Recording HEVC Fios channel in WMC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-11-2019, 05:56 PM - Thread Starter
Eagle784's Avatar
Has anyone been able to record the Women's World Cup using WMC on Windows 7 and a Ceton PCI-E 4 tuner on Fios Channel 1499? It's recording audio only, and the screen in WMC just says Digital Audio Service.
Even assuming an HEVC codec isn't available to WMC, I would have expected the video stream to record so I could play it back in another player. Anyone know if this is a tuner limitation?
Eagle784 is offline
post #2 of 4 Old 06-12-2019, 11:10 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 473
I can't event tune to it (reporting channel not subscribed) in WMC. However, I'm able to view it in HDHR WIn10 App (with the 6/11 update) without problem. So, it is not a tuner limitation at all.
Also, it normally airs in channel 1498 with 1499 as a backup channel in case two matches need to be aired.
Foxbat121 is online now
post #3 of 4 Old 06-12-2019, 03:26 PM - Thread Starter
Eagle784's Avatar
Wait, you can use the HDHR app with Ceton tuners?
Eagle784 is offline
post #4 of 4 Old 06-12-2019, 03:34 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 473
Sorry, missed Ceton part. No, you can't do that. But I don't believe the tuner has any limitations. I use HDHR Prime tuner.
UPdate: I found out the problem on my WMC is that the channel 1498 is mapped to 1458 by the guide and there is nothing I can do to fix that. Ch1499 is not mapped but also currently doesn't have any signal either.
Reply Home Theater Computers
