MadVR HTPC build for JVC NX7 projector - a build! - AVS Forum | Home Theater Discussions And Reviews
 56Likes
post #1 of 300 Old 02-26-2019, 07:03 AM - Thread Starter
tommarra's Avatar
Quoted: 1016 Post(s)
Liked: 597
I recently purchased a JVC NX7 projector, a fabulous piece of equipment, that displays a really good image.
But like all things there is room for improvement, mostly on HDR tone mapping.
Therefore I have decided to build a HTPC with MadVR to handle the 1:1 blu-ray rips. I currently use Nvidia Shield to play these using Kodi.
An added benefit would be that I will be able to use Netflix Windows 10 app, and get Atmos support (something the Shield lacks)
So without much adieu, here is my partlist:
https://pcpartpicker.com/list/jfgMNQ
I will also add FLIRC Universal Remote Control Receiver to easily control the PC with my Logitech Harmony remote.
https://www.amazon.com/dp/B01NBRBWS6..._JrvDCbQXTP9Q1
Also I have Mobile Mouse Pro app on my phone, that will be used to provide basic keyboard and mouse functions.
I plan to use Windows 10 as the operating system - I will use the free version from MSFT website - unless they require activation at some point in future - wherein I will reuse a spare licence I already have.
Finally, you will notice in the part-list that there is no large capacity hard drive. My movies are stored on my Synology NAS, as well as on a 8 TB USB3 HDD I bought from Costco a few months back.
To be continued ...
Gear: Fronts: B&W 804D3 | Center: B&W HTM2D3 | Surrounds: B&W 684S2 | Backs: B&W 684S2 | Heights: B&W DM601S3 | Subs: 3x PSA S1500 Receiver & Amps: Arcam AV40 + Monoprice Monolith 7x200 + Outlaw 7000x | Projector: JVC NX7 | Screen: 126 inch 16:9 Stewart Studiotek 130 G4 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is online now
post #2 of 300 Old 02-26-2019, 07:04 AM - Thread Starter
tommarra's Avatar
Liked: 597
*Reserved* Part pics, build pics and suggestions
CPU: Intel - Core i3-8100 3.6 GHz Quad-Core Processor ($118.99 @ Amazon)
Motherboard: Gigabyte - H310M A Micro ATX LGA1151 Motherboard ($55.99 @ Amazon)
Memory: Patriot - Viper Elite 8 GB (1 x 8 GB) DDR4-2666 Memory ($45.99 @ Amazon)
Storage: ADATA - XPG SX6000 128 GB M.2-2280 Solid State Drive ($28.99 @ Newegg Business)
[b]Video Card:EVGA RTX2070 ($484.99 @ BHPhotovideo)
Case: Rosewill - Line-M MicroATX Mini Tower Case ($39.99 @ Amazon)
Power Supply: Corsair - CX (2017) 450 W 80+ Bronze Certified ATX Power Supply ($19.99 @ Newegg)
Other: FLIRC USB (2nd Gen) Universal Remote Control Receiver for Media Centre, Raspberry Pi, Kodi and Set Top Boxes
Total: $659.93
post #3 of 300 Old 02-26-2019, 07:05 AM - Thread Starter
tommarra's Avatar
Liked: 597
JVC Settings
Five things that are quite important.
#1 Turn on Low Latency. Turn off Motion Enhance. Turning on Motion Enhance can cause artifacts in a lot of movies (e.g., in the night scene where the truck us stuck in Sand in Mad Max Fury Road). Note currently as of May 3, 2019, while using DI with HDR color profile causes yellowing. Using BT2020 does not have yellow DI - at the cost of ~10% light output. Personally, I am using BT2020 profile, and just have MadVR tonemap to a lower target nit.
#2 If you have a large screen (120 inch and above), use the HDR color profile vs BT.2020 - you will need the extra light output to really let HDR shine
#3 Keep the contrast setting at 0, Brightness as -2 or -3 to get the best contrasts.
#4 Personally I find using gamme 2.2 better than gamma 2.4
#5 Input range: Set to 16-235. (setting it to Auto, or full causes the image to wash out - you get more detail in the dark areas, but the contrast really suffers)
Windows 10 settings:
Resolution: 3840 x 2160, 23p. I use 24Hz as this minimizes the sync when a movie starts since most movies are in 24 fps
Windows HD color: Turned off in Windows. We will let MadVR use Nvidia APIs
Optimize content: For video
Nvidia GPU setting:
Bit depth: RGB, 8bit, Full color (On my card using HDMI, I can only select 8bit. Which should not be a problem -- atleast from what I have read)
Nvidia RTX Card’s suffer from stutter. Refer to the following threads for recommended drivers if you experience stutter.
https://forum.doom9.org/showthread.php?t=176013
post #4 of 300 Old 02-26-2019, 07:05 AM - Thread Starter
tommarra's Avatar
Liked: 597
MadVR settings for JVC NX7
MadVR settings on Madshi's #78 test build:
Link to the build http://madshi.net/madVRhdrMeasure78.zip
These settings are dependent on the setup you have. So I would like community help in building out a scenario specific list. Anyone who has tried MadVR with a JVC PJ please chime your settings and I will add them here
[I]Setup: JVC NX7
Screen: XYscreens 4K Soundmax (~1.0 gain), 130" gain.
Nits: Real peak nits ~ 70
Lamp and Iris:Low lamp with Auto iris, Manual iris set to 0
I found that in the test build setting Target Nits (green colored text) has no impact. Changing Maximal target nits and dynamic tuning are the real drivers. Other settings are parameter to improve scene detection - which I am not very familiar with so I defaulted them to @Neo-XP settings
For "consumers" changing the two settings above should do the trick.
Changing the Maximal target nits lower brightens the image. I found that setting it close to the actual nits I get gets me the best picture.
Changing the Dynamic tuning subtly alters the image. For my setup 100 shows the best results.
My basic MadVR settings (still WIP) are in this folder. People interested in setting only HDR tonemapping refer to the screen shot labeled MadVR tonemapping
https://1drv.ms/f/s!AlvdMbnqRAsKgbFp-SAe24wjpk0CWw
Name:	MadVR tone mapping settings on Build 79.jpg
ID:	2538392   Click image for larger version
Name:	MadVR basic setup 4.jpg
ID:	2538394   Click image for larger version
Name:	MadVR basic setup 3.jpg
ID:	2538396   Click image for larger version
Name:	MadVR basic setup 2.jpg
ID:	2538398   Click image for larger version
Name:	MadVR basic setup 1.jpg
post #5 of 300 Old 02-26-2019, 10:06 AM
dlinsley's Avatar
Quoted: 701 Post(s)
Liked: 563
How is the noise on the Zotac? There was a link posted (I think on the main building a 4k HTPC for MadVR thread) to a German review site that compared a bunch of 2060 boards and found the Asus and MSI significantly quieter under load than the eVGA.
dlinsley is online now
post #6 of 300 Old 02-26-2019, 11:16 AM - Thread Starter
tommarra's Avatar
Liked: 597
I dont have the card on me yet ... will be a few days before Newegg gets it to me.
I went by this reviewers recommendation to buy Zotac over MSI based on the pitch of the sound (lower freq vs. higher freq). Sounds compare at ~11 mins
post #7 of 300 Old 02-26-2019, 01:21 PM
mlknez's Avatar
Quoted: 660 Post(s)
Liked: 221
You chose a loud power supply. What cooler are you using on the CPU?
Media Room: LG oled65c7, Marantz AV8805, Sherbourn 7/2100, Emotiva A-300, Studer A80, Studer Revox b795, Nakamichi RX-202, HTPC, exaSound e38, Sweetvinyl Sugarcube SC-2, (2) Piega P10, Piega Coax Center, (6) Piega AP 1.2, Hsu VTF-15h mk2
Office: Emotiva mini-x A100, Geek Pulse, (2) KEF LS-50, Goldenear FF 4, PC, NAS 130TB
Bedroom: Panasonic TCP55vt35, Marantz NR1200, Dune 3 Prime, (2) Elac Uni-Fi UB5
mlknez is online now
post #8 of 300 Old 02-26-2019, 04:15 PM
markmon1's Avatar
Quoted: 6760 Post(s)
Liked: 4866
I'd pick up a logitec k400 keyboard / trackpad combo. They're great for this type of thing.
dj4monie, 12GAGE and tommarra like this.
JVC Control - my software for controlling JVC projector via IP control.
Smart Masking - See my automatic smart screen masking system.
JVC IR Codes - free online pronto code converter for JVC IR codes.
markmon1 is offline
post #9 of 300 Old 02-26-2019, 05:10 PM
whiteboy714's Avatar
Quoted: 1889 Post(s)
Liked: 811
I have been eyeballing the Zotac card a bit myself, seems like one of the only decent dual fan models at MSRP. But their resale value is one of the worst, and also the warranty is two years instead of the standard three from most GPU makers.
TCL 65R625 -- Denon X3500h -- Klipsch RP600m -- RP450C -- Ascend HTM 200 SE -- Dual Klipsch RW-10
whiteboy714 is online now
post #10 of 300 Old 02-27-2019, 06:07 AM - Thread Starter
tommarra's Avatar
Liked: 597
Stock cooler. I think MadVR is not CPU heavy so don’t think I need anything more.
At 19 bucks the power supply was too much to pass . If it indeed is very loud I will get something else. Newegg gives me 30 days...
post #11 of 300 Old 02-27-2019, 08:47 AM
mlknez's Avatar
Quoted: 660 Post(s)
Liked: 221
The stock cooler is loud also. That is why i asked. You are right that the stock cooler is fine for keeping the cpu cool.
post #12 of 300 Old 02-27-2019, 09:30 AM
kennethav's Avatar
Quoted: 83 Post(s)
Thanks for starting this thread. I'll be following your progress... and doing my own build at the same time. My build is a bit downscale from yours (JVC RS400, PC built from salvaged parts plus a new Radeon 580), so it'll be a good contrast.
Question for you... are you confident that madvr can tonemap netflix HDR from the windows app? I've searched around for people doing that and haven't found confirmation that it can work.
kennethav is offline
post #13 of 300 Old 02-27-2019, 10:06 AM
SirMaster's Avatar
Quoted: 1338 Post(s)
Liked: 991
It absolutely cannot. madVR works only with the media players listed on the website.
http://madvr.com
SirMaster is online now
post #14 of 300 Old 02-27-2019, 10:11 AM
kennethav's Avatar
Quoted: 83 Post(s)
http://madvr.com
OK, thanks. It's great to get resolution on that, but definitely disappointing. Do you think it'll happen at some point?
post #15 of 300 Old 02-27-2019, 10:16 AM
SirMaster's Avatar
Liked: 991
I very highly doubt there would ever be a way to feed a DRM-filled stream into a third party video renderer such as madVR.
dgrizzard likes this.
post #16 of 300 Old 02-27-2019, 11:55 AM
ddgdl's Avatar
Quoted: 379 Post(s)
Liked: 360
Originally Posted by Bill DePalma View Post
Just want to add my thanks for this thread. I have an RS600, awaiting arrival of the NX7. Very interested in building a MadVR HTPC. Unlike most of you, I know almost nothing about building a computer, although it seems straight forward. My question upfront is that I would really like the case to be a HTPC style/horizontal case. However, having enough room for the video card seems to be a sticking point. Asking opinions, if wanting to use this kind of case is unwise? Also, since I have no background in the PC game, I use Macs, would anyone like to put together a basic parts list that would include gear that was quiet, compatible and good enough for the task? My budget is 1k of below.
One of the best HTPC cases is the Silverstone GD09 or GD08, both of which have room for even the largest video cards.
The build listed above is more than enough for madvr. If you want it to be quieter, you can use a BeQuiet power supply and Noctua case fans instead of stock, plus a Noctua CPU cooler
ddgdl is offline
post #17 of 300 Old 02-27-2019, 03:48 PM
markmon1's Avatar
Liked: 4866
My list so far. Please let me know if see any issues
Bill d
https://pcpartpicker.com/user/bdepal...d/#view=Gzf3bv
Man dump that $114 window 10 pro purchase. You can get licenses for $10-30 on ebay and you can download windows 10 pro off microsoft's website. Further, if you never activate windows 10 pro, it works forever but you get no windows updates. For an HTPC this might be good as you never have to deal with pulling out a keyboard to handle it or click away nags. The watermark about activation can be disabled with a simple registry key entry.
Silentmac likes this.
markmon1 is offline
post #18 of 300 Old 02-27-2019, 04:47 PM
markmon1's Avatar
Liked: 4866
Good to know, any other stupid things you can spot?
I did purchase a windows 7 version off of 3bay for $35 to put on my Mac. That was a nightmare of not being able to register it officially. PITA! But I will give it a try. Thanks
Well you never need to "register" windows but if you can't activate it, you should get a refund. But if the HTPC isn't going to be used to go online and do other things, I prefer to just disable windows update. I mean you want the pc to just work with a remote not to have to keep pulling a keyboard out to click away constant update nags. I would disable updates for video card drivers, not install geforce experience, not enable any updates for anything. I guess if you're going online with it that's different. The best way to disable windows updates is to not activate windows and disable the watermark with a register key you can easily google. All this is legal as you'd be getting the software directly from microsoft and using just their tools to do it.
RapalloAV and Silentmac like this.
markmon1 is offline
post #19 of 300 Old 02-28-2019, 06:46 AM
damelon's Avatar
Liked: 355
You do know that you are likely promoting piracy right? Those are stolen keys. To each their own on how they obtain their windows installations on their own time but there is no "cheaper" way to get windows other than from microsoft, full retail boxes, oem, or through corporate/student licenses. Everything else is just skimmed keys from msdn etc resold on the internet. None of those sellers or "companies" are legit or legal. I wouldn't recommend telling others to do it that way.
On the flip side.. there was a way to use windows 10 as a demo early on using client setup keys which was perfectly legal. I'm not sure how long you could do it for, or how long it would last, or if it can still be done. I never looked into if this could work with an HTPC either. Might be worth investigating. *shrug* If you have an old windows 7 key you might still be able to use it to upgrade to windows 10 for free too. (At least you still could as of last year)
damelon is offline
post #20 of 300 Old 02-28-2019, 05:18 PM
kennethav's Avatar
Quoted: 83 Post(s)
Got my HTPC up and running. Tried JRiver as the front-end but it won't use HW acceleration with high-quality settings and my Radeon. So I switched to MPC-MC for now... figured that'd be simpler to get started than Kodi DSPlayer.
I used madvr default settings plus the recommendations here: https://www.avsforum.com/forum/24-di...l#post57654684
and checked 'measure each pixel'.
Also, I updated the calibration tab: I checked 'this display is already calibrated', BT2020, pure power curve, Gamma 2.4 (projector is using my SDR2020 mode, setup by ChadB)
Anything else I should be doing? It looks pretty good... but not sure it looks any better than just using Kodi out of the box. Source is some ripped HDR blu-ray movies.
Is there some well-known test scene I can use to do an A/B comparison? I've got Lucy & 5th Element ripped... I know those are fairly-commonly used discs for comparison.
post #21 of 300 Old 03-02-2019, 02:12 PM
ddgdl's Avatar
Quoted: 379 Post(s)
Liked: 360
And if anyone figures out exactly the right settings for an NX7 + Paladin DCR lens + madvr so that you can keep the lens in place all the time and have madVR do all the scaling, let me know! I've been reading numerous sites on this all day trying to figure this out
ddgdl is offline
post #22 of 300 Old 03-02-2019, 08:39 PM - Thread Starter
tommarra's Avatar
Liked: 597
Finally put together the PC ... Just waiting for the RtX2060 to be delivered Newegg shipping could not be slower. Taking a full 10 days to deliver!
But have run into problems installing Windows 10. Will have to troubleshoot tonight ...
post #23 of 300 Old 03-02-2019, 09:29 PM
markmon1's Avatar
Liked: 4866
There's no piracy being promoted here. The keys you buy on ebay come with CoA stickers. These are issued to system builders by microsoft and microsoft was paid for the CoA. There's no media provided you download straight from microsoft's website so there's nothing coming from MSDN etc.
You dont need any tricks. You can simply download windows 10 from microsoft's website and install it. Then never activate it, and it never expires. You have a watermark on the bottom right of the desktop, but you can disable that with a registry key.
markmon1 is offline
post #24 of 300 Old 03-02-2019, 09:44 PM
riddle's Avatar
Quoted: 207 Post(s)
Liked: 108
And what GPU GTX1660 TI?
riddle is offline
post #25 of 300 Old 03-02-2019, 11:19 PM - Thread Starter
tommarra's Avatar
Liked: 597
Rtx2060
post #26 of 300 Old 03-03-2019, 01:07 AM
Quoted: 630 Post(s)
Liked: 399
MadVr creator Madshi is releasing a MadVr Envy box that can tone map any source, no release date yet but he said soon, so that will definitely do netflix tone mapping.
JVC DLA X590/RS440 / BenQ LK970
madVR HTPC with 1080ti / Lumagen radiance pro 4242
Arendal 1723 LCR Monitors / M&K S150 Surrounds in 5.1.4 atmos setup / Yamaha AX2050 AVR / MiniDSP88BM audio processor/ beta3 6 channels Amp .
tnaik4 is online now
post #27 of 300 Old 03-03-2019, 04:48 AM
damelon's Avatar
Liked: 355
I apologize for the blatant blame without an addendum! If you get a physical CoA sticker (And not a photo of one) then that is awesome! I was referring more to places like your typical online key sellers like Kinguin, who re-sell the same keys over and over again, etc.
markmon1 likes this.
damelon is offline
post #28 of 300 Old 03-03-2019, 01:42 PM
Quoted: 165 Post(s)
Liked: 177
Got my HTPC running on my current desktop with a GTX1080. I may build another computer, but for now I will just run a long HDMI cable to my receiver. One thing I realized though during testing was that the HDMI cable I was using was an older cable so it couldn't reliably run 4K HDR. But during configuration I got to the HDR tone mapping portion and realized I was just sending SDR anyway so that actually cleared up my cable issues. I'm replacing it with another longer cable anyway that will run HDR just in case I need it in the future. Ordered my RS1000 from Mike this weekend so I'm just waiting for delivery now, very excited!
dgrizzard is offline
post #29 of 300 Old 03-03-2019, 06:18 PM
kennethav's Avatar
Quoted: 83 Post(s)
Updated my madvr to the latest test build and now I *do* see a small difference. The tone mapping adds a bit of detail in highlights that are blown out when watching in HDR mode.
But question is... is madvr one of those tools that provides a tiny improvement or a huge one? I realize that's subjective, and maybe my projector (RS400) isn't high-end enough to really benefit from the tone mapping over my custom curve. But I read so many raves about madvr, that I'm surprised my jaw didn't drop when I saw the results.
post #30 of 300 Old 03-03-2019, 06:23 PM
ddgdl's Avatar
Quoted: 379 Post(s)
Liked: 360
It takes a really long time to get just the right settings. But the best way to see a huge difference almost immediately is to use Soulnight's measurement optimizer tool with mostly default settings on a UHD file
Edit: also, while the tone mapping is really really good when you have the right settings, what really blows people away is the upscaling
ddgdl is offline
Reply Home Theater Computers
