Looking for OLD HD Homerun driver utility for use with XP. - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By toohip
post #1 of 6 Old 09-30-2018, 01:18 PM - Thread Starter
browncoat's Avatar
Quoted: 67 Post(s)
Like the title says, wondering if anyone has archived their old drivers. The oldest I could find so far was from 2014, and is too new, trying to get an HDHR4-(2) US-CA to run with an MDP-130 using Cliff Watson EPG Project as my PVR solution.
I just need to get as far as having the tuners scan for channels, then CW_EPG will take over from there.
I'd appreciate it.
browncoat is offline
post #2 of 6 Old 09-30-2018, 03:42 PM
toohip's Avatar
Quoted: 16 Post(s)
I'd appreciate it.
As far as I know, the last version of the HDHomeRun software which is XP-compatible is version 20141210. You won't find it linked anywhere on the SiliconDust website, but this link should work:
http://download.silicondust.com/hdho...s_20141210.exe
browncoat likes this.
toohip is offline
post #3 of 6 Old 09-30-2018, 04:24 PM - Thread Starter
browncoat's Avatar
Quoted: 67 Post(s)
My bad, I should have mentioned in the primary post that I already tried 20141210 today, and rather than the GetTickCount64 -KERNEL32.dll error, the dialogue read plainly that it did not support W98 through to Server 2008, but thanks for the link, I'll just have to keep trekkin' on in the hunt.
post #4 of 6 Old 10-02-2018, 04:27 PM
toohip's Avatar
Quoted: 16 Post(s)
Give these a try.
https://www.touslesdrivers.com/index...26&v_code=1624
Make sure you download from their server and not the SiliconDust server as it will not be found.
toohip is offline
post #5 of 6 Old 10-06-2018, 11:44 AM
Ken.F's Avatar
Quoted: 2288 Post(s)
Liked: 2569
The oldest download I have is 20140604. I also have an old disc with "HDHomeRun Installation CD October 2012" markings in the ring around the hub.
Ken.F is offline
post #6 of 6 Old 10-07-2018, 07:33 AM
captain_video's Avatar
Quoted: 729 Post(s)
Liked: 422
Have you tried posting this in the SiliconDust forums? I think you'd have better luck finding it there. You might consider contacting SD tech support. I'm sure they could send it to you.
captain_video is offline
Reply Home Theater Computers
