Is it possible to rip a DVD to a computer without encoding it again? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Foxbat121
post #1 of 9 Old 08-24-2017, 03:35 PM - Thread Starter
Liked: 0
So I have some home movies on VHS-C that I've converted to DVD. To my understanding, that means they've been encoded - transferred from analog to digital. There's a bit of compression here obviously, but there isn't really a way to avoid that, since they need to be converted to digital.
Now, I know there's software like MakeMKV and ByteCopy which transcode DVDs into another digital format, compressing the data once again. My question is - is there any way to simply grab the data off of a DVD without compressing again? If the DVD is already a digital format (MPEG-2, I believe), why do I need to convert it again, and do another round of compression? If someone could explain it to me, that would help a lot.
Sean
seanmcnally is offline
post #2 of 9 Old 08-24-2017, 03:41 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 480
Sean
MakeMKV does not re-compress the video unless you specifically tell it to. It simply take the MPEG-2 DVD video and wrap into a mkv file, retain the original video and audio. This is exactly the tool you want.
lockdown571 likes this.
Foxbat121 is online now
post #3 of 9 Old 08-24-2017, 04:32 PM
bryansj's Avatar
Quoted: 1753 Post(s)
Liked: 789
That is true. MakeMKV just wraps the original streams into a new (mkv) container. The process is lossless.
bryansj is offline
post #4 of 9 Old 08-25-2017, 06:18 AM
Kelson's Avatar
Quoted: 2226 Post(s)
Liked: 1366
Actually, you can't tell it to. MakeMKV has no facility to re-compress anything. Just rip and re-pack into MKV. I use it for all my DVD's. Re-compession requires another utility, like Handbrake, for example.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #5 of 9 Old 08-25-2017, 10:08 AM
dschlic1's Avatar
Quoted: 158 Post(s)
Liked: 53
You can also copy the DVD to your computer as an iso file. Many players will use that just the same as a DVD.
LG OLED65B6P TV, Marantz SR7012 AV receiver, Sony UBP-X700 Player, Klipsch F-30 speaker system
dschlic1 is offline
post #6 of 9 Old 08-25-2017, 04:57 PM
grittree's Avatar
Quoted: 444 Post(s)
Liked: 270
Yup. The files on the DVD can be copied to your PC. Then can be played by VLC or other. Was this a trick question?
grittree is online now
post #7 of 9 Old 08-26-2017, 08:11 AM
Kelson's Avatar
Liked: 1366
No, but you gave kind of a trick answer. The files on the DVD are encrypted. VLC can play them because it has DCSS built in to decrypt on the fly. This is by no means a general solution as most other utilities do no have DCSS built in to handle encrypted DVD files.
- kelson h
Kelson is offline
post #8 of 9 Old 08-26-2017, 09:25 AM
ajhieb's Avatar
Quoted: 1037 Post(s)
Liked: 698
If it was DVDs that were converted from VHS, then they most likely aren't encrypted.
ajhieb is offline
post #9 of 9 Old 08-26-2017, 10:11 AM
Kelson's Avatar
Liked: 1366
Yes, you are quite correct. I didn't recall from the OP that he was referring to personal content captured onto DVD.
My bad. @grittree
- kelson h
Kelson is offline
Reply Home Theater Computers
