MadVR HTPC build for JVC NX7 projector - a build! - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 56Likes
post #271 of 300 Old 02-26-2020, 04:05 AM - Thread Starter
tommarra's Avatar
Quoted: 965 Post(s)
Liked: 560
With more RAM and a good GPU (at least 2060) yes - I would say so.
If you are looking for Libredrive compatible blu Ray drive to rip movies I would add that as well at some point of time.
Gear: Fronts: B&W 804D3 | Center: B&W HTM2D3 | Surrounds: B&W 684S2 | Backs: B&W 684S2 | Heights: B&W DM601S3 | Subs: 3x PSA S1500 Receiver & Amps: Arcam AV40 + Monoprice Monolith 7x200 + Emotiva BasX-5 | Projector: JVC NX7 | Screen: 126 inch 16:9 Stewart Studiotek 130 G4 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is online now
post #272 of 300 Old 02-28-2020, 09:55 AM
asharma's Avatar
Quoted: 2318 Post(s)
Liked: 836
Thanks for posting this thread...we have the same pj...I’m looking into building a MadVR pc...I’m sure I’ll be in touch...can I send the output of my Panny 820 to the HTPC so I can use my physical 4K discs...
Video:JVC NX7, 125” 2.35 Stewart ST100 Electric, Sony 85” 900F Sony 55” 900F
Audio: Paradigm Prestige 95, 55C, 15b, 25s, Dual SVS SB3000
Receiver/Amp: Anthem 1120, Emotiva XPA-11 Gen 3
Source: Panasonic UB820, Triple black velvet batcave
asharma is offline
post #273 of 300 Old 02-28-2020, 05:38 PM - Thread Starter
tommarra's Avatar
Quoted: 965 Post(s)
Liked: 560
No I am afraid you can’t ... you need some kind of video capture device that is HDCP compliant - and there is no device like that available as of yet.
You are talking about Envy here :-)
post #274 of 300 Old 02-28-2020, 05:46 PM
asharma's Avatar
Liked: 836
Thanks, a couple questions...
1) could I just include a 4K disc player in the HTPC chassis?
2) how plug and play is MadVR? Once the right settings are set, does it ever need to be touched?
3) I have 30 FL in a velvet cave with a Stewart ST100 reference screen...everything pops now...does it really get that much better with MadVR in my setting?
asharma is offline
post #275 of 300 Old 02-28-2020, 06:31 PM - Thread Starter
tommarra's Avatar
Quoted: 965 Post(s)
Liked: 560
Yes I have a Libredrive compatible 4K UHd drive in my HTPC chassis. Almost all of us who go the UHd route, use MakeMKV to rip the drive to our Hard Drive or to our NAS and then use Kodi + MPC-HC (or Zoom Player) etc to play back.
It take approximately one hour of pre work before you can watch the movie but then you don’t have to touch your Physical disk ever again :-) mine go into a large suitcase!
Personally I find the HTPC a lot more effective way of playback vs putting a disk in a blu Ray player. (Streaming vs Buying Audio CD in early 2010)
If you have 30 FL, then MadVR will do absolute wonders to your picture. When I built my HTPC I was skeptical - but then o watched Avengers Infinity Wars with and without MadVR and oh boy was the difference night and day! I can never go back to watching HDR disk content without MadVR.
If you have $1000 to spare - go with HTPC like my build and treat it like an experiment. If it doesn’t work out For you, am sure you can recover ~80% of your cost.
MadVR is totally plug and play once you set it up. Setting it up requires some experimentation because everyone’s setup and more importantly preferences are different. Once you set it up the way you like it you don’t have to touch it again. It took me about 2 days to properly configure it - including automatically changing Lens Memory and Color profile based on content and since then I only open the MadVR setup tab when madshi releases a new beta build.
A number of experts (Neo-XP, Manni01, markmon1, and others) have detailed how to and are very helpful if you have any questions
post #276 of 300 Old 02-29-2020, 03:14 AM
asharma's Avatar
Liked: 836
AWESOME information, very kind! Thanks!!
asharma is offline
post #277 of 300 Old 02-29-2020, 04:52 AM
markmon1's Avatar
Quoted: 6524 Post(s)
Liked: 4660
Originally Posted by biglen View Post
How's this PC look as a starter PC for MadVR? I'd obviously add a good GPU and some more RAM.
This will be fine with a decent GPU. Even 4gb of ram is enough for video playback.
Edit: looks like there are cases where you'll need more than 6gb ram. I guess 8GB is a safer bet.
Video: JVC RS4500 135" ST130 G4 screen in batcave, htpc nvidia 1080ti madVR.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is offline
post #278 of 300 Old 02-29-2020, 04:58 AM
biglen's Avatar
Quoted: 816 Post(s)
Liked: 233
What do you consider decent, a 2060 GPU?
Sent from my SM-N975U using Tapatalk
biglen is online now
post #279 of 300 Old 02-29-2020, 05:01 AM
markmon1's Avatar
Liked: 4660
I'd consider a 2060 a minimum. I guess it depends what you want to do. I have a 1080ti. My friend had a 1070 but we had to upgrade that. Perhaps a 2060 super or 2070 is better for better upscaling.
markmon1 is offline
post #280 of 300 Old 02-29-2020, 08:01 AM
biglen's Avatar
Quoted: 816 Post(s)
Liked: 233
Darn, it got sold.
post #281 of 300 Old 02-29-2020, 08:06 AM
Quoted: 164 Post(s)
Liked: 176
Based on my testing with GeminiMan 4k60 HDR is a tough nut to crack. I have a overclocked 1080 and I had to turn on the HDR performance checkboxes to get smooth video, but still dropping a small number of packets. Hopefully not too many movies are going to be 4k60, I dont want to upgrade my GPU just because of that.
dgrizzard is online now
post #282 of 300 Old 02-29-2020, 10:46 AM
Quoted: 1706 Post(s)
Liked: 506
Render times have to be under 16ms. Try reducing some features, like chroma upscaling.
Considering how these movies have performed commercially I don't think they are making any more.
noob00224 is online now
post #283 of 300 Old 02-29-2020, 06:54 PM
long_pn's Avatar
Quoted: 66 Post(s)
If putting the HDR Tone Mapping and HDR 4K 60fps aside, what is a 2060S/2070 doing better than a 1060 6gb/1070 in term of upscaling 720/1080p 24fps to 4K ?
long_pn is online now
post #284 of 300 Old 02-29-2020, 07:41 PM
markmon1's Avatar
Liked: 4660
Content thats 30fps may not be able to be upscaled by a 1070. You can add more post processing filters with the better cards. You can use double and double again for 720p content with the better card but not with the 1070. Stuff like this.
You can get a 1060 / 1070 working but you just have to make more compromises.
markmon1 is offline
post #285 of 300 Old 02-29-2020, 11:16 PM
SirMaster's Avatar
Quoted: 1220 Post(s)
Liked: 839
Have you actually tried 4GB with madVR?
I had significant problems with 4GB with madVR that completely go away when I increased the memory to 8GB.
In truth I found that for 4K HDR you need at least 5GB of system ram with madVR.
markmon1 likes this.
SirMaster is offline
post #286 of 300 Old 02-29-2020, 11:43 PM
markmon1's Avatar
Liked: 4660
You know I think you may be right. I just did some tests. And for all the stuff I normally use madVR for (upscaling 1080p), the player is only using around 1.5gb RAM. But on a true UHD in tone mapping, it spikes up to 3.9gb RAM. So you're probably onto something that you need 6GB or more. I wonder if I play an 8K file if the memory usage goes up further.
markmon1 is offline
post #287 of 300 Old 02-29-2020, 11:47 PM
SirMaster's Avatar
Liked: 839
Yeah I was getting severe posterization and messed up inverted colors and strange random artifacts like that with 4GB. These happened only on 4K HEVC files and completely went away with more RAM. 4GB is right on the cusp where it seemed to depended on how much RAM my system was using at the time as for how much was free for madVR. Memory usage definitely seems to strongly depend on resolution with madVR.
As much as I like to be able to recommend affordable PCs for people for madVR I would say 6GB minimum now.
post #288 of 300 Old 03-01-2020, 05:39 AM
biglen's Avatar
Quoted: 816 Post(s)
Liked: 233
DDR3 is so cheap anyway. I think I saw 8gb for $30.
post #289 of 300 Old 03-01-2020, 07:48 AM - Thread Starter
tommarra's Avatar
Quoted: 965 Post(s)
Liked: 560
I think for any Windows PC at least 8 GB is minimum for decent performance nowadays
post #290 of 300 Old 03-02-2020, 04:49 AM
Quoted: 164 Post(s)
Liked: 176
Yeah I dropped just about everything I could, render times in the 12-13ms range but still dropping a hand full of frames every few seconds. It isn't noticeable because you have 60fps to work with instead of 24fps, but I can't have the same settings for 4k24 and 4k60. The render times jump into the 40s and 50s, with terrible visual performance. But it's just one movie, so changing settings maybe once a year (haven't watched it yet, so maybe never again?) isn't a huge deal.
post #291 of 300 Old 03-02-2020, 05:19 AM
Liked: 506
If you're still dropping frames you could post a screenshot of the OSD here:
https://www.avsforum.com/forum/26-ho...thread-70.html
post #292 of 300 Old 03-02-2020, 07:50 PM
jbnpaul's Avatar
Quoted: 145 Post(s)
Liked: 51
You can have two different settings for 24p and 60p.
You can set up madVR so that it will automatically apply the settings based on the resolution and frame rate.
There is a guide/samples available on how to do this.
jbnpaul is offline
post #293 of 300 Old 03-03-2020, 03:10 AM
Quoted: 164 Post(s)
Liked: 176
I have my profiled setup based on resolution right now, didn't realize it also did frame rate, I will look into that thanks.
post #294 of 300 Old 03-03-2020, 06:13 AM - Thread Starter
tommarra's Avatar
Quoted: 965 Post(s)
Liked: 560
It can do tonnes of things, frame rate, HDR, even aspect ratio etc
post #295 of 300 Old 03-04-2020, 04:33 AM
Quoted: 28 Post(s)
Liked: 2
Do you happen to have a link to the guide that explains how to set up different profiles based in frame rate? I currently have profiles based on resolution (4K vs everything else) but would like to set up a separate profile for 4K 60fps, for the small number of movies that are being released with 60fps. Thanks!
Sent from my Pixel 3 using Tapatalk
ayeroff is offline
post #296 of 300 Old 03-04-2020, 05:02 AM
markmon1's Avatar
Liked: 4660
Hopefully this helps you understand what to do.
tommarra likes this.
markmon1 is offline
post #297 of 300 Old 03-04-2020, 05:09 PM
Quoted: 28 Post(s)
Liked: 2
Thanks! I'll give it a shot.
ayeroff is offline
post #298 of 300 Old 05-16-2020, 02:04 PM
Quoted: 164 Post(s)
Liked: 176
Attack of the NVIDIA drivers again for me. I just put my theater back together and updated my drivers on my HTPC/gaming system. Started playing a movie and about 5-9 minutes in black lines would randomly start flashing on the screen. Then the lines would increase in frequency until MadVR crashed. I did a lot of testing and found out if I turned off black bar detection the problem went away. Then I tried different recent NVIDIA drivers to no avail, ended up pulling all drivers and installed one back from 7/2019. Enabled black bar detection again, and poof problem gone.
Just a lesson to everyone, when you have an HTPC and it's working, dont update anything.
post #299 of 300 Old 05-18-2020, 10:32 AM - Thread Starter
tommarra's Avatar
Quoted: 965 Post(s)
Liked: 560
I haven’t updated my HTPC drivers since the last working version- why fix something that’s not broken!
Good that it worked out for you in the end
post #300 of 300 Old 05-18-2020, 03:26 PM
Quoted: 164 Post(s)
Liked: 176
Yes, my issue is that I am using the same PC for gaming as well, and I needed to update to fix an issue with one game crashing. I am waiting for the 3080s to come out and place that in the gaming rig, then I will move my current 1080 to a different box for my HTPC/MadVR stuff. Until then no updating anything.
Reply Home Theater Computers
