Flexraid flxr folders - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-31-2017, 08:15 PM - Thread Starter
MrPictureman's Avatar
Hello
Can someone walk me through hijacking a hard drive in Flexraid to get to the flxr folders I did a cut and past from my server to another drive on my computer and all I got was empty folders so I'm hoping that the files are still in the flxr folders. I did see someone mention hijacking a drive and adding a drive letter to it and than once I'm done remove the drive letter and it will go back into my pool? Sounds easy enough but I have no clue how to do that can someone be so kind as to walk me through it step by step? I would greatly appreciate it
Thank you
MrPictureman is offline
post #2 of 9 Old 11-01-2017, 08:26 AM
mrfattbill's Avatar
Quoted: 146 Post(s)
Liked: 106
Originally Posted by MrPictureman View Post
Hello
Thank you
Just go into disk manager in windows and give the drive you need a letter and your stuff should be visible.
Bill
mrfattbill is offline
post #3 of 9 Old 11-01-2017, 08:55 AM - Thread Starter
That takes it out of the pool how is it added back in by just removing the letter and how do you remove the letter? I don't want to go back in and create a new DRU
post #4 of 9 Old 11-02-2017, 10:59 AM
mrfattbill's Avatar
Quoted: 146 Post(s)
Liked: 106
Adding the drive letter doesn't remove it from the pool it just makes the data available in windows explorer like any other hard drive.
Bill
post #5 of 9 Old 11-02-2017, 02:26 PM - Thread Starter
Bill
Thank you how do you remove the drive letter once I'm done so that it goes back into the pool? I assume I stop the flexraid pool correct?
post #6 of 9 Old 11-03-2017, 11:38 AM
mrfattbill's Avatar
Quoted: 146 Post(s)
Liked: 106
I would stop the pool although not sure it really matters. When done just un-assign it the same way you assigned it in the WINDOWS disk management.
Bill
post #7 of 9 Old 11-28-2017, 05:14 PM - Thread Starter
Bill
Thanks guys I did experiment and I went to rename the hard drives and found ADD which I tested on one drive I left the original name and just added the new name ie drive D. I was able to pull it out of the pool by doing this. I then did a search for the two folders names which I still had and could not find. So I went back to rename the hard drive and saw that I could delete out the new name Drive D and retain the original name. I started up the pool again and everything was back the way it was supposed to be. Feeling confident I went back in and followed the same process on a couple more drives checking the newest least filled drives first and I found the folders fully intact and copied and pasted the folders to an attached external hard drive. Everything went perfect saved 150GB of data I thought I would give the long explanation version in case someone else needed the added info.
post #8 of 9 Old 11-29-2017, 09:39 AM
mrfattbill's Avatar
Quoted: 146 Post(s)
Liked: 106
Glad you were able to find the data you were looking for.
Bill
post #9 of 9 Old 11-30-2017, 07:37 PM - Thread Starter
Bill
Me too!!!
Thanks for your help
Reply Home Theater Computers
