MadVR HTPC build for JVC NX7 projector - a build! - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 43Likes
post #151 of 235 Old 04-09-2019, 01:27 PM
riddle's Avatar
Quoted: 118 Post(s)
Liked: 54
Originally Posted by tommarra View Post
You probably have too many image enhancements for 4K content (sharpening, dithering, etc.)
Press CTRL+J, and make sure your render times are less that 41ms for 4K 23hz content, and less than 16ms for 4K 60Hz content.
Unless you mean stuttering and not dropped frames - in which case its a driver issue - try to to use .34 or .35 driver. You can get it from Nvidia site.
this is one of my seting for RTX 2060, i7 7700t with 16GB DDR4 RAM and SSD HDD
riddle is offline
post #152 of 235 Old 04-09-2019, 08:37 PM - Thread Starter
tommarra's Avatar
Quoted: 572 Post(s)
Liked: 340
With these render times of 14ms you should not have any dropped frames.
I think you might be suffering from stuttering that some drivers can have on RTX cards.
Use the version 419.34 or 35 (March 5, 2019) from Nvidia website and see if this corrects itself.
See this link for recommended cards
https://forum.doom9.org/showthread.php?t=176013
markmon1 and riddle like this.
Gear: Fronts: B&W 803D3 | Center: B&W HTM2D3 | Surrounds: B&W 705S2 | Backs: B&W DM601S3 | Heights: Definitive Techonlogy ProCinema 1000 | Receiver & Amps: Anthem MRX 720 + Emotiva BasX-5 | Projector: JVC NX7 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is offline
post #153 of 235 Old 04-09-2019, 09:51 PM
markmon1's Avatar
Quoted: 4634 Post(s)
Liked: 2942
You have two interesting indicators in that screen shot. First, you have 110 dropped frames, which is a ton. Second, you have 14ms render times which is great. Perhaps your issue isn't processing but some sort of buffering issue. Why not crank your queues up from 16 and 8 to something big like 64/32?
riddle likes this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #154 of 235 Old 04-09-2019, 10:11 PM
riddle's Avatar
Quoted: 118 Post(s)
Liked: 54
I will try it... thanks
riddle is offline
post #155 of 235 Old 04-09-2019, 10:12 PM
riddle's Avatar
Quoted: 118 Post(s)
Liked: 54
Hi markmon1, can you plz explain me whre i can set it?
riddle is offline
post #156 of 235 Old 04-09-2019, 11:48 PM
markmon1's Avatar
Liked: 2942
In the settings under rendering, general at the bottom there are 2 sliders. I am using 32 and 16 on mine.
markmon1 is offline
post #157 of 235 Old 04-11-2019, 02:01 AM
riddle's Avatar
Quoted: 118 Post(s)
Liked: 54
Hi, this is ma old Nvidia GPU drivers with changes to 64/32...
And its still not play well :-)
riddle is offline
post #158 of 235 Old 04-11-2019, 03:41 AM
markmon1's Avatar
Liked: 2942
What does "its still not play well" mean? According to that screen shot, you're rendering in 15ms average and are well below the threshold to drop frames.
markmon1 is offline
post #159 of 235 Old 04-11-2019, 03:59 AM
riddle's Avatar
Quoted: 118 Post(s)
Liked: 54
Its litlle tricky to write, but i see some time little shuttering as well on 1080p too. There must be somethink what i missed to set.. :-)
riddle is offline
post #160 of 235 Old 04-11-2019, 04:01 AM
markmon1's Avatar
Liked: 2942
Perhaps you should take that to heart?
markmon1 is offline
post #161 of 235 Old 04-11-2019, 04:06 AM
riddle's Avatar
Quoted: 118 Post(s)
Liked: 54
Yesi my drivers are now 419.35
riddle is offline
post #162 of 235 Old 04-11-2019, 04:08 AM
markmon1's Avatar
Liked: 2942
Whats your player? Where is your content located? Local hard disk? Network share?
markmon1 is offline
post #163 of 235 Old 04-11-2019, 04:11 AM
riddle's Avatar
Quoted: 118 Post(s)
Liked: 54
Mpc-hc and all is on local HDD
riddle is offline
post #164 of 235 Old 04-11-2019, 04:38 AM
Onkyoman's Avatar
Quoted: 941 Post(s)
Liked: 579
Are all your files playing that way? Your picture at post #157 shows all the queues are full, but you say you are dropping frames rather than getting stutter? It looks like the file is being rendered correctly. The file shown also has no HDR metadata. I don't understand how it could be skipping frames. Try using another media player like MPC-BE.
riddle likes this.
Onkyoman is online now
post #165 of 235 Old 04-11-2019, 04:55 AM
riddle's Avatar
Quoted: 118 Post(s)
Liked: 54
Ok, i will try it. Did you try on MPC-BE some 3D MVC video with MadVR? I think i was some problem on it but its was long time ago...
riddle is offline
post #166 of 235 Old 04-11-2019, 04:59 AM
Onkyoman's Avatar
Quoted: 941 Post(s)
Liked: 579
It is possible to play 3D videos with MPC-BE. I haven't tried it recently, but it is known to work.
riddle likes this.
post #167 of 235 Old 04-12-2019, 09:47 AM - Thread Starter
tommarra's Avatar
Quoted: 572 Post(s)
Liked: 340
For rendering methods - I noticed that using Full Screen Exclusive significantly reduces the render times.
Question I have is whether I should use Direct X 11 option or not? What is the benefit of one vs. the other?
tommarra is offline
post #168 of 235 Old 04-13-2019, 01:51 AM
riddle's Avatar
Quoted: 118 Post(s)
Liked: 54
Ok, in MPC-BE i see no shuttering compare to MPC-HC
markmon1 likes this.
riddle is offline
post #169 of 235 Old 04-13-2019, 06:01 AM
Onkyoman's Avatar
Quoted: 941 Post(s)
Liked: 579
The D3D11 option is needed for 10-bit output from madVR. It might also be faster to enter and exit fullscreen exclusive mode with it enabled.
Improvements with rendering times with windowed mode vs. fullscreen exclusive mode tend to be fake. The rendering stats are likely inaccurate, as there is not supposed to be any difference between the two. It just changes the windowed mode of the player.
post #170 of 235 Old 04-14-2019, 06:02 PM - Thread Starter
tommarra's Avatar
Quoted: 572 Post(s)
Liked: 340
Thank you.
One more question - on my PC I have a lot of streaking (seems like bright areas of scenes with high contrasts clip and there are bright streaks) this happens not just on MadVR but also on other video playing through the stock windows video player.
I tried to use newer drivers, change contrast setting but nothing helps.
Worst offender is in How to train your dragon hidden world ... final scene of battle where there is a lot of fire and lightning... all of that has lot of streaking on faces and fires.
Any advise?
tommarra is offline
post #171 of 235 Old 04-15-2019, 05:35 AM
Onkyoman's Avatar
Quoted: 941 Post(s)
Liked: 579
Is the content HDR or SDR? Clipping sounds like a video levels issue or contrast that is not set correctly on the projector. Have you tested for black and white clipping with SDR 16-235 clipping patterns, like these (under Basic Settings):
https://www.avsforum.com/forum/139-d...libration.html
post #172 of 235 Old 04-18-2019, 11:44 AM - Thread Starter
tommarra's Avatar
Quoted: 572 Post(s)
Liked: 340
I wasnt the only one. I guess it was happening because I had motion enhance turned on. Turning it off removed all the artifacts. It was not really clipping but in-frame artifact.
Thanks for all the suggestions.
tommarra is offline
post #173 of 235 Old 05-02-2019, 07:40 AM
Quoted: 76 Post(s)
Hi, I have been using MadVR with my NX7 and loving almost everything. My last issue I am trying to troubleshoot is a stutter that is only noticeable in long (20 seconds or more) pan shots. I will typically see one stutter in that time. I am using windows 10 and kodi dsplayer. My render times are around 23 msec and madvr reports one repeated frame every 10 minutes or so. There are almost no dropped frames after the first 5 seconds of playback. My graphics card is an nvidia rtx 2070 using driver version 419.35.
Any advice on things to try would be greatly appreciated. Thanks.
cogdok is offline
post #174 of 235 Old 05-02-2019, 09:28 AM - Thread Starter
tommarra's Avatar
Quoted: 572 Post(s)
Liked: 340
Is your MadVR or KodiDS player set to auto frame match. Typically PCs are using 60fps and if the content is 24 FPS you will see stutter in pan shots due to frame rate pulldown.
In my setup I had to use MPlayerHC to auto switch the frame rate ... for some reason MadVR itself was not switching the frame rate for me.
Also make sure you turn off CMD in the projector.
tommarra is offline
post #175 of 235 Old 05-31-2019, 03:13 AM
FGEvans's Avatar
Quoted: 80 Post(s)
To get best HDR - you would create a custom picture mode:
Color: HDR
White: 6500K
Gamma: 2.4
Input Space: Auto
In MadVR:
Set Gamma to 2.4
Display: Full (0-255)
In Nvidia Driver:
Colorspace: RBG
Bits: 8 or 12
RGB: Full
Also on my NX7, if i use a Contrast of >0 then i get some highlight clipping (where the color shows up as White streaks) so now my Contrast is 0, Brightness -2
is that correct. I understood that by selecting a HDR colour profile you defeat the purpose of the tone mapping. I assume you would chose bt 2020 as the colour range. I may be wrong as i am just starting out and have read conflicting posts already.
also how do i actually load a new build. Does it replace the existing madvr file i have and hence i lose the current settings for everything else or does it keep existing settings and just add new options.
FGEvans is offline
post #176 of 235 Old 05-31-2019, 05:13 AM
ddgdl's Avatar
Quoted: 330 Post(s)
Liked: 298
Color: HDR
White: 6500K
Gamma: 2.4
Input Space: Auto
In MadVR:
Set Gamma to 2.4
In Nvidia Driver:
Colorspace: RBG
Bits: 8 or 12
RGB: Full
Setting the color space in the jvc to HDR just means bt2020 but without the color filter in place, for slightly more brightness but a lower percentage of the DCI-P3 color space. If you have madvr do the pixel shader tone mapping, the jvc thinks it is getting a SDR signal and doesn't do anything to it
ddgdl is offline
post #177 of 235 Old 05-31-2019, 06:46 AM - Thread Starter
tommarra's Avatar
Quoted: 572 Post(s)
Liked: 340
HDR and BT.2020 are both used for HDR. BT2020 uses the color filter to get 100% DCI coverage.
To load a new build just replace the file from Madshi test build in your current MadVR folder. All settings are retained. You might have to tweak setting in the HDR section (under Display)
I have build a few batch files to automate color profile selection and lens memory for a network connected PJ if MadVR detects HDR. I will post them i this thread as well
If you want to back up your settings make a copy of settings.bin file in the MadVR.
tommarra is offline
post #178 of 235 Old 05-31-2019, 08:03 AM
FGEvans's Avatar
Quoted: 80 Post(s)
cheers so i need to tell madvr to pass through the HDR meta data
also do i pick a custom picture option on the projector and then use that for the tone mapping. Also what lamp level do most people use ie low or high.
i also assume i dont have to worry about using the measurement tool that is referred earlier in the tone mapping post
FGEvans is offline
post #179 of 235 Old 05-31-2019, 11:34 AM
ddgdl's Avatar
Quoted: 330 Post(s)
Liked: 298
You posted this in three different threads.
No, don't pass through the HDR metadata. You can do anything you want on the projector but the best setup is likely User 1, HDR color, 2.4 gamma, brightness -2, iris set to 0 under manual mode and then switched to auto 2 mode
ddgdl is offline
post #180 of 235 Old 05-31-2019, 12:22 PM
FGEvans's Avatar
Quoted: 80 Post(s)
FGEvans is offline
Reply Home Theater Computers
