Mpc-be - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Shark007
post #1 of 9 Old 06-03-2019, 05:11 AM - Thread Starter
FGEvans's Avatar
Quoted: 80 Post(s)
Mpc-be
I currently use MPC-HC and have that set up with madvr.
Is there any benefit using the BE version
FGEvans is offline
post #2 of 9 Old 06-03-2019, 01:10 PM
captain_video's Avatar
Quoted: 689 Post(s)
Liked: 415
Not really. MPC-BE is basically MPC-HC with MadVR built-in.
captain_video is offline
post #3 of 9 Old 06-03-2019, 07:48 PM
AVTechMan's Avatar
Quoted: 48 Post(s)
Liked: 40
No advantage in using BE....I usually use it for mostly testing out video playback before committing to server. I like the all black theme of BE too.
AVTechMan is offline
post #4 of 9 Old 06-04-2019, 05:11 AM
the_jaguar's Avatar
Quoted: 158 Post(s)
Liked: 50
One big advantage of BE over HC is its ability to auto mount ISO files. That is the only reason I use BE. Also, it appears there is active development happening with BE, while HC is in maintenance mode, but I am not a 100% sure about this.
the_jaguar is offline
post #5 of 9 Old 06-04-2019, 11:00 AM
JeffR1's Avatar
Quoted: 1054 Post(s)
Liked: 508
Yes there is, at least for me.
When watching an UHD disc and decrypting on the fly, I have to tell MPC-HC what playlist to use _ I use Clone BD to find it.
I don't have to do this with MPC-BE, when I click on "FILE" and the "OPEN DISC" it plays the UHD disc, while MPC-HC will not.
Note that I'm still using Virtual Clone Drive to mount my ISO's _ not sure if that makes difference though _ probably not.
JeffR1 is offline
post #6 of 9 Old 06-07-2019, 02:31 AM
the_jaguar's Avatar
Quoted: 158 Post(s)
Liked: 50
Like I mentioned in the post above yours, with MPC-BE, you don't need to use any external ISO mounting software. BE does it all.
post #7 of 9 Old 06-07-2019, 11:48 AM
JeffR1's Avatar
Liked: 508
Yes, thanks, I realize that now, and yes, it works quite well, I watched an ISO of an UHD movie the other day and it played with out a hitch.
I'm finding that forced subtitles works much better with MPC-BE, I had to always choose different settings for MPC-HC to get them to work properly.
eg, on one of the Marvels movies the guy was speaking Russian and the forced subtitles were not working.
I had to enable English sub-titles and then tell it to display "forced sub-titles only" _ this seems to work with on BE with out having to keep enabling/disabling the settings.
It makes sense, since no one is updating MPC-HC anymore, it still works, but it takes more to get it there.
JeffR1 is offline
post #8 of 9 Old 06-09-2019, 07:30 AM - Thread Starter
FGEvans's Avatar
Quoted: 80 Post(s)
Cheers is there a way of importing my madvr settings into BE or will I need to manually set them again. I have quite a complicated madvr set up.
FGEvans is offline
post #9 of 9 Old 06-09-2019, 08:05 AM
Shark007's Avatar
Quoted: 94 Post(s)
Liked: 78
Within the BE settings - click on Video - select madVR as the renderer - done
jbcain likes this.
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
Reply Home Theater Computers
