Upgrading HTPC for 4k - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By whiteboy714
  • 1 Post By markmon1
post #1 of 28 Old 01-09-2019, 02:49 PM - Thread Starter
Liked: 0
Hello All
I got a 4k 65in Samsung TV for Christmas and looking to upgrade my HTPC to handle 4k and all the latest surround sound formats. Here is my current configuration
MOBO: Asus P7H55 M Pro
CPU: Intel Core i3 2100
GPU: Nvidia GeForce GT 430
Receiver: Sony STR-DN1080
I play uncompressed blu ray rips from a home server. No 4k content yet, but would start adding some once the HTPC is upgraded. I would like to get the most that I can from the media while not breaking the bank. This will be only for video playback. It is not for gaming. I would also like it to handle Netflix 4k (if that changes things).
I've seen the GeForce GT 1030 recommended quite a bit and was considering it for the GPU upgrade. I was curious if my MOBO and CPU are in need of upgrade as well? I am hoping the GPU upgrade is sufficient.
Thanks for your assistance.
skj88 is offline
post #2 of 28 Old 01-09-2019, 06:08 PM
audit13's Avatar
Quoted: 282 Post(s)
Liked: 110
I suggest getting at least an nVidia 1050Ti which is what I am using with an Intel g3258.
I had the 1030 and it just couldn't give me smooth 4k playback or do high quality upscaling to 4k.
audit13 is offline
post #3 of 28 Old 01-09-2019, 08:00 PM
frank xbe's Avatar
Quoted: 94 Post(s)
Liked: 65
Intel® Core™ i5-6500 skylake family Processor is a sure bet.if not gaming you wont need a video card
Samsung 55KS8000 ,Samsung 55MU6300 . Sony 55X850C ,LG 42LB5400 ,Roku 2
Sony ES 7.1HT AVR modest 5.1 surround with Elac B6 fronts w/other impedance and sensitivity matched surrounds , center and powered sub that work well for what it is.
frank xbe is offline
post #4 of 28 Old 01-09-2019, 08:08 PM
whiteboy714's Avatar
Quoted: 1743 Post(s)
Liked: 765
For 4k video? Since when?
Often a 1050ti is recommended, if you can swing a 1060 6gb thats what I would shoot for. But its not a must.
audit13 likes this.
whiteboy714 is offline
post #5 of 28 Old 01-09-2019, 08:15 PM
frank xbe's Avatar
Quoted: 94 Post(s)
Liked: 65
IIRC since HDR but lots of other older Intel 4th gen CPU will do 4K SDR
good suggestion
post #6 of 28 Old 01-09-2019, 08:19 PM - Thread Starter
Liked: 0
Thank you! I have one on the way!
skj88 is offline
post #7 of 28 Old 01-09-2019, 08:27 PM
audit13's Avatar
Quoted: 282 Post(s)
Liked: 110
I have great 4k playback with MPC-BE, madVR, and windows 10. I hope you'll be happy with your choice.
audit13 is offline
post #8 of 28 Old 01-10-2019, 04:19 AM
jmanou's Avatar
Liked: 0
Sorry for hijacking thread but i am in a similar situation. Its time to replace my GT 1030 with something more powerful and with 4Gb memory. I find GT 1050 ti and RX570 at the same price. Which of them is recommended? i mainly watch 1080p and 4k material on a Samsung KS8000 UHD display.
jmanou is offline
post #9 of 28 Old 01-10-2019, 05:22 AM
markmon1's Avatar
Quoted: 6555 Post(s)
Liked: 4705
Originally Posted by jmanou View Post
Sorry for hijacking thread but i am in a similar situation. Its time to replace my GT 1030 with something more powerful and with 4Gb memory. I find GT 1050 ti and RX570 at the same price. Which of then is recommended? i mainly watch 1080p and 4k material on a Samsung KS8000 UHD display.
I'd be getting the 1050ti.
waleed likes this.
Video: JVC RS4500 135" ST130 G4 screen in batcave, htpc nvidia 1080ti madVR.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is offline
post #10 of 28 Old 01-10-2019, 06:25 AM
jmanou's Avatar
Liked: 0
Thank you for the reply.
Are there specific reasons that the 1050 ti is better from RX 570 ? Because i was under the impression that 570 is more powerful (Maybe i am wrong).
jmanou is offline
post #11 of 28 Old 01-10-2019, 06:32 AM
Onkyoman's Avatar
Quoted: 1183 Post(s)
Liked: 700
If you were using madVR, the RX 570 is less powerful than the GTX 1050 Ti.
Onkyoman is offline
post #12 of 28 Old 01-10-2019, 01:37 PM
jmanou's Avatar
Liked: 0
Thanks for making it clear. Yes i am using Madvr
jmanou is offline
post #13 of 28 Old 01-10-2019, 03:03 PM
markmon1's Avatar
Liked: 4705
Also if you want to use madVr's processing for upscaling and noise filtering and sharpening, you might consider a 1070 (used off craigslist) or at least a 1060.
waleed likes this.
markmon1 is offline
post #14 of 28 Old 01-11-2019, 01:19 AM
jmanou's Avatar
Liked: 0
I see your point, maybe i manage to stretch budget for a 1060.
jmanou is offline
post #15 of 28 Old 01-11-2019, 05:45 AM
Onkyoman's Avatar
Liked: 700
You can still do a lot with a 1050 Ti. The 1060 is a luxury.
Onkyoman is offline
post #16 of 28 Old 01-11-2019, 01:45 PM
jmanou's Avatar
Liked: 0
Thank you.
jmanou is offline
post #17 of 28 Old 01-24-2019, 08:10 PM
Quoted: 35 Post(s)
Liked: 4
4k netflix wont work on a 1050ti you need a 7th gen intel processor or newer and can only use the onboard gfx
i stand corrected it works now in the windows 10 oct 2018 update
Billycar11 is offline
post #18 of 28 Old 01-25-2019, 05:36 AM
ruggercb's Avatar
Quoted: 131 Post(s)
Liked: 71
[URL] https://nvidia.custhelp.com/app/answers/detail/a_id/4583/~/4k-uhd-netflix-content-on-nvidia-gpus[/
ruggercb is online now
post #19 of 28 Old 01-25-2019, 08:38 PM
Quoted: 35 Post(s)
Liked: 4
Originally Posted by ruggercb View Post
thanks for the info had no idea it works now hope they do the same for uhd blurays too.
post #20 of 28 Old 01-26-2019, 05:54 AM
ruggercb's Avatar
Quoted: 131 Post(s)
Liked: 71
My internet is just 20 mbps so Netflix decides I can’t do 4k anyhow, but I did research it thinking my pc was to blame.
I rip all my UHD discs which is another challenge, but it’s about the only way for me to watch 4k. I don’t own a standalone player.
post #21 of 28 Old 01-29-2019, 01:49 PM
aggregatebuzz's Avatar
Liked: 2
4K native playback with Kentsfield era Intel 4core(since new)and a GTX980,nice and smooth
pretty quick with 2nd gen Intel 80G ssd in a Raven case
Windows 10 produces much better quality sound now days
Potplayer works nice,for 3D playback too when I had it
Kenwood KR-8540...Bose 901
Denon AVR4520CI...Emp Tek 55 Ti Tower x4... E56Ci...(2006)SVS12Ultra/2...LG Oled 55"
Onkyo TX-NR3008...Pioneer A.J. Towersx4...BIC Formula 12x2
aggregatebuzz is offline
post #22 of 28 Old 01-30-2019, 06:48 PM
123
123's Avatar
Quoted: 18 Post(s)
I am doing the same thing and have some similar questions. I spec'd my HTPC in 2012 for 1080p playback. Based on this thread + the HTPC for 4k Build thread, I'll pick up a 6GB GTX 1060. I also need to upgrade the PSU, which I've got covered. My question is what else I may need to do.
Intel - Core i3-3225 3.3 GHz Dual-Core Processor 3rd Gen (Ivy Bridge)
Gigabyte - GA-H77M-D3H Micro ATX LGA1155
4 Gigs DDR3 RAM
SSD
Win7
Per the HTPC for 4K Build thread, 6-8 GB of RAM are required, but I'm not clear why - isn't the GPU doing the heavy lifting? I can buy more, just not sure why I would need it.
And will I encounter issues with Win7? I'm seeing most 4k builds are on Win 8 or 10.
Anything else to be aware of? I know this is an old rig, so if it makes more sense to start from scratch, I'll do that.
123 is offline
post #23 of 28 Old 01-31-2019, 05:49 AM
Onkyoman's Avatar
Liked: 700
You could probably get by with 4GB of RAM. Hardware decoding can use some of the system RAM, so a higher amount just ensures you never run out of RAM.
Onkyoman is offline
post #24 of 28 Old 01-31-2019, 08:22 AM
123
123's Avatar
Quoted: 18 Post(s)
Thanks; doubling the DDR3 ram is pretty cheap, so I'll just go ahead and do so.
123 is offline
post #25 of 28 Old 01-31-2019, 09:56 AM
Liked: 2
mine is smmooth with the 4G ram,I think that is max for this platform,is a Asus workstation model
post #26 of 28 Old 01-31-2019, 11:45 AM
123
123's Avatar
Quoted: 18 Post(s)
Thanks for sharing your experience! I was probably going to do it piece-meal for giggles, anyway. It'll cost me about 30$ to add 4 more gigs, so no real harm in doing so, even if I won't need it. But if it runs fine without, I probably won't, out of laziness.
123 is offline
post #27 of 28 Old 01-31-2019, 03:23 PM
Liked: 2
prices for ram are nice now,the upgrade would be easy or easy to forget about too
lazy is king for me sometimes too
post #28 of 28 Old 09-03-2019, 12:39 PM
Quoted: 51 Post(s)
Hi, Someone can suggest a good card for MPV player? (linux)
bl4ck is offline
Reply Home Theater Computers
