Remnant Arcsoft files cause page fault blue screen with Windows 10 updates - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-06-2019, 08:04 PM - Thread Starter
jmelan's Avatar
Quoted: 58 Post(s)
Liked: 33
Just a PSA for others here:
If you used to have or currently have Arcsoft TMT installed on a Windows 10 PC, attempting to run the latest Windows updates may result in update failure and a blue screen page fault error.
Seems 2 driver files, ArcSec.sys, and ArcCtrl.sys can be left over after uninstall
Following the instructions to delete both fixes the issue, and Windows updates can proceed
https://answers.microsoft.com/en-us/windows/forum/all/september-2019-update-with-bsod-at-reboot/fb3fb346-e48d-4fa6-bf6c-9272e3d38438
jmelan is offline
post #2 of 2 Old 10-12-2019, 08:40 AM
Slosh's Avatar
Quoted: 65 Post(s)
Liked: 42
Thanks for this!
We have 4 Haswell-based PCs at our house and two of them failed to install KB4517389. The two that failed are on Z87/Z97 motherboards with overclocked CPUs and RAM. The two that successfully updated are on B85 and H97 boards so I thought the page fault error might have something to do with the overclocked RAM. That wasn't the problem. Deleting ArcCtrl.sys fixed it.
Slosh is offline
Reply Home Theater Computers
