How to Video : [Make a Blu-Ray drive UHD Friendly and read 4K disks] Recorded in 4K - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-24-2019, 08:17 PM - Thread Starter
Quoted: 35 Post(s)
Liked: 4
thanks to these guides here:
https://www.makemkv.com/forum/viewto...p?f=16&t=17058
https://club.myce.com/t/dosflash-v2-...-drives/399911
New Video easier and safer method:
Old Video:
Requirements:
32Bit windows bootable PE or full installation will work
Computer with sata ide mode look for something similar to this in bios
advanced - pch storage - sata - sata mode and change that from ahci or raid mode to ide
dive must be connected to sata controller not usb
Drives
ASUS BW-16D1HT build date 2015+ check it has 3.00+, the 1.00 ones are not compatible
LG BE16NU50 SVC NS50+
LG WH16NS40 SVC NS50
LG BH16NS40 SVC NS50
LG BH16NS55 SVC NS50+
LG WH14NS40 SVC NS50
LG WH16NS60 SVC NS60
Billycar11 is offline
post #2 of 6 Old 01-25-2019, 06:13 AM
Onkyoman's Avatar
Quoted: 1195 Post(s)
Liked: 705
Thanks for this. I added the link to the madVR build guide in this forum.
Onkyoman is offline
post #3 of 6 Old 01-25-2019, 04:17 PM - Thread Starter
Quoted: 35 Post(s)
Liked: 4
Thanks! glad you think its good enough to include in your guide.
post #4 of 6 Old 01-25-2019, 04:30 PM
Onkyoman's Avatar
Liked: 705
I haven't had to do this myself, but your video made me understand how easy it is.
You might want to make a note in your post on how to check the BIOS for motherboard compatibility or if a certain spec for the motherboard is required.
Onkyoman is offline
post #5 of 6 Old 01-25-2019, 06:21 PM - Thread Starter
Quoted: 35 Post(s)
Liked: 4
not really a certain spec but the place to look in the bios would be under advanced > pch storage > sata > sata mode and change that from ahci or raid mode to ide.
i will put the requirements in the description
urf noticed while i was editing description my google drive links got taken down in less than 2 days no wonder the original guides link to sketchy web hosting sites they are back up for now but i will have to find another way to host them and dont want to put them on my own server because everyone will have my ip address
post #6 of 6 Old 02-15-2019, 01:59 AM - Thread Starter
Quoted: 35 Post(s)
Liked: 4
new safer and easier downgrade method with modified firmware edited by me
source https://www.makemkv.com/forum/viewto...p?f=16&t=18873
Reply Home Theater Computers
