AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Home Theater Computers (https://www.avsforum.com/forum/26-home-theater-computers/)
-   -   Atmos really playing from Netflix app HTPC to Denon? (https://www.avsforum.com/forum/26-home-theater-computers/3068782-atmos-really-playing-netflix-app-htpc-denon.html)
WynsWrld98 05-21-2019 01:15 PM
3 Attachment(s)
Windows 10 HTPC (Intel NUC) with Netflix app having issues getting Denon to display Atmos on front of it/Info menu. HDMI connection directly between HTPC and Denon X6300H.
Playing Atmos content from Netflix app I'm confused by my Denon X6300H displaying Dolby Digital + on Info menu and front of Denon but when hitting the Movie button on Denon remote it automatically has Atmos selected as shown in the pics but why doesn't it show Atmos on Denon? So I'm not sure I'm really hearing Atmos. Then I played some Netflix titles that do not show Atmos on the Netflix info for the titles but when I hit the Movie button on the Denon it also has Atmos selected as shown in second picture which makes no sense.
When I play an MKV with Atmos on the HTPC the Denon displays Atmos correctly.
Has anyone else experienced this type of thing with Netflix app on HTPC to a Denon?
teachsac 05-21-2019 01:18 PM
From my understanding, Netflix Atmos is not supported on PC's.
WynsWrld98 05-21-2019 01:33 PM
Interesting. I would think it wouldn't show Atmos on the info page for the title. That's how I thought it worked that if the device can't playback Atmos it doesn't show up on the Netflix info page. Maybe for HTPCs it's a bit different than something like a Shield, Roku, etc. Hmmm.
WynsWrld98 05-21-2019 01:49 PM
From https://help.netflix.com/en/node/64066
Which devices support Dolby Atmos audio with Netflix?
The following devices support Dolby Atmos with Netflix. For exact device models with Dolby Atmos available, please visit the device manufacturer's website.
Apple TV 4K (requires tvOS 12 or later)
LG OLED TVs (2017 or newer models)
Panasonic TVs (2019 or newer models)
Pixela 4K Smart Tuner
Roku TVs (2018 or newer models)
Sony BRAVIA Android TVs (2018 or newer models)
Toshiba TVs (2019 or newer models)
Vizio TVs (2018 or newer models)
Windows 10 computer or tablet (requires Windows 10 RS3 Build 16299 or later)
Xbox One, Xbox One S, and Xbox One X
Worf 05-22-2019 03:35 AM
Did you have the Atmos app for windows 10 setup and running? It should be free and you only need free mode as long as you have an Atmos amp.
WynsWrld98 05-22-2019 08:43 AM
Yes but for some odd reason in the Windows Sound if I click the Configure button Atmos is getting deselected. I'll select it, apply it, play something in Netflix and get Atmos on the Denon but then later I won't get Atmos then look at Configure and it's set to stereo vs. Atmos. Not sure why/how it's getting deselected, weird and annoying.
denyam 05-27-2019 06:36 AM
I have a similar problem with my own x4100w Denon. It shows as a device that is connected to the desktop. After the last update of windows 10, I can no longer see it as a default device in the sound settings. I get atmos for headphones but not for home theater????
Mark the Red 05-27-2019 01:33 PM
The whole problem arises from the fact that Windows 10 will only allow Atmos for your PC if you pay a license for it.
This creates a whole problem because nVidia has to cycle their drivers whether the user has an Atmos license or not. It's a big problem and I've beaten my head againsts the wall over it for months.
That said, when it IS installed correctly, Atmos works beautifully and my AVR sees it as such. The Punisher is a good Netflix show to demonstrate it.
WynsWrld98 05-27-2019 01:51 PM
I thought they only charge for Dolby Headphones when I installed the plug in.
rekbones 05-27-2019 08:07 PM
I had to reinstall this after the latest Win10 update and with an ATMOS AVR it is free, only the headphone app has a charge. This makes since as you already paid for the license when you bought the AVR. The update also clobbered my HDMI audio driver so I also had to reinstall the same version of that.
db999md 05-27-2019 08:30 PM
I wonder if this has something to do with the fact that netflix atmos is compressed dolby digital + the atmos info on top of it instead of the lossless atmos that you get on the HD blu-rays. For what it is worth, when you play atmos content from netflix on apple tv to my denon x4300h it shows atmos on the front of the receiver. I have an xbox one s in another room with a denon x2400h and that shows atmos on the receiver also when playing netflix atmos.
For what it is worth, as much as I generally dislike apple products I have found that the apple tv is the best awy to play dolby atmos from netflix. I used to use the xbox one s for this about 1 year ago but I got all kinds of dropouts with the denon and xbox one s. I think this may have been fixed with xbox firmware updates, but not 100% sure ( i do not watch atmos content much in that other room with the x2400h so I cannot really tell you if the problems are fixed.)
The bad thing about apple tv is there is no passthru of lossless audio to the receiver. SO if you have an atmos file and you want to play it with plex on the apple tx you are out of luck. For that I need to use the nvidia shield. Still looking for one device that will do everything! At least I now have it narrowed down to the shield and the appletv.
my HTPC does not have a good enough video card to play netflix 4k so I cannot try to duplicate your issue.
Dennis
WynsWrld98 05-27-2019 08:47 PM
Thank you Microsoft (sigh)
aerodynamics 05-29-2019 07:15 PM
Have the same question. I had my HTPC with a Zotac 1050ti connected to Denon S720 and a TCL P605. Whenever I played a movie with Atmos through the Netflix Win10 app, the AVR display showed Atmos.
I have since put an RTX2060 int he HTPC and switched to a Pioneer LX503 AVR and PX800HD projector and this changed all of my sound settings in Windows. When I select "Dolby Atmos for Home Theater" the changes never stick and always revert back to stereo. Now when I play an Atmos movie in the app, the new AVR shows DD+ and only five speakers are lit up in the display. I am not sure if I'm getting Atmos sound. If I play a movie labeled 5.1 in Netflix, the AVR also shows DD+.
WynsWrld98 05-29-2019 07:25 PM
In the Windows sound settings if you click the Configure button does it have Atmos selected? When my AVR was showing DD+ playing a Netflix Atmos movie it was because the Configuration setting was set to Stereo not Atmos. But every once in awhile that Configuration setting will change from Atmos to Stereo ; I have not been able to figure out a pattern when it does it. I'd bet if the AVR is showing DD+ vs Atmos it isn't playing Atmos.
aerodynamics 05-29-2019 07:37 PM
Nope. If I select Atmos, it always reverts back to stereo as soon as I close the window. If I select anything else, 5.1, 7.1, the changes take but I still see DD+ on the AVR.
WynsWrld98 05-29-2019 07:45 PM
That's different than the behavior I get with my setup.
rekbones 05-29-2019 07:50 PM
Mine with a 1050ti was doing the exact same thing after the latest Windows update. I did a right click on the audio icon and ran the fix issue. It gave me an option to reload the HDMI Audio driver and cleared up the issue. Atmos should still work for all your bitstream players but to get Netflix Atmos for me this needs to be set to Atmos.
aerodynamics 05-31-2019 04:32 AM
Welp, not sure what I did but last night I decided to fiddle around with the sound settings and low and behold, choosing Dolby Atmos for Home Theater actually kept this time. When I now play an Atmos movie in the Netflix app, my AVR shows "Atmos/D+" and all 7 speakers light up.
dfa973 05-31-2019 04:48 AM
Try to reinstall the audio drivers and search for updated audio drivers.
NOT TRUE! Atmos works just fine for free if you have a receiver.
The pattern is this:
1. after each Windows feature update -> reset to Stereo
2. if you start the Audio configuration wizard but you cancel midway or fail to set it properly -> reset to Stereo
denyam 05-31-2019 08:28 AM
I thank you for your support, I've done all of the things you mentioned. I even reset my window OS to previous versions ( still windows 10) now I see hdcp support, as well as the other hd version of audio. The problem now is that I have a different screen display on my TV screen than what I see on my desktop. I'm just gonna leave it alone for the moment to take my mind off it before I begin to lose my mind. Lol
ratbuddy 05-31-2019 08:32 AM
It is not necessary to set Windows to Atmos in order for Netflix to bitstream it to your receiver. I would actually recommend against doing so, since it usually does no good, and at worst can prevent your receiver from upconverting non-Atmos signals. The one exception would be games written to use that Atmos output mode, but there are still not many of those and you'll probably know it if you're playing one.
denyam 05-31-2019 08:34 AM
It's strange how this happened, because the desktop output is Hdmi to avrx4100 hdmi output to my tv. My tablet nuvision output hdmi to avrx4100 with atmos.. shows the same display on both the tablet and tv. The saddest thing i've encountered is that Microsoft doesn't have the ability, or just doesn't care about this thing
denyam 05-31-2019 08:44 AM
My internet service is too slow (Verizon doesn't provide fios in parts of Baltimore) as if the fact I am living here is not bad enough. I used Netflix from my phone and cast it to my Roku 3, which sends to my avr x4100w Denon. I get atmos with no problem. I was just trying to get it back to the setup I had before the last update of windows 10. Thanks for your support as well. It's not the worst thing I've encountered in my life, but I would just like to have what I have paid for with the Dolby access app on windows 10
denyam 05-31-2019 08:48 AM
There are a lot of videos on u tube that I really enjoy watching with the DSU on my audio system using 5.1.4
denyam 05-31-2019 08:53 AM
Whenever I play DDt, my avr x4100w always displays atmos on the info as Dolby digital plus input and Dolby atmos output
rekbones 06-01-2019 12:54 AM
Can you give us a way to do this? Even on the Netflix web sight it states you must install the Dolby Atmos App for it to work. This issue came back for me again after another Win10 update. This time I had to remove the Dolby Atmos app and reinstall it. Its now working but I fear another reboot will clobber it again. I have no issues bitstreaming ATMOS lossless with all my players its only DD+ lossey from Netflix that has issues.
ratbuddy 06-01-2019 05:26 AM
I don't really know, because I've never had to do anything special to get it working. I leave my Windows sound on 7.1, unless I'm playing a game that only supports 5.1, in which case I switch to that. When playing content from the Netflix app, the receiver simply switches to say DD+ or Atmos no matter what setting Windows was on. The Netflix app just takes over the audio connection and bitstreams whatever format the show is in.
What kind of video card are you using? I'm on Nvidia, maybe AMD or Intel have some issues with this?
edit: I should also try it here - I haven't used Netflix in about a month, maybe they broke something. Their dev team is pretty bad.
cchou11 05-05-2020 06:28 PM
For those of you still can't get the Netflix Windows 10 App output the Dolby ATMOS, I also have Denon X6300H receiver and the solution is to install the Dolby Access Windows 10 App and run its configuration with the home theater option. Once this is done, you should see the Dolby ATMOS under the speaker configuration and receiver will detect the decode the ATMOS successfully. By the way, the app is completely free.
dfa973 05-08-2020 05:04 AM
Originally Posted by cchou11 (Post 59599898)
...the solution is to install the Dolby Access Windows 10 App and run its configuration with the home theater option...
I can confirm that it works just fine!
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
