separate display and audio through GTX1080 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-07-2019, 01:08 AM - Thread Starter
FGEvans's Avatar
Quoted: 80 Post(s)
I am not sure if this is possible.
I am currently having some drop outs with my pc. I have my pc connected to my Amp - my amp is then connected to my TV and also my projector. All other devices including xbox x do not cause a drop out and also i get no drop outs to my projector
the drop outs occur with my pc running into my sony xe940 TV.
my cables are mounted behind my walls (the main one from amp to TV)
i will try a new cable from pc to amplifier.
however my gtx1080 has one HDMI output and a couple of display ports. I was wondering if its possible to use the display port on the gtx1080 and send the video to my TV (using a display port/HDMI adaptor) and using the existing HDMI to my amp just for audio.
FGEvans is offline
post #2 of 4 Old 06-07-2019, 08:15 AM
mlknez's Avatar
Quoted: 441 Post(s)
Liked: 132
Amplifiers do not have HDMI ports
Media Room: LG oled65c7, Marantz AV8805, Sherbourn 7/2100, Emotiva A-300, Studer A80, Studer Revox b795, Nakamichi RX-202, HTPC, exaSound e38, Sweetvinyl Sugarcube SC-2, (2) Piega P10, Piega Coax Center, (6) Piega AP 1.2, Hsu VTF-15h mk2
Office: Emotiva mini-x A100, Geek Pulse, (2) KEF LS-50, Goldenear FF 4, PC, NAS 130TB
Bedroom: Panasonic TCP55vt35, Pioneer SX-N30, Dune 3 Prime, (2) Elac Uni-Fi UB5
mlknez is online now
post #3 of 4 Old 06-07-2019, 08:26 AM
Quoted: 89 Post(s)
Liked: 55
Yes, you can do that (I do it/something similar). Just need to be aware that Windows will see the amp (I assume you are talking about an AVR) as a display and have it set as a second monitor. You should be able to mirror the displays so you don't have a "ghost" display (a display that is non-functional).
Your issue seems like it would be cable related more than anything. How long is it/what settings are you using on your PC? Cable might be too long for 4K, 60hz, 4:4:4, 8bit? You could try dropping to 4:2:2 or 4:2:0 to see if you still have issues?
JediMindTrick is online now
post #4 of 4 Old 06-09-2019, 07:27 AM - Thread Starter
FGEvans's Avatar
Quoted: 80 Post(s)
Cheers yes it was a cable issue. Now works fine after replacing the hdmi lead
FGEvans is offline
Reply Home Theater Computers
