Can you get HDR on windows 7 4K UHD MKV playback ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-17-2018, 07:30 AM - Thread Starter
annisman's Avatar
Quoted: 166 Post(s)
Liked: 87
Hi everyone,
I have a Win7 HTPC that I have used for a few years to playback ripped BD (via MakeMKV) using EMBY as my media manager, and WMC as my player.
I recently purchased a 'UHD friendly' optical drive to try ripping some of my 4K UHD. Will I need to upgrade to Win 10 to get HDR capability for my ripped UHD playback ?
I have a GTX 1060 3GB card, 8GB RAM, core i3 3220 with many TB of storage (USB 3.0 HDD enclosure).
LG B6 OLED < Yamaha 673 receiver
annisman is offline
post #2 of 11 Old 07-17-2018, 08:48 AM
Onkyoman's Avatar
Quoted: 1170 Post(s)
Liked: 690
It should work with any player that uses madVR, but the last person I talked to was experiencing some bugs. So Windows 10 might not be out of the question.
Onkyoman is offline
post #3 of 11 Old 07-17-2018, 08:50 AM - Thread Starter
annisman's Avatar
Quoted: 166 Post(s)
Liked: 87
So Win 7 may work, but MADVR is a definite MUST for 4K MKV playback ?
annisman is offline
post #4 of 11 Old 07-17-2018, 09:09 AM
Onkyoman's Avatar
Liked: 690
There are no other players on Windows that support HDR passthrough at this time, save DVDFab Player v3. Windows 7 is compatible, but you'd have to try it.
Onkyoman is offline
post #5 of 11 Old 07-18-2018, 03:57 AM
Liked: 0
yes, it works on win7. my setup:
geforce gtx980 -> mpc hc + lav filters + madvr hdr passthrough -> philips 55pos901 oled tv
only problem is when closing mpc-hc while playing HDR stuff my tv sometimes won't switch back to SDR and i need to reboot my pc.
zeus0r is offline
post #6 of 11 Old 07-18-2018, 04:09 AM - Thread Starter
annisman's Avatar
Quoted: 166 Post(s)
Liked: 87
Zeus, would you be so kind as to give me a (brief) description of how to set that up on my PC and what settings to use in both LAV and Madvr ?
annisman is offline
post #7 of 11 Old 07-18-2018, 04:15 AM - Thread Starter
annisman's Avatar
Quoted: 166 Post(s)
Liked: 87
I was able to successfully get my TV to switch over to HDR mode last night in Win 7 using MPC-HC + LAV + HDR passthrough but it was so laggy. I checked my CPU usage and it was spiking up to 100%, whereas my GTX 1060 3GB was only hitting 30-40%, this doesn't seem right to me. Any thoughts on this ?
Also, for anybody who may know this answer, what windows resolution, refresh rate, bit depth and color range (full or limited) should I be using on my windows desktop ? On my OLED B6 I can set it to 24Hz 12 bit Full at 4K resolution - but when in 60Hz mode it only lets me choose 8 bit.
LG B6 (Chad B. calibrated)
Yamaha 681 AVR
Polk Audio 3.1.2 Atmos
Panasonic UB820
Custom HTPC/Emby WMC/MPC-BE/MadVR
annisman is offline
post #8 of 11 Old 07-18-2018, 06:47 AM
Liked: 0
you need to activate GPU hardware decoding:
i use 1080p resolution, rgb 12bit & full range (0-255) in nvidia driver settings. madvr full/limited depends on what your TV is able to handle.
you don't need to set your desktop resolution to 4k in order to watch 4k videos. just use mpc-hc automatic fullscreen monitor switch:
zeus0r is offline
post #9 of 11 Old 07-18-2018, 09:19 AM - Thread Starter
annisman's Avatar
Quoted: 166 Post(s)
Liked: 87
Ok let me see if I understand what needs to be done, assuming a fresh Win 7 install:
1. install LAV filters and only change 'hardware acceleration' (DXVA2 I imagine ??)
2. install MadVR
3. Install MPC-HC and direct it to use MadVR, enable it to use automatic full screen monitor switch.
4. Desktop PC resolution set to whatever I want
Is that it ?
annisman is offline
post #10 of 11 Old 01-07-2020, 01:37 PM
Liked: 0
I have this weird change in windows 10. Before I had to turn of HDR settings in windows and madvr would automatically switch my tv to HDR when proper content was played. Now this is no longer the case, I need to switch HDR on in windows for it to work... any thoughts?
SuurbieR is offline
post #11 of 11 Old 01-09-2020, 02:12 PM
gerall's Avatar
Quoted: 70 Post(s)
Onkyoman, are you familiar with dvdfab player v3 and if so is there any difference in audio/video quality between playing a uhd disc with that player and playing an mkv rip of the same disc with madvr?
gerall is offline
Reply Home Theater Computers
