any dvd vs rip (new to ripping) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-15-2019, 10:36 AM - Thread Starter
gerall's Avatar
Quoted: 59 Post(s)
Are there are any quality differences - video or audio - between playing a disc (blu ray 1080p and dvds) directly using any dvd hd and mpc vs a rip of that disc using mpc ? Also, is a rip with mkv the same quality as a rip to a folder structure with dvdfab? thanks
gerall is offline
post #2 of 3 Old 04-15-2019, 09:54 PM
whiteboy714's Avatar
Quoted: 560 Post(s)
Liked: 148
If you just do a rip then yes they are identical. For instance makemkv just takes the audio and video you want and puts it in a new container (the .mkv).
Quality will be exactly the same as watching the disc or ripping to folder structure (not taking into account different players that might be used.)
You can definitely also have an mkv that the quality has been changed, but that would require transcoding with something like handbrake.
whiteboy714 is offline
post #3 of 3 Old 04-16-2019, 07:03 AM
kjfalls's Avatar
Location: Dennison IL, just across the state line from Terre
Quoted: 310 Post(s)
Liked: 109
Ripping to disc many times result in "interstitial errors" because of lost samples. It is evident as sharp drops on a waveform. Most are not noticeable and those which are sound like an audio drop-out.
kjfalls is offline
Reply Home Theater Computers
