Why can't i get 4k? (prime,netflix) - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By skschatzman
post #1 of 10 Old 05-13-2019, 05:40 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 5
I cant for the life of me get 4k working on my PC. Please help me figure this out.
I have tried netflix and amazon prime and they never go above 1080p.
I have tried the w10 netflix app,edge and firefox.
My specs are
w10 pro
I7 8700k
1080 ti
vizio 2018 p65-f1
cox cable 300Mbps (wired)
williewonk is offline
post #2 of 10 Old 05-13-2019, 05:42 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 5
My specs are
w10 pro
I7 8700k
1080 ti
vizio 2018 p65-f1
Sorry cant figure out how to edit post...
But i also have the pc going through a yamaha 383 reciever and i did make sure that im hooked up arc and not hdmi5 limited to 1080p on tvs ports
post #3 of 10 Old 05-13-2019, 06:16 AM
skschatzman's Avatar
Quoted: 2498 Post(s)
Liked: 1510
This may be the problem. Try plugging the PC directly to the TV ports 1-4. Make sure Full UHD color is enabled for that port. Do a speed test on the PC to make sure you are getting enough bandwidth. Make sure the Netflix account subscription allows 4K/HDR. Check the display settings in Windows to make sure it detects your display as HDR compatible. Check the cable and make sure it is a "Certified Premium High Speed" cable. Word for word.
williewonk likes this.
skschatzman is offline
post #4 of 10 Old 05-13-2019, 06:46 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 5
Thank you ... I recently rearranged my room and i ended up using different hdmi cables on different devices than i previously was . I swapped the hdmi cables back to the way they were and now i have 4k , but its weird that same hdmi cable plugged into the ps4 pro still gets 4k..Oh well problem solved..
Thanks skschatzman
post #5 of 10 Old 05-13-2019, 06:54 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 5
Oh and i forgot while googling i read it could be that microsoft dropped hvec support without you downloading it from the microsoft store . So it could be that because i also downloaded and installed that right before the hdmi cable swap.
post #6 of 10 Old 05-13-2019, 10:30 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 470
Hevc support is now a paid option for win10. You have to pruchase it from store.
On the other hand, I don't believe Netflix or Prime is using Hevc anyway.
Sent from my Pixel 3 using Tapatalk
Foxbat121 is offline
post #7 of 10 Old 05-14-2019, 02:50 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 5
I did have to pay for the HEVC but it was only a dollar. Netflix's own site says that it's needed for w10 to stream 4k and links to the Microsoft store. I suspect that that missing this codec was the cause of not getting 4k in edge or netflix app.
I am too new to post a link to netflix's HEVC page telling you it's a requirement for w10 but just :
Google I'm not seeing Ultra HD 4K titles when I browse Netflix.
post #8 of 10 Old 05-14-2019, 08:29 AM
whiteboy714's Avatar
Quoted: 619 Post(s)
Liked: 162
Really?? Wow, is this to use it with "official" apps liek Netflix? Because it doesn't matter for something like Lav or Kodi right?
whiteboy714 is offline
post #9 of 10 Old 05-14-2019, 10:01 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 470
The HEVC video extension app works for apps that depend on Windows to decode the video such as the default Windows Media Player, Movies & TV app. Hevc decoding was part of the Win10 before but was pulled about 1 year ago after one of the update.
The reason behind this is that not many people were using it. It makes sense for Microsoft to save a few pennies and ask those who do use it to pay for the license fee. Same story when they pulled WMC out of the OS.
post #10 of 10 Old 05-14-2019, 02:02 PM
Quoted: 619 Post(s)
Liked: 162
I see thanks, too bad they didn't leave WMC as a paid add on.
Reply Home Theater Computers
