No sound from Kodi after resuming from sleep - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-22-2019, 04:30 AM - Thread Starter
Quoted: 155 Post(s)
Liked: 235
I've had a problem with having to restart my HTPC after it had resumed from sleep mode. The issue was that there would be no sound. Some nice folks over at the Kodi forum have provided a fix for this issue. I'm not sure if anyone has been frustrated by this issue but I wanted to pass the link along just in case.
https://forum.kodi.tv/showthread.php?tid=251833
lmidgitd is offline
post #2 of 5 Old 05-22-2019, 05:07 AM
Jawaburger's Avatar
Quoted: 183 Post(s)
Liked: 175
I realize this may just be a bandaid, but set your HTPC to never go to sleep. My computer is always on, and I know I am not alone in this tactic.
Sharp LC-80LE844U | Marantz BD8002 | Marantz AV8003 | Marsh Sound Design A400s (FL/FR) | Marantz MM7055 (C/SL/SR) | Phase Tech PC 9.1 (FL/FR) | Phase Tech PC 3.1 (C/SL/SR) | 3 Phase Tech Octave Power-15 Subs | 1 REL R-528 Sub
Jawaburger is offline
post #3 of 5 Old 05-22-2019, 06:16 AM - Thread Starter
Quoted: 155 Post(s)
Liked: 235
Yes I was thinking about doing that as well, but I'd like knowing that I'm saving a bit of energy letting the pc sleep. The linked page also states that you can cover HDMI pin #19 with electrical tape to solve the audio issue as well (however somebody says that covering the pin could cause other issues?).
Either way, I know this issue has caused me mild frustrations and I wanted to pass it along.
lmidgitd is offline
post #4 of 5 Old 05-23-2019, 02:47 AM
rekbones's Avatar
Quoted: 917 Post(s)
Liked: 480
Another way to fix this issue without restarting the PC is to just power off the AV receiver and power it back on. Unplugging the HDMI cable and plugging it back in also works but can be hard to do and puts a lot of stress on the cable and connector. Of course if you bring the PC out of sleep before the HDMI hand shake from the display it also won't fail over to internal audio.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is online now
post #5 of 5 Old 05-23-2019, 03:46 AM - Thread Starter
Quoted: 155 Post(s)
Liked: 235
Very true, excellent point. I was powering the receiver on before resuming from sleep (harmony remote sequence).
lmidgitd is offline
Reply Home Theater Computers
