WMC only sees 1 tuner - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 09-21-2019, 11:36 AM - Thread Starter
Liked: 0
With out loading Wintv 8 how can I get WMC to see both tuners... 1 works fine from my 2255 Hauppauge one doesnt.. If I load wintv which i can't cuz i dont have the code but i do have disk it recognizes both!
thanks
Edfhobbies is offline
post #2 of 15 Old 09-22-2019, 01:33 AM
Worf's Avatar
Quoted: 840 Post(s)
Liked: 567
I believe the hauppage wmc drivers say they only support one tuner? Check the documentation, I think it says so in the readme file.
Worf is offline
post #3 of 15 Old 09-22-2019, 04:53 AM
captain_video's Avatar
Quoted: 729 Post(s)
Liked: 423
WMC should recognize both tuners if that's a dual tuner card. If only one shows up when you run the TV signal setup, select the option to manually select the tuners instead of accepting the configuration that WMC gives you. All of your tuners should show up in the list of available tuners. I believe you have three options to choose from for the type of tuner - analog OTA, digital OTA (ATSC) or digital cable (cablecard). All tuners for the type you selected should be listed. Just scroll through the list and check each tuner you want to include. WMC will then be configured with the tuners you selected.
captain_video is offline
post #4 of 15 Old 09-22-2019, 05:23 AM
markmon1's Avatar
Quoted: 5245 Post(s)
Liked: 3413
Do both tuners show up in device manager?
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #5 of 15 Old 09-23-2019, 09:34 AM
Ken.F's Avatar
Quoted: 2290 Post(s)
Liked: 2570
Do you have any other tuners set up in WMC? I believe there's a 4 tuner per type limit. If you already have three ATSC tuners set up then WMC will only allow you to add one more ATSC tuner. If that's what's happening you can increase the tuner limit with TunerSalad. They used to charge you for it but they made it freeware a couple of years ago.
http://www.mychannellogos.com/tunersalad-dl
Ken.F is offline
post #6 of 15 Old 10-10-2019, 08:58 AM
sgbroimp's Avatar
Quoted: 305 Post(s)
Liked: 40
I run a Ceton 6 Pcie board and WMC sees all 6. Does my machine not know there is a 4 tuner limit (ha ha)?
Assassin HTPC + Echo, Sony 49XBR850, McIntosh MX151, MC202, MC7104, MS300, B+W 803D2, CWM's, Janus 1W Sub
sgbroimp is offline
post #7 of 15 Old 10-10-2019, 09:28 AM
Ken.F's Avatar
Liked: 2570
The Ceton software removes the 4 tuner limit.
Ken.F is offline
post #8 of 15 Old 10-10-2019, 10:12 AM
sgbroimp's Avatar
Quoted: 305 Post(s)
Liked: 40
That makes sense! So this limit should also not come in to play when I dump the WMC EPG and install the EPG123?
sgbroimp is offline
post #9 of 15 Old 10-10-2019, 10:17 AM
Ken.F's Avatar
Liked: 2570
You should be fine.
Ken.F is offline
post #10 of 15 Old 10-10-2019, 11:36 AM
sgbroimp's Avatar
Quoted: 305 Post(s)
Liked: 40
You should be fine.
Thanks much, Ken. Always appreciate your wisdom. I gather you are using EPG123 happily?
sgbroimp is offline
post #11 of 15 Old 10-10-2019, 11:46 AM
Ken.F's Avatar
Liked: 2570
I've been using EPG123 for a few years and never had any trouble with it.
Ken.F is offline
post #12 of 15 Old 10-11-2019, 05:52 AM
sgbroimp's Avatar
Quoted: 305 Post(s)
Liked: 40
Thank you, Ken. I gather they remind you once a year to re-up for the $25 fee or does one have to remember to do that?
Also, am I right to get started it is best to join SD at schedulesdirect.org (on any computer) before beginning the set up phase on the HTPC just to make cure membership goes through, credit card accepted, etc.?
sgbroimp is offline
post #13 of 15 Old 10-11-2019, 06:49 AM
Ken.F's Avatar
Liked: 2570
Note: Renewal is offered 45 days before expiration.
You will receive an email from us when your account is about to expire.
We will not bill you automatically.
You need a Schedules Direct account user name and password before you set up EPG123. SD will let you do a free 7 day trial if you want to make sure it's going to work before paying for a full year. They also have two month plan but I don't know who would want that.
Ken.F is offline
post #14 of 15 Old 10-11-2019, 06:53 AM
Ken.F's Avatar
Liked: 2570
I hate to keep hijacking this thread. It might be a good idea to start a new thread if you have any more EPG123 or Schedules Direct questions.
Ken.F is offline
post #15 of 15 Old 10-11-2019, 06:56 AM
sgbroimp's Avatar
Quoted: 305 Post(s)
Liked: 40
You are right, but I guess I was the first hijacker when I got off topic. Apologies to all.
sgbroimp is offline
Reply Home Theater Computers
