What to do with a computer that has CATV/UHF inputs and a Dish satellite on my roof - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Worf
  • 1 Post By Foxbat121
post #1 of 5 Old 10-24-2019, 06:00 PM - Thread Starter
brandon_k_w's Avatar
Quoted: 108 Post(s)
Liked: 42
I have an older Sony Vaio VGC-LT28E computer that i want to use as a bar TV, mounted up in the corner. These were nice media PCs at the time. It has the UHF/VHF and CATV coaxial inputs. I also have a satellite dish on my roof left from my previous owner. Is there any good use i can get with these two things? Im trying to see if i can get free OTA channels, or possibly more if the satellite allows this.
Ive never used satellite before so i have no idea if I'm able to get free OTA channels just by having the dish on my roof, or if i would need to buy a separate box to decrypt the channels and pay a monthly fee. I'd like to try and make use of it before taking it off my roof and throwing it away.
brandon_k_w is offline
post #2 of 5 Old 10-25-2019, 12:31 AM
Worf's Avatar
Quoted: 846 Post(s)
Liked: 576
If the satellite dish is one if the small ones, then it's tied to dish or directv and will require a decoder and subscription. If you want to receive OTA, you will need an OTA antenna. Depending on how the satellite cabling is done, you might be able to reuse it for your antenna.
The other question is if your PC can handle ATSC signals - it may be too old and only have NTSC support
brandon_k_w likes this.
Worf is offline
post #3 of 5 Old 10-25-2019, 08:28 PM - Thread Starter
Quoted: 108 Post(s)
Liked: 42
Yes it has an input labeled ATSC/HDTV. Does having ATSC allow me more flexibility to do certain things vs. NTSC?
post #4 of 5 Old 10-25-2019, 08:38 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 506
As of now, all NTSC broadcasting has been turned off. They are all ATSC now.
Sent from my Pixel 3 using Tapatalk
Foxbat121 is online now
post #5 of 5 Old 10-27-2019, 07:49 AM
mrfattbill's Avatar
Quoted: 146 Post(s)
Liked: 106
I'd leave the mast on the roof, remove the dish and mount an antenna to it, use that and the existing cabling to get the feed inside and to your computer or even your television, that way you can watch OTA Even if you decide to not do this I would at the very least just leave the mounting plate up there, no sense in removing it and breaking what is a water tight seal.
Bill
mrfattbill is offline
Reply Home Theater Computers
