asus stx II with sparkos opamps - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-14-2019, 12:45 AM - Thread Starter
goodsguys's Avatar
Hi And thanks for reading this thread.
Just replaced the stock muse opamps in my asus stxII soundcard with sparkos discrete opamps, and it sounds awful.
The muses are so much better.
I heard something about 100 hours burn in time is required for the sparkos, it will have to be a big improvment to warrant keeping them.
Have you heard anything about this. What is the difference in sound quality with muses compared to sparkos. Is it a subtle difference or something more profound.
goodsguys is offline
post #2 of 2 Old 10-15-2019, 12:56 AM - Thread Starter
goodsguys's Avatar
I have found plenty of posts comparing sparkos against burson audio opamps, but nothing concerning muses vs sparkos.
What is your opinion of the muse opamp, it is expensive but is it audiophool expensive, or genuinely high performance.
Usually when i upgrade components, if the new component is better i can hear it straight away, so am not a big fan of the burn in theory.
Might be something to it, or maybe not.Do you have an opinion.
Reply Home Theater Computers
