Please recommend me a 10 or 12TB HDD - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By dfkimbro
  • 1 Post By ckronengold
  • 1 Post By annisman
post #1 of 12 Old 08-08-2019, 05:34 PM - Thread Starter
annisman's Avatar
Quoted: 115 Post(s)
Liked: 75
I use USB 3.0 HDD enclosures and I only have room for two more drives so I want to make them large.
Please recommend me the best and least expensive 10 or 12 TB hard drive for my needs.
My needs are: streaming MKV video files from the hard drive using my htpc, with some files being 4K HDR so pretty large (80 GB sometimes). I have mostly three terabyte Seagate barracuda but I also have a Western digital black 4tb + 2 Western digital 8tb drives and they all work flawlessly I believe they are all 7200 RPM but I'm not sure if that's a requirement. What do you guys think?
Edit: I take that back the 8tb drives are Seagate archive drives Seagate Archive HDD 8TB SATA 6GBps 128MB Cache SATA Hard Drive (ST8000AS0002) https://www.amazon.com/dp/B00XS423SC..._W-ltDb6ZHDHY2
LG B6 (Chad B. calibrated)
Yamaha 681 AVR
Polk Audio 3.1.2 Atmos
Panasonic UB820
Custom HTPC/Emby WMC/MPC-BE/MadVR
annisman is offline
post #2 of 12 Old 08-09-2019, 06:49 AM
ckronengold's Avatar
Quoted: 228 Post(s)
Liked: 99
I dont think there's any reason for you to use a Black drive or even be too concerned about 5400 vs 7200. Yes its faster. No, it isn't the bottle neck in the over all throughput.
I just picked up a couple of WD Red 10TB for under $200 each. If you don't need it today, keep an eye out for what goes on sale. Stay away from the 12tb. The biggest drives always have a premium price tag associated with them, so the cost per TB is high. I paid $200 for 10tb, and the 12tb were almost $300. Insane to pay $100 for 2tb, right?
Movies: Epson 5050 / Marantz 7010 / OPPO-103
Streaming: nVidia Shield / Roku Ultra / Chromecast Ultra
Speakers: MartinLogan Motion 40 (LR), Motion 50XT (center), Motion 2 (surrounds)
Server: Ubuntu 18.04, i7-8700 CPU
HTPC: Win10 Pro 64-bit, i5 750 Radeon HD 5850
ckronengold is offline
post #3 of 12 Old 08-09-2019, 08:47 AM
mlknez's Avatar
Quoted: 445 Post(s)
Liked: 135
10TB drives are going for $160 regularly.
Media Room: LG oled65c7, Marantz AV8805, Sherbourn 7/2100, Emotiva A-300, Studer A80, Studer Revox b795, Nakamichi RX-202, HTPC, exaSound e38, Sweetvinyl Sugarcube SC-2, (2) Piega P10, Piega Coax Center, (6) Piega AP 1.2, Hsu VTF-15h mk2
Office: Emotiva mini-x A100, Geek Pulse, (2) KEF LS-50, Goldenear FF 4, PC, NAS 130TB
Bedroom: Panasonic TCP55vt35, Pioneer SX-N30, Dune 3 Prime, (2) Elac Uni-Fi UB5
mlknez is offline
post #4 of 12 Old 08-09-2019, 11:16 AM
TornadoTJ's Avatar
Quoted: 1944 Post(s)
Liked: 626
For streaming videos, all that 7200 rpm gets you is more heat and noise.
TornadoTJ is offline
post #5 of 12 Old 08-09-2019, 05:15 PM - Thread Starter
annisman's Avatar
Quoted: 115 Post(s)
Liked: 75
Thanks guys, got any specific suggestions for one of these under 200$ 10TB hdds ? I mean is one as good as the next ? I want something that will last.
Yamaha 681 AVR
Panasonic UB820
annisman is offline
post #6 of 12 Old 08-11-2019, 09:04 AM - Thread Starter
annisman's Avatar
Quoted: 115 Post(s)
Liked: 75
Everything I see is closer to 300$, are there any specific drives that go on sale to look for ? And which vendor ?
Yamaha 681 AVR
Panasonic UB820
annisman is offline
post #7 of 12 Old 08-11-2019, 10:23 AM
dfkimbro's Avatar
Quoted: 193 Post(s)
Liked: 122
Western Digital Easystore from Best Buy is a pretty common deal. Usually $130-140 for 8TB AND 160 for 10TB. Sign up for alerts on slickdeals.net.
It’s an external drive that you’ll shuck for use in a PC. It’s usually a White Label drive these days, which is the same as a Western Digital Red drive for NAS use. The White Label drives usually have the newer pin set that may require tape or other modification to work with a newer power supply, but YMMV on that. There’s a couple reddit threads on how to do that.
This ones live now for a 10TB at $180 plus 20% off first purchase using Best Buy’s Google Express store.
https://slickdeals.net/f/13304662-10...archBarV2Algo1
ClearToLand likes this.
Well, Duncan, he's just this guy, you know?
dfkimbro is offline
post #8 of 12 Old 08-11-2019, 10:39 AM - Thread Starter
annisman's Avatar
Quoted: 115 Post(s)
Liked: 75
It’️s an external drive that you’️ll shuck for use in a PC. It’️s usually a White Label drive these days, which is the same as a Western Digital Red drive for NAS use. The White Label drives usually have the newer pin set that may require tape or other modification to work with a newer power supply, but YMMV on that. There’️s a couple reddit threads on how to do that.
This ones live now for a 10TB at $180 plus 20% off first purchase using Best Buy’️s Google Express store.
Thank you sir ! Just ordered one for 160$ (plus tax)
Yamaha 681 AVR
Panasonic UB820
annisman is offline
post #9 of 12 Old 08-12-2019, 09:05 AM
Quoted: 228 Post(s)
Liked: 99
Do a little reading on potential issues with shucked drives. Not that you should expect any issues, but in case you do, you'll know exactly why it happened and how to fix it.
dfkimbro likes this.
post #10 of 12 Old 08-12-2019, 09:19 AM - Thread Starter
annisman's Avatar
Quoted: 115 Post(s)
Liked: 75
Thank you. I'm going to be placing it in one of these HDD enclosures, any idea if I will still need the 3.3v mod ?
Mediasonic ProBox HF2-SU3S2 4 Bay 3.5" SATA HDD Enclosure - USB 3.0 & eSATA Support SATA 3 6.0Gbps HDD transfer speed https://www.amazon.com/dp/B003X26VV4..._MezuDbGN46N9M
Yamaha 681 AVR
Panasonic UB820
annisman is offline
post #11 of 12 Old 08-12-2019, 08:31 PM
dfkimbro's Avatar
Quoted: 193 Post(s)
Liked: 122
No, but at least one or two MediaSonic Probox devices are listed as working here.
https://www.reddit.com/r/DataHoarder...tb_compendium/
dfkimbro is offline
post #12 of 12 Old 08-14-2019, 06:21 PM - Thread Starter
annisman's Avatar
Quoted: 115 Post(s)
Liked: 75
https://ibb.co/7K44Znp
Worked like a charm, no volt mod required. What an awesome deal for 160$.
Yamaha 681 AVR
Panasonic UB820
annisman is offline
Reply Home Theater Computers
