What version are you using? Cause I don't have that option - "Select Best Soundtrack".
Toys
Toys7505 is offline
post #7 of 12 Old 09-30-2016, 09:01 AM - Thread Starter
Toys7505's Avatar
Quoted: 72 Post(s)
Liked: 27
OK - UPDATE:
So I had some success (finally!). I have an episode of Superstore recorded by WMC that is in Dolby Digital. I have "checked" my format as AVI (for right now), have "checked" Multichannel Audio, and have changed the Language "Default" to English. Let MCEBuddy do its thing. I just played back the episode and my AVR displays Dolby Digital as the incoming signal - HOORAAY! Now to move on to a couple other recorded items that are longer in time that I want to keep permanently.........fingers crossed here
I also DL MediaInfo - and it shows the AC3 audio track as 6 channel vs the other unsuccessful attempts as AC3 audio - 2 channel stereo
Toys
Toys7505 is offline
post #8 of 12 Old 09-30-2016, 09:50 AM
garnuts's Avatar
Quoted: 100 Post(s)
Liked: 69
Toys
I'm using version 2.4.5 (Beta 5). I started on 2.4.3, and 'Select Best Soundtrack' was on that version too.
If you do upgrade, check the upgrade instructions. After a certain version you can do an in-place upgrade, however, for older versions you need you uninstall and then reinstall the newer version.
Here is what the volume settings look like:
Name:	MCEBuddy Audio Settings.PNG
garnuts is offline
post #9 of 12 Old 09-30-2016, 10:56 AM
TornadoTJ's Avatar
Liked: 626
The latest version requires an uninstall also. But, all the config stays there, you don't have to start over.
post #10 of 12 Old 09-30-2016, 01:02 PM
cburbs's Avatar
Quoted: 159 Post(s)
Liked: 39
I'm using version 2.4.5 (Beta 5) as well.
cburbs is offline
post #11 of 12 Old 09-30-2016, 02:13 PM
garnuts's Avatar
Quoted: 100 Post(s)
Liked: 69
Thanks for catching that. That's why I don't rely on my memory like I used to Older versions you had to manually backup configuration settings, however newer versions you still have to uninstall/reinstall, but settings are retained:
":Please Read Before Installing MCEBuddy 2.4.4
If you have a previous version of MCEBuddy, cancel this installation and perform the following:
• Stop MCEBuddy, close the application and then Uninstall the existing version
NOTES on Upgrading (Uninstalling/Reinstalling) from Older Versions:
• If you are upgrading from 2.2.3 or newer MCEBuddy preserves the History file and transfers the settings from your MCEBuddy.conf while uninstalling/reinstalling. MCEBuddy also backsup the configuration files (mcebuddy.conf and profiles.conf) as a safety measure. The files are placed in the installation directory with an “.old” extension. PLEASE DO NOT BLINDLY REPLACE THE NEW CONFIGURATION FILES WITH THE OLD FILES AS PARAMETERS IN THE NEW FILES ARE ADDED/UPDATED WITH EACH RELEASE."
• If you are upgrading from 2.2.6 or newer MCEBuddy preserves the Comskip.ini file restores the file while uninstalling/reinstalling. (as of 2.3.1 it is restored as comskip.ini.old)
• • If you are upgrading from 2.2.1 or older then you need to manually backup and restore the coniguration files (mcebuddy.conf and profiles.conf) if you wish to preserve your settings. PLEASE DO NOT If you are upgrading from 2.2.1 or older then you need to manually backup and restore the coniguration BLINDLY REPLACE THE NEW CONFIGURATION FILES WITH THE OLD FILES AS PARAMETERS IN THE NEW FILES ARE ADDED/UPDATED WITH REACH RELEASE"....
garnuts is offline
post #12 of 12 Old 10-05-2016, 09:22 PM
cburbs's Avatar
Quoted: 159 Post(s)
Liked: 39
I am using MKV Normal Quality
Multichannel audio selected
Audio Language - English
This gives me the (AC-3) audio stream.
Same above settings and MP4 NQ settings give me aac audio.
cburbs is offline
Reply Home Theater Computers
