Software to run plug-ins on a MacBook output - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-30-2018, 03:39 AM - Thread Starter
Liked: 0
Question Software to run plug-ins on a MacBook output
Hi guys,
Until now, I've been running on a Windows computer. I used APO Equalizer that takes the sound from the computer (i.e. Spotify, YouTube,...) and enables to run plugins on that mix and outputs on the main output of your computer. I simply used that tool to run parametric EQs, exciter, enhancers and moderate reverbs for music.
I will soon be investing into a MacBook. Is there a way to do the same? What are the different options? Use an external sound card with Pro Tools? Or is there a way to do it using Ableton Live?
Thanks in advance for your help!
Yann
yannchapelle is offline
post #2 of 2 Old 07-30-2018, 07:22 AM
bryansj's Avatar
Quoted: 1756 Post(s)
Liked: 791
There is a Mac HTPC sub forum.
bryansj is offline
Reply Home Theater Computers
computer , macbook , plug-ins
