MadVR HTPC build for JVC NX7 projector - a build! - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 47Likes
post #61 of 236 Old 03-05-2019, 06:05 PM
markmon1's Avatar
Quoted: 5346 Post(s)
Liked: 3473
Originally Posted by tommarra View Post
I downloaded the Kodi DSPlayer build that has built in MadVR, Lavfilters, etc.
I am just waiting for my RTX2060 to deliver to start to play with MadVR. I tried using it on stock intel processor and had so many framedrops that it was unusable.
In the interim I will create the profiles based on the settings you used.
Still trying to figure out where to get the nightly MadVR build - and which one to use.
The nightly builds change sometimes 2x a day. I'm using build 45 for now. I'm going to stay there probably until it moves into a more released state.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #62 of 236 Old 03-05-2019, 06:11 PM - Thread Starter
tommarra's Avatar
Quoted: 641 Post(s)
Liked: 384
Thank you!
Gear: Fronts: B&W 803D3 | Center: B&W HTM2D3 | Surrounds: B&W 705S2 | Backs: B&W DM601S3 | Heights: Definitive Techonlogy ProCinema 1000 | Receiver & Amps: Anthem MRX 720 + Emotiva BasX-5 | Projector: JVC NX7 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is offline
post #63 of 236 Old 03-05-2019, 06:13 PM
markmon1's Avatar
Liked: 3473
Thank you!
yea, if you scroll that thread and find build 45 you can scroll down a little and find screens of neo-xp's settings. I'd plug those in. You can probably do that up to build 50. Seems build 49 might be good, too. I just happen to use build 45 and it works well enough I'm staying there until something is official. I don't like measurement files either so those are all turned off. Results are awesome without.
tommarra likes this.
markmon1 is offline
post #64 of 236 Old 03-06-2019, 05:45 PM - Thread Starter
tommarra's Avatar
Quoted: 641 Post(s)
Liked: 384
Originally Posted by Bill DePalma View Post
Any issues with this list?
https://pcpartpicker.com/user/bdepalma1/saved/Gzf3bv
Bill d
Looks good. The LOGITECH keyboard is only 20 bucks at Walmart . So you may save $5 there.
Also add a Noctuna CPU case fan - the stock cooler is horrible.
Also are you sure the case fans are the quietest? Try to see if You have Noctunas in the same price range?
tommarra is offline
post #65 of 236 Old 03-07-2019, 07:14 AM
Onkyoman's Avatar
Quoted: 1129 Post(s)
Liked: 665
Bill d
Your Blu-ray drive won't rip 4K UHD discs. You need one from this list:
https://www.makemkv.com/forum/viewto...p?f=16&t=16832
I would go with the official drives. However, you still may need to flash the firmware of that drive to get it to work, which requires a motherboard with an IDE mode for the SATA ports. Instructions on how to do this are included in the madVR build guide. It also an option to simply buy a pre-flashed drive from someone.
Onkyoman is offline
post #66 of 236 Old 03-07-2019, 07:18 AM
SirMaster's Avatar
Quoted: 789 Post(s)
Liked: 485
Well, now that MakeMKV has LibreDrive support, the number of supported drives should be higher.
https://www.makemkv.com/forum/viewto...4025aab4266255
You no longer need a special "UHD Friendly" drive with an old firmware since LibreDrive completely bypasses the drive's DRM firmware features and reads tracks raw. No more revokes and such either.
Silentmac likes this.
SirMaster is offline
post #67 of 236 Old 03-07-2019, 07:40 AM
Onkyoman's Avatar
Liked: 665
Sounds promising. Are you sure new firmware is supported for off-the-shelf drives?
Onkyoman is offline
post #68 of 236 Old 03-07-2019, 07:56 AM
SirMaster's Avatar
Quoted: 789 Post(s)
Liked: 485
I just found out about LibreDrive yesterday heh so more research would be required. Just thought i'd mention it.
post #69 of 236 Old 03-07-2019, 08:27 AM
markmon1's Avatar
Liked: 3473
Bill d
Nice selection. Good video card. No f-ing around here
markmon1 is offline
post #70 of 236 Old 03-07-2019, 05:10 PM
RapalloAV's Avatar
Quoted: 2228 Post(s)
Liked: 773
I just bought a new BH16NS55 with UHD Friendly firmware from Australia yesterday which should arrive next week to me in NZ. As Im all new to this but have used makemkv for years, how does this LibreDrive affect me? I read the posts from your link but still dont completly understand it all, does it mean that we no longer need what i have just bought?
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild, plus new LED ceiling install Christmas 2018
RapalloAV is offline
post #71 of 236 Old 03-08-2019, 03:53 PM
Rookie Member
Bill DePalma's Avatar
Quoted: 77 Post(s)
Liked: 31
Thanks for that, I will amend my list
Bill DePalma is offline
post #72 of 236 Old 03-08-2019, 03:55 PM
Rookie Member
Quoted: 77 Post(s)
Liked: 31
I can get a 1080ti locally for 500, which would be a better choice?
post #73 of 236 Old 03-09-2019, 08:28 AM - Thread Starter
tommarra's Avatar
Quoted: 641 Post(s)
Liked: 384
I think I read somewhere that the RTX GPUs are preferred ... some new capabilities might be on the horizon using the capabilities in that GPU ... but don’t quote me on that
tommarra is offline
post #74 of 236 Old 03-09-2019, 08:32 AM - Thread Starter
tommarra's Avatar
Quoted: 641 Post(s)
Liked: 384
Finally completed my build but there is an issue with the GPU fan - makes a noise as if the fan bearning is unbalanced.
I tried to play with MadVR also ... build 49.
With so many settings in the HDR section I couldn’t figure out what to change.
I changed the target nits box with green text to 75 bits because that is what I get on my screen in low power mode ... but not sure what all settings need to be changed
Can someone please help with most relevant settings and what they mean
tommarra is offline
post #75 of 236 Old 03-09-2019, 09:14 AM
ddgdl's Avatar
Quoted: 350 Post(s)
Liked: 328
The Kodi forums have a really good setup guide for madvr. Its linked in Onkyoman's sig I believe
ddgdl is online now
post #76 of 236 Old 03-09-2019, 09:44 AM
Onkyoman's Avatar
Liked: 665
Maybe this can help until there are fewer options?
https://www.avsforum.com/forum/26-ho...l#post57640870
Onkyoman is offline
post #77 of 236 Old 03-09-2019, 02:20 PM - Thread Starter
tommarra's Avatar
Quoted: 641 Post(s)
Liked: 384
Thank you !
tommarra is offline
post #78 of 236 Old 03-09-2019, 02:29 PM
Rookie Member
Quoted: 77 Post(s)
Liked: 31
Thanks, I think I read that as well.
Since you have completed your build my question would be is it worth the money and or trouble?
I certainly don’t want to suggest it isn’t, but there have been very few (none?) samples comparing the potential advantages to going down this path. I certainly understand that some improvements are not visually quantifiable by photographic A/B comparisons but maybe anyone who has seen the benefits can try to define them, maybe something more than the “best upscaling”. Again, not denying that MadVR is the best but - what is it? My system is a monster right now, with more components by the day. The thought of introducing more complexity makes me pause.
Would love to hear your thoughts, as a new user.
post #79 of 236 Old 03-09-2019, 03:11 PM
ddgdl's Avatar
Quoted: 350 Post(s)
Liked: 328
There are some fantastic comparison screenshots of madvr upscaling here. Compare anything to NGU sharp and prepare to have your mind blown. For example, under the image doubling heading, compare how well madvr NGU upscaling does with a 480p photo compared to, say, the original. It almost perfectly recreates it!
https://forum.doom9.org/showthread.php?p=1840876
Best example is the photo labeled Corporate Photo. Look at the 540p photo, then the bilinear of the nvidia shield, then the NGU very sharp
ddgdl is online now
post #80 of 236 Old 03-09-2019, 04:25 PM
markmon1's Avatar
Liked: 3473
The RTX might be better in future, but for $500 I'd snag a 1080ti
markmon1 is offline
post #81 of 236 Old 03-10-2019, 10:10 AM
Rookie Member
Quoted: 77 Post(s)
Liked: 31
Thanks! I am impressed.
Also, thanks Markmon, I am going to purchase the ti card today. Thanks all
post #82 of 236 Old 03-10-2019, 03:43 PM
Rookie Member
Quoted: 77 Post(s)
Liked: 31
I would love to see some upscaling samples from 1080 to 4K. Do you know of any?
post #83 of 236 Old 03-10-2019, 03:51 PM
ddgdl's Avatar
Quoted: 350 Post(s)
Liked: 328
I don't know of any, but it has been said that NGU sharp is as good as, if not better than, the upscaling machines that production companies use when upscaling a 1080p master to 4k for new UHD disc releases. That makes sense because it is based on a trained neural network. So, if it is able to get that close to the original from a terrible 540p source, it will be able to almost perfectly recreate a 4k source from a 1080p file in upscaling, since it has that much more info to work with in the 1080p file vs the 540p
ddgdl is online now
post #84 of 236 Old 03-10-2019, 03:55 PM
Rookie Member
Quoted: 77 Post(s)
Liked: 31
Thanks, that is encouraging. My reason for going with MadVR is the upscaling testimonies I hear from you good people here on the forum. Thanks for your help
post #85 of 236 Old 03-10-2019, 04:00 PM - Thread Starter
tommarra's Avatar
Quoted: 641 Post(s)
Liked: 384
Tbh I am still figuring it out. Watched Bladerunner yesterday but spent most of my time configuring MadVR. it looked good - but again I didn’t understand half the settings plus I did not get time to do an A/B with my shield.
I am not going to use upscaling a lot since I just started building my Blu-ray collection and will be mostly buying 4K blu rays
tommarra is offline
post #86 of 236 Old 03-10-2019, 04:19 PM
Rookie Member
Quoted: 77 Post(s)
Liked: 31
Yes, it sounds complex. I assume you are interested in the tone mapping. How much did your build end up costing. Which video card did you go with? I assume playback with the card you chose is stable? Lots of questions.
post #87 of 236 Old 03-10-2019, 06:41 PM - Thread Starter
tommarra's Avatar
Quoted: 641 Post(s)
Liked: 384
Total it cost me ~660, with RTX2060
So far no issues everything is stable. I haven’t tried upscale of 1080 content. Tone mapping works quite well.
Hopefully will be able to play more tonight and post impressions with native JVC tone mapping
tommarra is offline
post #88 of 236 Old 03-10-2019, 07:12 PM
Quoted: 109 Post(s)
Liked: 131
What do you have for your windows and Nvidia settings as far as refresh/color depth/etc?
dgrizzard is offline
post #89 of 236 Old 03-11-2019, 08:37 AM - Thread Starter
tommarra's Avatar
Quoted: 641 Post(s)
Liked: 384
For some reason I can only get RGB 8 Bit on the card. I have set the GPU and MadVR to Full Range (0-255) and have the JVC NX7 set to auto.
If I set JVC to video I get more contrast but blacks are crushed quite a lot.
tommarra is offline
post #90 of 236 Old 03-13-2019, 08:48 AM - Thread Starter
tommarra's Avatar
Quoted: 641 Post(s)
Liked: 384
Updated the first page with HTPC and MadVR settings I am using.
Would appreciate any feedback and tweaks.
Happy to include your settings on the main page if you have played around with MadVR as well …
Bill DePalma likes this.
tommarra is offline
Reply Home Theater Computers
