Kodi video settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 03-29-2019, 10:54 AM - Thread Starter
velocci's Avatar
Quoted: 624 Post(s)
Liked: 44
Kodi video settings
Hi all, there is something wrong with my Kodi video settings on my Windows 10 computer that I have in my basement HT. when I watch a movie using kodi, the picture looks weird. it kind of looks over processed and the bright areas are way too bright. If I watch the same movie using media player classic, everything looks fine. What key video settings do you use in kodi?
Family Room: Onkyo TX-NR 646 AVR, Polk Audio RtiA3 fronts, Polk Audio CSiA4 center, BIC America F12 sub, Polk Audio RC-65i rears
Basement: Denon AVR-X3400 AVR, Klipsch RP280f fronts, RP450c center, SVS PB-2000 sub, Polk Audio RC-85i rears & surrounds
Www.jvpix.com
velocci is offline
post #2 of 11 Old 03-31-2019, 04:53 PM
mrfattbill's Avatar
Quoted: 147 Post(s)
Liked: 108
There is an option to set the color space within KODI. Flip that and try a movie. If you have Avengers, that is always my go to for checking color space early in a movie.
Bill
mrfattbill is offline
post #3 of 11 Old 04-01-2019, 06:21 AM - Thread Starter
velocci's Avatar
Quoted: 624 Post(s)
Liked: 44
ok thanks I'll try that.
Www.jvpix.com
velocci is offline
post #4 of 11 Old 04-17-2019, 06:04 PM
Liked: 0
I had that happen every time I upgraded to Kodi, found out it was an option in Settings / Player / Video and scrolling down to Processing. Allow hardware acceleration - DXVA2 was enabled. Make sure your settings is set to Expert. I disabled it and my video quality was perfect.
GamerBear is offline
post #5 of 11 Old 04-17-2019, 07:44 PM - Thread Starter
velocci's Avatar
Quoted: 624 Post(s)
Liked: 44
Bill
there is no such setting
Www.jvpix.com
velocci is offline
post #6 of 11 Old 04-17-2019, 08:02 PM
Jawaburger's Avatar
Quoted: 231 Post(s)
Liked: 230
The Kodi Wiki is amazingly helpful and covers all the video settings, I recommend browsing that. I have not had your issue, so I don't know how to correct it. I am also using Kodi on a Windows 10 PC.
Sharp LC-80LE844U | Marantz BD8002 | Marantz AV8003 | Marsh Sound Design A400s (FL/FR) | Marantz MM7055 (C/SL/SR) | PSA MTM 210T (FL/FR) | PSA MTM 210C (Center) | Phase Tech PC 3.1 (SL/SR/SB) | Dual PSA S1811 Subs
Jawaburger is offline
post #7 of 11 Old 04-18-2019, 05:03 AM - Thread Starter
velocci's Avatar
Quoted: 624 Post(s)
Liked: 44
so am i
Www.jvpix.com
velocci is offline
post #8 of 11 Old 04-22-2019, 02:27 PM
mrfattbill's Avatar
Quoted: 147 Post(s)
Liked: 108
Color Range
post #9 of 11 Old 04-22-2019, 02:53 PM
brazen1's Avatar
Quoted: 626 Post(s)
Liked: 357
Are you trying to playback SDR or HDR?
I suspect HDR so, if you use KODI v.18 or lower, make sure W10 HDR is off and the Pixel shader setting is selected.
If using v.19, it doesn't matter if W10 HDR is on or off but if on it will certainly affect the desktop. Still, Pixel shader should be selected. This allows proper HDR to SDR conversion. Also, go into video settings during playback and select Reinhard tone mapping.
HOW TO - Kodi 2D - 3D - UHD (4k) HDR Guide Internal & External Players
W10 1909 / MPC-BE\HC / PotPlayer / PowerDVD 19 / DVDFab Player 3&5 / KODI 19 videoplayer
GTX960 4GB / RGB Full 4:4:4 / 8bit Desktop mode =60Hz / 10/12bit Video mode = Matched Refresh rates IE 23,24,25,60Hz
65JS8500 UHD HDR 3D / Denon S720W
brazen1 is offline
post #10 of 11 Old 01-29-2020, 10:27 AM
Liked: 0
Use Kodi 18.5 and it looks much better than 17.6.
worm91100 is offline
post #11 of 11 Old 01-29-2020, 01:12 PM - Thread Starter
velocci's Avatar
Quoted: 624 Post(s)
Liked: 44
I gave up on kodi. i'm using Plex. much better.
Www.jvpix.com
velocci is offline
Reply Home Theater Computers
computer , home , kodi , theater
