UPS recommendation - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By millst
  • 1 Post By captain_video
post #1 of 12 Old 09-16-2018, 07:53 AM - Thread Starter
Quoted: 250 Post(s)
Liked: 84
UPS recommendation
Hello,
I have a Benq W2000 projector and would like to get an UPS for it.
I allready have an UPS rated 800VA/480W which does not work properly. If (with charged battery) I unplug the UPS's mains while the PJ is off and I start it up the UPS is fine for a few minutes. It beeps rapidly, which the manual indicates as overload, after which it looses power and beeps continuously, manual claims Faulty UPS.
However if I unplug the mains while the PJ is ON, I instantly loose power and the unit beeps continuously.
I tested a monitor, was fine, beeped every 10 seconds indicating it was on battery.
I tested the PC unit, beeped every 10 seconds and lost power after about 4 minutes (beeped continuously).
I unplugged the UPS main for both of these while running and were fine.
I assume it's because the PJ is more demaning(?). The PJ lamp has 240w, and the estimated consumption according the benq website is 353w.
What model should I get?
noob00224 is online now
post #2 of 12 Old 09-16-2018, 07:59 AM
Seilerbird's Avatar
Quoted: 187 Post(s)
Liked: 212
Here is the UPS I have been using for the last three years without an issue. Cost me $88.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
LG OLED55C6P
Sony STRDH770, Sony UBP-X800, Sony PS3 160
2 - Polk TSi300, 1 - Polk CS10, 4 - Polk T15, 1 - Polk PSW125
Seilerbird is offline
post #3 of 12 Old 09-16-2018, 08:17 AM - Thread Starter
Quoted: 250 Post(s)
Liked: 84
@Seilerbird if the power goes out and the PJ (or TV) is on, does it stay on?
On your own equipment I mean.
I paid for the UPS about $60, that one is about $120 locally. It's strange that the performance seem to be higher on mine, yet cheaper.
Is this a case of the manufacterer lying about the specs?
I still don't understand why the UPS works fine when I turn the PJ on with the mains unplugged, but stops if I unplug the mains while the PJ is on.
post #4 of 12 Old 09-16-2018, 10:21 AM
millst's Avatar
Quoted: 203 Post(s)
Liked: 104
I have a few CyberPower ones (mini-towers w/ LCD) that I'm happy with. However, unless your area has power outages often, it seems like a waste of money to me. I'd save the money for the next projector upgrade instead of investing against some lost hours on your current projector's bulb.
-tm
millst is offline
post #5 of 12 Old 09-16-2018, 11:28 AM - Thread Starter
Quoted: 250 Post(s)
Liked: 84
@millst what kind of pj? And what Cyber Power model?
Unfortunately it happens about twice a week (sometimes more often), and I understand this can damage the bulb, not just loose hours.
post #6 of 12 Old 09-17-2018, 08:23 AM
millst's Avatar
Quoted: 203 Post(s)
Liked: 104
As I said, I think it's a waste of money so I don't use a UPS for my JVC. I think I've had a single power outage during projector use in ~15 years. I have models similar to the CP850PFCLCD for different purposes e.g. computer.
If you have power problems like that, then I understand the interest. CP makes AVR specific models, too.
Not sure if that is actually true. Obviously, the excess heat is not great for the bulb, but I've never seen anything scientific. Just baseless speculation and anecdotes. A new UPS is probably 1/3 the cost of a new bulb...
-tm
millst is offline
post #7 of 12 Old 09-17-2018, 09:53 AM - Thread Starter
Quoted: 250 Post(s)
Liked: 84
[QUOTE=millst;56822330]A new UPS is probably 1/3 the cost of a new bulb.../QUOTE]
You're probably right.
One like the amazon link above is about half the price of a bulb, and a 700W APC is about $170.
I might still get it for future projectors, when I upgrade to a more expensive unit.
post #8 of 12 Old 09-20-2018, 01:38 AM
Quoted: 217 Post(s)
Liked: 41
I think your problem with your UPS is it is trying to power an induction load instead of resistive load. Induction loads are harder for the inverter to power. You may want take the amount of watts and multiply it by four to get plenty of power. Probably CyberPower OR1500PFCLCD is what you need. Be careful with simulated sine wave or modified sine wave based UPS when used with induction loads. Induction loads will have different performance on simulated sine wave or modified sine wave based UPS. Every UPS is different, so you have to find which works well for your projector. I don't know projectors. I suggest asking in the projector forum.
tecknurd is offline
post #9 of 12 Old 09-20-2018, 08:18 AM
millst's Avatar
Quoted: 203 Post(s)
Liked: 104
The general speculation I've seen has been that anything that isn't a true sine wave is not great for the projector. Is running it briefly to properly shut down and cool the projector worse than loss of power? Probably not. Again, nothing scientific.
You can spend more to get a better sine wave approximation, but that just makes the value proposition even worse (and I'd say it was not a good value to begin with). Why spend $300 to protect a discontinued $1200 projector?
-tm
millst is offline
post #10 of 12 Old 10-17-2018, 11:20 PM - Thread Starter
Quoted: 250 Post(s)
Liked: 84
Usually the power outages only last a few seconds. The PC restarts itself, the PJ immediately turns off (the UPS does not kick in).
Had a outage the other day that lasted longer. The PC shut itself off, the projector lost signal but stayed on (the UPS kicked in).
Both the PC and the UPS (+PJ) are plugged in the same extension cord.
I thought that it might have something to do with the HDMI beeing connected to a live PC. I did some tests.
The UPS kicked in when I:
Unplugged the extension cord from the wall socket (with all 3 devices PC, monitor, UPS (+PJ).
The UPS did not kick in when I:
Unplugged the HDMI cable from the GPU, then unplugged the UPS.
Unplugged the PC and the monitor, then unplugged the UPS.
I will upgrade to a higher end PJ and I see the lamps can go for around $650, so I will want an capable UPS.
post #11 of 12 Old 10-18-2018, 09:05 AM
millst's Avatar
Quoted: 203 Post(s)
Liked: 104
The UPS doesn’t care about any connections downstream. It’s a simple switchover from line power to battery power when an outage is detected. Either your UPS has a bad battery, is damaged or is overloaded. Disconnecting equipment affects the load.
-tm
noob00224 likes this.
millst is offline
post #12 of 12 Old 10-19-2018, 06:07 AM
captain_video's Avatar
Quoted: 717 Post(s)
Liked: 422
There are several factors to consider when shopping for a UPS. Aside from providing temporary battery backup to your equipment when the power goes out you should also consider one that provides surge protection and power regulation. Electrical spikes can cause more damage to your hardware than loss of power. You should look for one that provides filtering and regulation to give you the cleanest, most stable power input to your components. You should also consider one that provides a true sine wave output. A $60 UPS isn't going to do much to protect your equipment and is comparable to using a leaky condom. Not a lot of protection and the risk of a catastrophic event is very likely.
Instead of using a UPS for your projector you might want to consider a standalone power filter and regulator that basically does everything I described except for the battery backup. You don't really need a battery backup for a projector, but it's good to have the protection from dirty power and energy spikes. I haven't shopped for one in quite a while but there are models by APC, Tripplite, and Monster that should do the trick. There are others out there and you might want to check some of the other forums for recommendations.
captain_video is online now
Reply Home Theater Computers
